Question about Maytag Atlantis MAV8551 Top Load Washer
Will not fill changed inlet valve not the problem
    Top Expert:
  • Maytag Master
  • 9,472 Answers
F you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
Posted on Jan 04, 2011
WF-T1022TP(H) INCOMMING WATER DOES NOT STOP
could b eather a pressour switch prob or inlet valve sticking open
Apr 29, 2015 | LG Washing Machines
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Apr 11, 2015 | Whirlpool Dishwashers
Dishwasher will not fill have changed the inlet valve but still not filling.
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Jul 20, 2011 | Bosch Dishwashers
Cold water fills the tub even when machine is not
This is almost definatley the inlet valve faulty.The inlet valve is literally stuck in the open position.You will need to change the inlet valve.I hope this helped you.
Jun 01, 2010 | Washing Machines
Cold water fill is very slow and makes strange sound
check with the plumbing work if that is fine then better take it to the dealer to change the inlet valve. attempting to change by yourself can cause other complications.
Oct 04, 2009 | KitchenAid KHWS01PWH Global Horizontal...
I have a KA fridge with ice maker. the ice maker cycles but does not fill with water. have changed the inlet valve but no change. any ideas what to do next
See if the water inlet valve is stopped up with ice, blocking the water. This happens when the water inlet valve leaks.
Sep 12, 2009 | Refrigerators
Ice maker wont fill
Hi, It sounds like the inlet valve needs changes. Could be the plunger inside the solenoid is not lifting to allow water through. If you remove the line going to the ice maker off the inlet valve, try and cycle the ice maker and put the inlet valve over a bucket to see if water is coming out when it gets voltage.
I hope this helps.Please let me knwo if I can assist you further.
Thanks
Vic
May 31, 2009 | Kenmore 53502 / 53504 Side by Side...
Fills with water when not in use.
Hi, If the washer fills up when off, you will need to change the inlet mixer valve. Do you have to shut the water source valve off to keep it from filling up?
Please let me know so I can assist you further.
Thanks
Vic
May 28, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Jun 22, 2007 | Creda W100FW Front Load Washer
Maytag Atlantis MAV8551 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
