Question about Microsoft Xbox 360 Console
My xbox 360 makes 2 tick like noises and then says open tray with any disc I put in please help
  • 839 Answers
Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to clean the disc.
· Once the disc is clean, load the disc into your console and see if the disc plays.
Or Click here to download repair guide
Posted on Jan 04, 2011
Xbox 360 elite console makes 2 weird noises and says open tray when putting in any discs.how to fix it
I've fixed open tray errors before, and if you are sure the problem is with the 360 and not the disc, it means you need to open the dvd drive and slide the laser over once or twice (at least based on my experience). BE CAREFUL. The mechanism that allows the laser to move around and read the disc is probably jammed.
Mar 20, 2011 | Microsoft Xbox 360 Console
I put in a disc into my xbox 360 and i just keeps reading th disc and saying open tray, I open tray, put in disc and close tray, it reads the disk and just repeats message open tray?? Please help
You can do it yourself by opening the xbox 360 case and the dvd rom with a proper tools.. tighten with a screw (counter clock) right there!! (see the picture)
Feb 16, 2011 | Microsoft Xbox 360 Console
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
When load a disk xbox 360 makes a clicking noise and says open tray on the screen
Something is most likely wrong with your disc tray.
Try a new disc, and if the problem persists, I would call xbox support.
May 19, 2010 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at alexswierenga@yahoo.com ty
May 29, 2009 | Microsoft Xbox 360 Console
the lens of the disc drive needs a check up...
When i put an xobx 360 disc in it says to open tray
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
This issue occurs when there is a problem with the lens on your 360 disc tray..
Apr 05, 2009 | Microsoft Xbox 360 Console
My xbox 360 only plays copies some of the time
your laser is nearly dead and needs replacing, the ticking sound indicates that the laser is at the end of its lifespan OR possibly needs cleaning and the power adjusting.
we can fix this for only £40 inc return delivery to your door.
www.fixmyconsole.co.uk
uk only
Apr 01, 2009 | Microsoft Xbox 360 Console
Disc Drive
u need a new drive
Jan 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
206 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
