Question about LG DU-42PY10 42 in. Plasma HDTV
50PG20D the sound is still there but the screen has gone black ?
Screen black still has sound
Try in a very dark room with set on to look close at screen and or use a flashlight to see if faint images can be seen or not......
Oct 30, 2012 | Proscan 47 in. Diagonal Class LCD Full HD...
JVC LT-52P789 no picture just sound
If this is an LCD TV, show a flash light on the screen from a safe distance. If you can see picture, it means the backlights have gone off and the TV might need servicing.
Aug 23, 2012 | JVC LT Televison & Video
My screen has gone totally black. rebooting
The most likely problem in this situation is that the inverter is burned out. Do you hear sound? If your computer boots and there is sound, it is definitely the inverter board. You might want to try to replace the inverter board. I think it's about $15 on ebay. If you are tech-savvy you can take the computer apart. The inverter is usually located below the LCD screen. for more info on replacing the inverter click here http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-hp-pavilion-dv9000-laptop/
Sep 28, 2010 | HP Pavilion dv9000z Notebook
The Tom Tom screen has gone black. It worked Ok on
If I knew the model I could help you perform a hard reset as the first step to recover it. Antonio Cesar Brazil
Jan 14, 2010 | Tomtom GO GPS Receiver
Screen went black while watching, now ony have sound
Look at the venting grills, you should see whit lights inside the set. If not, the backlight inverter board may have gone out or the power supply supplying the power to the inverter board may have gone out. Those are the two places to look first. It may have bad capacitors in the power supply.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 06, 2009 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Blank/Black Screen, Sound/Audio is Static/Noise
It sounds like the Main board has gone out, but I would still check out the Power board also.
Mar 21, 2009 | JVC AV-27020 TV
No Picture just a Black Screen!
sounds to me like your display has gone you would be better of scrapping the set and getting a new one im afraid.
Mar 10, 2009 | Televison & Video
Black/white/rainbow screen
Sounds like power board issues, if your able test the voltages coming out of it and see if they are correct
Nov 23, 2017 | Insignia 19 in. Widescreen Flat-Panel LCD...
LG DU-42PY10 42 in. Plasma HDTV Logo
268 people viewed this question
Computer Repairing
Computer Repairing
