Question about Microwave Ovens
Aluminium foil melted on Smeg black schott ceran cooktop. Too stubborn for razor blade. Any suggestions?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
try some oven cleaner, and let it soak...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 04, 2011
  • 591 Answers
You need something to corrode the aluminium, i know that calcium can corrode aluminium so i would suggest some sort of calcium based cleaning solution, or some abrasive solution (VIM, TOOTH PASTE, BRASSO, etc...) use carefuly!!!
  • Tommy
    Tommy Jan 05, 2011
    OK maiby you can try some thing more radical you need something to ETCH the aluminium away USE GRATE CAUTION WITH WHAT FALLOW
    you could find an aluminium etching solution in maiby a craft shop or make your own
    1- try CAUSTIC SODA mixed with water
    2- ferric chloride (FeCI3) use to etch PCB boards (RADIOSHAK/LA SOURCE)
    3-a mixture of the falowing
    1-Kilogram of BLUESTONE (CuSO4)
    250-Grams of TABLE SALT (NaCI)
    25-Grams of SANI FLUSH (NaHSO4)
    10-liters of WATER (H2O)
    sorry about the big quantity but it's what i have found
    now all of the above are ACIDS so use grate precotion and try the solutions on a small part at a time
Accidentally cooked with foil paper. Now my microwave oven is sparking. How can I fix it?
You could have burnt the foil into the bottom of microwave I would take a box razor and shave the area till there is no more foil melted in the bottom
May 07, 2014 | Samsung MU3250W Microwave Oven
Replacing the ceran glass maintop
Actually if you've removed the 2 or 3 screws at the front (underside) of the cooktop, you can lift up the front. Prop it up with a board, and then remove the 4 screws that hold the 2 brackets that hold the 4 elements to the cooktop. Now pull the cooktop forward a bit, and you should see a green ground wire attached to the back of the cooktop. If not, then don't worry about it! Just pull that cooktop up and off the range. You will need to transfer the 2 tabs in the back of the cooktop, and the silver steel bar located at the front of the top to the new cooktop. Then reverse the process to install the new cooktop and re-fasten the elements to it.
Apr 22, 2014 | Kenmore Microwave Ovens
Hi, We have MAYTAG schott ceran flexchoice glass cooking top. Even after cleaning it with a ceramic glass top cleaner,stains are remaining on it. Can u please suggest what is the best way to clean it .
Sudha3025 -
Sorry to hear you're having trouble getting your cooktop clean.
You mention you are using a glass-ceramic cleaner but I would also suggest scrapping the stains with a NEW metal razor scraper. A cooktop scraper is similar to one you would use to scrape paint off your windowpanes at home and you can typically find them at a hardware store. The razor won't damage the surface like other abrasive sponges might. For best results, hold the scraper at approximately a 30 degree angle to the cooktop and protect your hands by wearing an oven mitt.
Also try using a Wieman sponge in conjunction with the cleaner on those stubborn stains.
As always, try to clean up spills, especially sugary ones, immediately when they happen, or get them away from the hot burner area and clean after every use.
Hope this is helpful!
Apr 07, 2011 | Maytag Microwave Ovens
I have a new Jennaire Ceramic cooktop. I am having difficulty keeping it clean. Friends scared me into worrying about how to clean it. Please advice. r
Cerama-brite works well. You apply it like a wax, but it's got cleaners in it, and it's thicker. As it drys to a haze, you wipe it off with a dry paper towel. This is good for daily cleaning, and gets most soft residue. You can buy this anywhere. For more stubborn residue, you can use a pad similar to a Tuffie pad, (but it is colored red) and is made for cook tops. These are found on the cleaning pad aisle. You use this with the Cerama-brite. For the most stubborn burnt on stuff, they make a device that is retractable and holds a single edged razor blade. This has never failed to remove burnt on material. If the blade is used, you then follow it up with the Cerama-brite and pad, bringing the cook top back to shiny-new status.
Hope that this was helpful. Best regards, --W/D--
Jan 23, 2011 | Jenn-Air Microwave Ovens
I am just looking for a manual for a Bosch CERAN SCHOTT 5030002293 induction cooktop.
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, Driver downloads and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Nov 23, 2010 | Microwave Ovens
Good morning we are staying in a house of friends who are on holiday. I would like to clean the Bosch Ceran top but I am not sure which cleaning stuff I can use. Is the use of CIF creamer allowed with a...
Harry -
I would first see if your friend has a special ceramic cleaner in his or her cleaning supplies cupboard. If you can't find a ceramic cleaner, the best thing you can do is use hot water to clean the surface. All-purpose cleaners (like Cif) can damage the ceramic glass so it's best to avoid using them.
Also, look in your friend's cleaning supplies cupboard for a metal razor scraper. Use the razor scraper to scrape off any burnt-on food or spills. Do this by holding the scraper at approximately a 30 degrees angle to the cooktop while wearing an oven mitt to protect your hands. If no scraper is available, don't resort to a knife or abrasive sponge as these could damage the ceramic glass.
When the cooking surface is cool, apply a few dabs of the ceramic cleaner (if you found it) in each burner area and work the cleaning cream over the cooktop surface with a damp paper towel. Then wipe down with water and dry with a clean paper towel.
If no ceramic glass cleaner is available, it is sufficient to wipe down with hot water and a soft sponge. Never use abrasive sponges or scouring pads on ceramic glass cooktops. Also watch out for corrosive cleaners such as over sprays, cleaners containing chlorine or ammonia and stain removers - these will just further damage the surface.
For a list of approved CERAN cleaners see here: www.schott-ceran.com
Oct 28, 2010 | Microwave Ovens
Microwave Ovens Logo
233 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
