Can I bypass the fan sensor? - Heating & Cooling
  • 2,133 Answers
Hazards In electrical and electronics happen only because of by passing sensors/controls/terminals.
It's not advisable method. Please replace sensor if defective or find exact problem and solve it. Helpful?
Posted on Jan 04, 2011
How can we bypass the cooling sensor by the thermostat?
Om most vehicles, you can't. The coolant temperature sensor sends a variable signal to the ECM based on coolant temp, and that value is used by the ECM in the computation of the fuel mix (rich/lean) to the injectors. Without it, the vehicle will run poorly, if at all, and will set the Check Engine Light. There MAY be a separate coolant sensor that simple controls the radiator fan. This one could be bypassed, but that comes with great risk of engine overheating and damage. Most newer cars use the coolant temp sensor for both the fuel mix and the radiator fan with the fan on/off signal controlled by the ECM.
Oct 11, 2015 | Cars & Trucks
What sensors are bypassed when the cooling fan is put on a fusible link on 89 firebird
I'm not sure I completely understand your question, if youre wiring the cooling fan directly to power (with the fusible link) you'll be bypassing the PCM's output to the fan relay...the PCM uses the Coolant temp sensor (CTS) as an input to determine when to turn the fan on.
Jun 17, 2015 | 1989 Pontiac Firebird
I can't find the radiator cooling fan sensor
if the sensor is for the car and the correct temp more than likely the car is not hot enough to turn on the switch , hence fan.
the fan works, if you bypass switch..
Apr 28, 2015 | 2005 Chrysler Pacifica
2000 400 grizzly fan cycling on and off and quad overheating. What can cause the fan to cycle ? And how do i troubleshoot the issue ?
Sounds like your heat sensor is bad most are attached to the radiator in the Cooling fins..to make sure the fans are not the problem..after the engine is warm enough to turn on the fans locate the sensor and unplug it then using a jumper wire "paper clip or any small wire " as a bypass connect the two wires together "the plug end" the turn on the switch..the fans should run as long as the switch is in the on position..if it does your sensor needs replaced...note if you are out where there is no help and the fans are shutting off and the engine is running hot..just bypass the sensor until you can replace it..Just make sure it shuts off with your ignition switch off..or the battery will drain..good luck
Oct 22, 2014 | ATVs
Radiator fan switch or coolant temp sensor however it is called is not activating the radiator fan when temperature is high. . .iS THERE a way to by pass this switch or sensor so it can activate the...
CHECK COOLING FAN FUSE AND RELAY.IF ALL IS GOOD.HOT WIRE COOLING FAN TO MAKE SURE COOLING FAN MOTOR IS WORKING. IF COOLING FAN RUNS WHEN YOU HOT WIRE FAN MOTOR.CODE SCAN FOR ECM FAULT CODES.REPLACE THE ENGINE COOLANT TEMPERATURE SENSOR NO NEED TO BYPASS THE SENSOR.
Aug 22, 2011 | 2004 Suzuki Aerio
Sensors blew after bypassing fan.
no they blew for other reasons
Oct 29, 2009 | 1997 Pontiac Grand Am
FAN PROBLEM OR SENSOR?
i believe you have a sensor problem best way is to replace the sensor but you can bypass it it will automatically make the fan come on when you bypass the sensor
Jun 06, 2009 | 1999 Plymouth Grand Voyager
Bypassing Temperature sensor on the radiator
Just connect the two wires that are connected to the sensor which will keep the fan running when the ignition is on.
May 07, 2009 | 1994 Toyota Camry
Sensor Wire/Fan 1990 Toyota Corolla
There is a sensor screwed into the bottom of the radiator
Dec 11, 2008 | 1990 Toyota Corolla
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
