Question about Citizen Eco-Drive BL006056H Wrist Watch
Hello, can you give some tips on how to change the capacitor? I bought a new one and have no idea how to replace it. Is there perhaps some kind of diagram giving proper instructions that can be followed? The watch is a lady's citizens watch eco drive BO23 Model No.EW8XXX/EP4XXX Thank you
  • b7maire7 Jan 04, 2011
    Can you help me please
  • 73 Answers
SOURCE: Setting the time on a Citizen Eco-Drive Watch
Go to this link and pay particular instructions on how to find your watches movement or caliber number.
http://www.citizenwatch.com/COA/English/settings.asp
Posted on Dec 31, 2007
SOURCE: Citizen Eco Drive
A "non" fully charged watch will sometimes "jump" seconds rather than indicate one second intervals. Charging these small solar panel watches takes forever, in BRIGHT sun. Have you tried leaving it outside, in the sunlight, for at least 12 hours?
Posted on Jan 05, 2008
escapement
  • 2334 Answers
SOURCE: CITIZEN BL9000-59F MEN ECO DRIVE WATCH minute repeater
Try this link:
http://www.citizenwatch.com/CUK/English/settings.asp
Everything you need for the caliber number and settings is here.
Do not forget to rate, please.
Posted on Feb 24, 2009
escapement
  • 2334 Answers
SOURCE: how do you adjust a stainless steel strap of a citizen eco watch
If there are screw on each side- you have to use two screwdrivers simultaneously. If not- read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together. Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!! Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Sep 01, 2009
escapement
  • 2334 Answers
SOURCE: need to shorten my band
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
Hello, please could you advise me? I've bought an Ingersoll ladies' diamond watch for 30 pounds from Cash Converters and I need to have the battery replaced to see if it's working. It has a screw back
I would suggest taking your watch in to a local jeweller. They should be able to replace the battery for a few pounds or give you an opinion on other options. A Google search should find several in your area.
Jan 13, 2015 | Watches
How to remove back to change battery in "My Wish" Collezioni watch. No notch for knife and won't screw off.
You should be able to pry it off, just follow this simple steps:
Locate a very small tab (or recessed area) on the edge of the back cover. Pull out the stem, which releases the back on some watches.Get a small flathead screwdriver it needs to be a thin inflexible tip. Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch. These steps are listed on wikihow:
http://www.wikihow.com/Pry-off-a-Watch-Backing-Without-Proper-Tools . You also could skip step 2 if it's a cheap quartz watch.
Feb 19, 2013 | Watches
What kind of light should i use to charge my watch
stick the mtg900 in a window sill for a day and that should charge it completely. If that does not work that means you will need a new capacitor. It might be easier at that point to buy a new or pre owned on ebay . they go for like 60 dollars or so.
even though they are solar they still need a battery to store the electricity needed to run the watch. A capacitor will need to be replaced from every 5 to 10 years.
Jan 24, 2012 | Casio Atomic-Solar MTG900 Watch
Hello! I got a compax, hour twelve in figures, rest dots. Backside number on clock is 978926 22498. Steel. When manufactured, sold where? Can you help me? Thanks in advance! Kind regards. Per...
Go to http://www.universal.ch/.
The web site should give you all the information you require.
I cannot find the watch (?) you describe: perhaps there is another maker with a similar model name?
Apr 25, 2010 | Watches
Watch Band requires replacement
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 22, 2010 | Watches
I got new timex iron man with heart rate monitor. Just after 2months indiglo lights don't function anymore. I need it badly for my early dawn workouts
Do not be so upset - any nearest watchmaker will fix it. All you need is a new battery. Visit your nearest watch repair shop and ask for a new battery to fit in. If you not satisfied: find out in my TIPS here for the manual for your watch. Explanation: When you bought the watch, it was in perfect state (allegedly), everything was working and so on. The thing you do NOT know is: battery was fitted in the workshop long ago, maybe a year or few ago before you bought it. That is OK, co'z watch companies do fit a battery at the point of watch leaving company. So, for example, you bought a brand new watch, but it is not working at all. Wind it up. Or, if you are unable to do the things we do, visit TIMEX download page. Save your nerve and watch as well - send it back and ask for replacement. You will find everything in my tips here on FixYa.
Feb 05, 2010 | Timex Ironman Triathlon 50 Lap Digital...
Gucci watch looses 10 mins a day after battery change
Please refer this matter to expert. Kindly run through below website for assistance in finding the nearest outlet/dealers in your country.
Gucci
Apr 12, 2009 | Gucci 6700 YA067503
Citizen Eco-Drive BL006056H Wrist Watch Logo
48 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Are you a Citizen Watch Expert? Answer questions, earn points and help others
