Question about Kenmore 24032\24036 Top Load Washer
Water is leaking from the front of the washer unto the floor. It is not a problem with the hoses.
    President:
  • 3,113 Answers
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: when my washer drains into wall pipe it rush out
There is a blockage in the wall pipe, you will have to fake it apart to find the blockage, or try rodding it through with a flexible drain cleaner.
Posted on Jan 25, 2010
My passenger floor board is wet bypassed the heater coreand it is still getting wet what else could it be
If you have an ac the drain hose for the evaporator is clogged and water overflows pan and drips unto floor. Clear the hose and the water leaking will be gone.
Sep 03, 2015 | 2009 Pontiac G6
Washer leaks water on floor
its possibly the door seal if its a front loader, or a hose, you can easily remove the back cover panel re attach any cords or hoses needed to remove the panel then operate it while looking for the source
Jun 07, 2013 | Washing Machines
I have a frigidaire atf6000es and while the washer is running water is running out in the floor
Hello Brandy Neal - Often a leak coming from underneath the washer would indicate a leak possibly in the hoses or in the tub. If the hoses are securely tighten then at this point I personally recommend consulting with a certified technician to narrow down the precise issue.
Mar 10, 2013 | Frigidaire ATF6000ES Front Load Washer
I found a some water on the floor by the front of the washer. where did it come from ?
Most likey a water inlet hose is loose on the valve body or the water valve from the wall may be leaking or if thats not it then mostlikey te drain hose has a leak or the water pump may be leaking.
Apr 10, 2010 | GE WBSR3140DW Top Load Washer
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
GE FRONT LOADER WASHER LEAKING WATER
inspect the door boot the rubber thing between the tub and door also inspect the hoses inside the machine you will see the leak
Aug 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking on floor at right front corner of
check the door rubber for any tears,this is also called a boot glove.
Jul 14, 2009 | LG WM2688H Front Load Washer
In the spin cycle water leaks onto the floor,
If the hoses at the back are not leaking, you need to check the drain hose lines, aksi check that the machine is not dripping from the inlet valve hose, or because of a leak from the door gasket.
Dec 09, 2008 | Maytag PAV3240A Top Load Washer
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Waher
quite possiblethat the tub itself is sitting to far foward, this machine fills from the back section above the tub, very possible as it fills its deflecting off the tub cover and unto the floor
Nov 26, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
24 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
