Question about HP Pavilion dv6000z Notebook
My hp dv600 won't do anything not even with a new battery and new AC adapter l can't get no power at all let me know what can be the symptoms: thanks julio
  • sheepdog0331 Jan 04, 2011
    Does it give you any indicator lights when you press the on button? do you hear any fan noise even for an instant when you press the on button?
  • juliohern440 Jan 04, 2011
    no power light and the fan is not working the laptop is dead the only light l get is when l connect the AC adapter to the computer plug that is all l get
    Guru:
  • HP Master
  • 2,178 Answers
The motherboard is bad or the power jack is defective. Check the HP website to see if you qualify for a free repair. Some have been recalled for the mother board issue.
Posted on Jan 04, 2011
Won t charge new battery
Few options: either the connection is "hazy" (try moving the plug in the hole), battery is fake or battery has been abused and is empty...
Aug 16, 2013 | HP Mini Computers & Internet
HP Pavillion dv6700 - won't power up
Hi have you tried to power up without battery?
Feb 16, 2013 | HP Pavilion Computers & Internet
I have a Pavillion DV600 laptop and when i hit the power button I can see the blue light, located in the top part of the keyboard, for a second an then they turn off and the computer has no power. I also...
If your AC adapter is connected, then your motherboard needs to be replaced. If your AC adapter is not connected, then connect it and try charging the battery for several hours. After a few hours, check to see if your laptop will turn on. If not, then either the battery or the motherboard needs to be replaced. You will have to connect HP tech support to determine which one. They will probably try replacing the battery first and then the motherboard.
Sep 08, 2011 | Computers & Internet
Dv600 no power no power led blink when adapter attach into the laptop
take the battary out and tri agen with power adapter. If not test the DDR -.
90 % motherboard problems (Video chip)
Mar 07, 2011 | HP Pavilion dv6000z Notebook
I have an HP Pavilion dv 6000z. I had shut it down, tried to power it back up. It will not do anything. Some of the blue lights come on for a short period,then it is completely dead. It has happened once...
Look at the area where you plug the AC adapter in on the side of the computer. HP puts a little lite there or it lites up around the area where that plugs in when power is present. If there is no lite indicating power then you AC adapter is not working and that coupled with the battery being dead is causing your problem. Your other options are to remove the Hard Drive, Ram and CDROM units and see if you get power back. If you do then you know your problem is a short in one of those. The computer should start to bios with those items removed. If it does then replace one piece at a time until it stops responding and you have identified the problem. The other problems that could cause this dead PC symptom are a blown power circuit, requires a new motherboard, a burned CPU, requires replacement of CPU which is normally a new Motherboard in an HP because it is soldered directly to the board. Check the power supply AC Adapter first as this is the most common problem.
Feb 21, 2011 | HP Pavilion dv6000z Notebook
Compaq nc8000 won't start please i wont to know the problem on the mother board after swicth on it will go off after 4 second and it wil not even show anything on the screen and the fan too will go off.
It could very likely be the motherboard causing the problem, in which case you're best off just getting a new computer rather than replacing or repairing the board, but it could also be a power issue.
Try turning the computer on with the battery installed and the AC adapter disconnected, and then try it with the AC adapter connected and the battery removed -- does it show the same symptoms both times?
Jun 08, 2010 | HP Compaq Business nc8000 Notebook
HP DV600 laptop doesn't turn on even on mains.
It sounds like your ac adapter has died, and thus is not charging the battery back up. Test the adapter for power output. If it isn't working, the only option is to purchase another.
Jan 07, 2010 | HP Pavilion dv6000z Notebook
Hp dv600 will not turn on. It doesn't matter if the battery is in or if the adaptor is in, it will not turn on. I have no idea what to do or if there is anything i can do.
First thing to try, unplug the unit and remove the battery
Then hold the power button for at least 30 seconds, this will drain any power left on the motherboard.
plug the power line back in and attempt a restart. If it works you may get an error message warning you that your hibernation file is damaged. it is ok to allow the boot to continue but you will loose any unsaved files you had open.
If this doesn't work, unplug it, put the battery back in and then replug the AC adapter. look at the front left edge of the laptop and check for the AC light, looks like a lightning bolt. If it's not lit you may just have a faulty adapter, then can be replaced for about $100, with a targus or kensington universal adapter.
If the light is on and the reset doesn't work, it's likely a hardware failure in the charging circuit or motherbaord which can generally be repaired but depending on the price of the unit isn't always cost effective.
Feel free to post back and let me know if this does or doesn't work for you.
Chris
Armor-IT
Apr 24, 2009 | HP Pavilion dv6000t Notebook
Laptop won't turn on, blinking blue light
Jeremy,
It depends what failed on the motherboard. If the charging circuit is failed then you may indeed need a new mobo. The fact that it was working wouldn't be affected by the dead circuit as it only effects th laptops ability to recharge the battery or run from power.
Try talking to hp online tech support as they offer a $500 flat rate repair on many models. They can be access by going to www.hp.com and clicking the "contact us" link the the chat with live technician link.
Chris
Armor-IT
IBM T30 - power issues
You might try cleaning the battery compartment. Makeing sure there are no damaged pins. Often times even a single messed up pin will cause this. Also this is a very good indication of adaptor failure. If you haven't allready I suggest getting another ac adapter specific to you machine. Even a substitute will casue the same issue you are now experianceing.
Jul 11, 2008 | IBM ThinkPad T30 2366 Notebook
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
