Question about Sony Cyber-shot DSC-T90 Digital Camera
Sony Cybershot DSC T90 zoom facility has broken. It seems to have stuck and when reviewing pictures the pictures appear to have zoomed in.
pinkmajik
SOURCE: Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Posted on Oct 16, 2008
INTERLOGIC
  • 326 Answers
SOURCE: sony cybershot dsc-w200 zoom system error
try formatting the cam
Posted on Jan 17, 2009
zohail
  • 1223 Answers
SOURCE: Sony Cybershot DSC F828 problem with optical zoom feature
CCD Failure !
Just call Sony for Free Repairs they will do it , known problem in thousands of cameras just see the link below to confirm ur problem Sony has issued some service advisories but if u are not incl dont worry just call them and insist on free repairs
See this Pls rate me FIXYA for help
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
http://www.imaging-resource.com/badccds.html
Posted on Apr 24, 2009
Rammsteins
  • 300 Answers
SOURCE: sony Cybershot DSC-W150-turn power on, lens zooms
Hi!
It's probably stuck focus. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Posted on Jul 29, 2009
  • 497 Answers
SOURCE: I have a sony cybershot dsc-f707 Icant zoom in or
Option 1:
Reset the Camera and check if it helps to resolve the issue.(Resetting the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera).
The RESET button is located inside the battery/ Memory Stick cover. The Camera should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
Use a fully charged Battery in the Camera so that the Zoom function work normally.
Posted on Aug 27, 2009
Sony Cybershot DSC-W180 won't turn on when plugged into computer.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 27, 2012 | Sony Cybershot DSC-W180 10.1MP Digital...
My camera Cybershot DSC-W150 has a problem with zoom
Sounds like your lens might be stuck. Do not force it closed or pull it out for that might further damage parts that are an integral part of its sliding mechanism. http://www.teleplancamerarepair.com/Sony_Cyber-Shot_DSC-W150 can repair this for you and they also clean your camera as part of the repair.
if there were any parts you were not able to put together after you opened it , make sure to very carefully put those back to go along with your camera.
Jul 08, 2010 | Sony Cameras
Zoom wont work
Reset the camera setting , if the problem still remains than its software problem . due to T90 has no physically zoom out.
Apr 21, 2010 | Sony Cyber-shot DSC-T90 Digital Camera
I have a sony syber shot camera optical zoom 3x. sony DSC-T1. When I turn it on, the screen says ''Rec. folder is 101MSDCF'' The screen is black. I can take a picture but nothing appears. What can be my...
How about turn the nobe on the top. It is on the movie part. so it is recording movie. Change it to P or some other letter. You should be able to take picture now. good luck
Jun 09, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Cannot Take Pictures Anymore...
Hey BLOBO123,
I would have the camera looked at by an authorized service technician. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they can send it out for service. The flap that holds the batteries in could possible be purchased from the manufacturer and is probably pretty easy to replace, but the lens is usually much harder and expensive to repair. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Sony cybershot w50 zoom problem
Take it to a warm place to thaw out then try. If no joy then assume it has broken. If broken then it is not likely to repaired at reasonable cost - check out Sony for an estimate
Sep 10, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Green, I spent some time today with a sony tech rep on line. We went thru the motions of battery, memory card and still no help. So I'm sending my camera back to sony for repair. Mine is still under warranty. Hopefully yours is too. Good Luck. Mike aka m1stones1
Aug 21, 2006 | Sony Cyber-shot DSC-W50 Digital Camera
Digital Camera Zoom
When you change the resolution setting, you are changing the digital zoom. Here take a look. http://www.photoxels.com/article_zoom.html
Sep 08, 2005 | Sony Cyber-Shot DSC-S30 Digital Camera
Sony Cyber-shot DSC-T90 Digital Camera Logo
99 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
