Question about Amana NDE6800AYW Electric Dryer
The door light works but i dont have any other lights our powerto the control panel
2000 chrysler voyager. .audiovox system.. car is totally dead..no lights of any kind...alarm is chirpping, can not disengage
First put a booster pack or hook your booter cable on the car and there powerto the voyager take your remote and unlock the car if you dont have a remote simply unlock the rear door and passager door should remove the alarm good luck thans on using fixya
Mar 09, 2015 | 2000 Chrysler Grand Voyager
The switches on the 3 doors dont work either even if i try to control the windows or locks from the Driver switch still dont work. Ive tried changing the control switches and still nothing works, the
the drivers door switch is the master switch i would take a test light and check to see if the drivers door swich is sending 12 volts to other doors when pushing down on other windows test with test light to see if any light up if you find one that lights up stop pressing switch and see if it goes out if it does the switch is ok if it does not then the drivers door master switch is probably your problem
Aug 22, 2014 | 2001 Buick LeSabre
2003 chevy trailblazer driver door controls don't work, interior light won't work when driver door is opened. The other three doors work ok
There two common problems with the driver's door control panel, rain water gets into the module and damages the electrics or the wires in the door boot break or abrade and short out. To check out the control panel itself, take the passenger side panel and hook it up to the drivers side, if everything works, replace the driver's panel.
Dec 16, 2012 | 2003 Chevrolet TrailBlazer
A/c panel lights dont work why ?
The heater control panel is sealed so you can not access the lights. They simply go out and you have to replace the panel to get lights back.
May 21, 2012 | 2006 Jeep Grand Cherokee
Control panel not working and no lights
Hi. you will need to replace this non functioning Control Panel asap and, test the light pressure switch for it's operational value. If the switch is OK, simply replace the bulbs.
May 24, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Power windows dont work and the same problem with the power locks
the harness that is between the drivers door and the "a" pillar probably has some wires broken.
Dec 09, 2008 | 2005 Jeep Grand Cherokee
Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Feb 12, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
No lights work after installer removed door
hi i would look at the hinge area where door was removed, theres electrcal plug there and if he,s not connected it properly then lights dont work.. funky
Jun 27, 2007 | LG (LSC21935) Side by Side Refrigerator
Amana NDE6800AYW Electric Dryer Logo
43 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you an Amana Dryer Expert? Answer questions, earn points and help others
