Question about HP Photosmart C7250 All-In-One Thermal Printer
Printer says it is fine, but the Magenta is not printing, so I cannot get the correct colors. I have tried cleaning and running the different Tests. Anything else I can do? On the Extended self Test Diagnostic page it says it is ok but it is a light pink. You can see faint lines in the Magenta. The rest look good.
    Problem Solver:
  • 10 Answers
Hi, is your magenta cartridge new? if it is new there are some factory defects concerning cartridges but this can be solve, you can go back to the store and let them check the defects of the cartridge or you can go to the nearest hp service center in your area to have a faster transaction.
Posted on Jan 04, 2011
Two problems: 1) I have had to replace the cyan, magenta, yellow, and black inks many different times and it seems like very often too, but I have NEVER had to replace the light cyan or light magenta...
If your documents look good when they are printed then the printer is working just fine and you dont have to be concerned about the ink use.
If the printer was not using the other cartridges correctly, then you would see areas that were missing color or were the wrong color when you tried to print. If the ink on a cartridge was not flowing freely the printer would stop printing and display error codes until the problem was corrected.
Being these things are not happening, I think it is safe to assume that it is working properly.
To correct the problem with the black line on the side, try cleaning your print heads and using the maintenance features on your printer. To access these features find the "menu" button on the printer and push it. Then scroll the features displayed by using the arrow keys on the printer until you see "maintenance". Then push the "ok" or "enter" button on the printer and continue using the arrow keys to find the cleaning options for print heads. Follow the instructions for cleaning the print heads and repeat the process a second time for good measures.
Regular maintenance of the printer should eliminate the black line problem and provide better printing results.
Oct 26, 2010 | HP Photosmart C7280 Laser Printer
Colors don't print correctly. such as green prints as red. what's messed up?
The color cartridge for this printer has three colors (cyan, magenta, and yellow) within it. So if one runs out or is dried up if throws the color out of wack. Try running the head cleaning first but replacing the color cartridge should correct the problem.
Aug 09, 2010 | HP DeskJet 930c InkJet Printer
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
I have all the correct color cartridges on my MP530 color printer. All of the sudden it coated a blue tint to my color printings. My print out look blue. Any suggestions I can correct the printer to print...
Just make sure the right colors are in the right place, photo magenta is not interchangeable regular magenta. Also run the nozzle check to make sure all colors print, if after 2 deep clean cycles you don't have all colors you may need a new printhead.
Jan 10, 2010 | Canon PIXMA® MP530 All-In-One Printer
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Weak color (reds only)
red colour requires magenta plus yellow.as u said magenta is brand new.may be the yellow is at its end so check out.this can be the problem.
Dec 16, 2008 | HP LaserJet 2605DTN Color Printer
Colour problems when printing with dj 130
I had similar problems when I first installed the printer and after different tests we found out that the Magenta ink print head was faulty. Changed head to a new one and problem solved. You will need to recalibrate and do paper set up's again.
Aug 16, 2008 | Designjet Black Designjet 30/130 Series...
Color printing problem
Most likely the print head has failed.
May 06, 2008 | Xerox Phaser 8200 Laser Printer
HP Photosmart C7250 All-In-One Thermal Printer Logo
261 people viewed this question
Seeker5211
Seeker5211
