Question about Soyo DYLM1988 Monitor
Soyo DYLM1988 Comp Monitor; monitor powers on with picture for only 3 seconds, then picture goes blank (black screen), the power light stays on.
  • 11,361 Answers
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 04, 2011
Soyo DYLM1988 vertical hold/jittering picture problems when starting up. Clears when warmed up & playing with monitor settings helps.
How old is the screen? if more than 5 years, the circuitry can go bad. I had this with one of mine, it would jitter for about 10 mins before it warmed up. Just get a new one, they are cheap as chips
Sep 27, 2017 | Soyo DYLM1988 Monitor
My Soyo monitor (DYLM1998) stays blank (black) except when it is turned on, the monitor shows a picture for 2 seconds and then goes blank again. If I turn the monitor off/on several times, it finally...
your power supply has a short in it this is comon ive seen this before try to replace cord if attatched take it to someone for repairs if not attatched its the cord most of the time loose wire..
Apr 10, 2011 | Soyo DYLM1998 Monitor
I have a Soyo Monitor, Model MT-NI-DYLM1998. It had been working OK, but I put my computer in storage for 2 weeks and then tried to reconnect. The Soyo monitor stays blank (black) except when it is turned...
i have encountered this same issue with a monitor like yours its very common especially for lcd monitors there is a bad diode on your monitor board and you will not be able to fix this yourself you can buy another or use just a regular crt monitor or your best bet is to have it repaired im sorry and i hope this helps
Dec 19, 2009 | Soyo DYLM1998 Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Soyo DYLM1988 Monitor Logo
174 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
