Question about Nuova Simonelli Premier Maxi Espresso Machine
New Premier Max Semi. @ Gr. Boiler will not fill. Has two Steam wands so not area for a manual fill
    President:
  • 1,618 Answers
Remove the drain tray and safety cover the, the fill valve is down there.
Posted on Jan 05, 2011
Why no steam.Sunbeam 6910 cafe series. Turned on steam wand this morning and all I heard was a sigh, a feint try to deliver steam but not successful. Very little pump noise / action almost non-existent....
This could be 1 of many issues, usually the Steam pump (black or blue) is corroded and no longer vibrating correctly, the pump could be blocked, the pipe work after pump but before boiler could be blocked, the steam boiler could be blocked, the pipe work after steam boiler but before the steam tap could be blocked, the steam tap could be blocked, and also the milk nozzle could be blocked, if you feel competent to take it apart, it is easy to fix but if not take the machine to local service agent.
Feb 20, 2015 | Sunbeam Cafe EM6910
How to fix the wand on the espresso machine, not enough pressure is coming from the wand to steam the milk.
First check the steam wand tip to make sure it is not blocked. If it is clear remove the wand and run it under a faucet to make sure it is not blocked, it water flows freely, then the problem is on the fitting that connects the valve to the boiler, remove fitting and check, if clear check the boiler fitting, use a screwdriver and clear the fitting on top of the boiler.
Jun 28, 2011 | Astoria Compact CKXE Espresso Machine
Zero steam from steam wands. No pressure.
First thngs first, make sure knob is turned to 2, then make sure there is water in the boiler, then turn machine to 0, remove back panel and reset thermostat on top of back boiler, if your machine has that feature installed. Then turn machine to 2, open one of the steam wands, If within 10 minutes boiler does get hot or there is no water bubbles, from steam wand, then the pressure stat might be damaged and needs to be replaced.
Apr 14, 2011 | La Marzocco Linea Series Group 3 Espresso...
I have a francisfrancis x8 machine and cannot find my owners manual. I have a red light blinking after using the steam wand and need to know what that indicates. Also, where can I download the manual?
I've lost my manual too. I think the red blinking light means that the boiler is cooling down (from making steam). This machine only has one boiler so it must cool down and relieve the pressure built up by the steam before making another shot of espresso. You can turn the wand back on and shoot the hot water into a mug and this will speed up the cool down process.
Jan 15, 2011 | FrancisFrancis! X5 Espresso Machine
Steam wands on espresso machine wont work
There should be a boiler pressure and water pressure guage. If there is no pressure on the boiler guage that could mean a heating element or pressure stat problem.
www.kaldi.com
Jun 12, 2010 | La Pavoni LaPavoni Bar S3 Semi-Automatic...
No barometric pressure
Check the reset thermostat located on the right side of the machine just above the element, you will see 2 electrical brown wires going to it and a red push pin, make sure machine is OFF and not connected to the Mains, press reset you will hear the click. Plug machine in, turn on and open steam valve.
Apr 17, 2010 | Nuova Simonelli Premier Maxi Espresso...
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
Open Questions:
See all Nuova Simonelli Premier Maxi Espresso Machine Questions
Nuova Simonelli Premier Maxi Espresso Machine Logo
89 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
