Question about Sony VAIO VGP-WKB1 Keyboard
The Y key is not working properly. Have to press it very hard to get in to work properly
  • 46 Answers
Probably some dirt or grease prevents easy connection. some keys are easy to clean.
Posted on Jan 04, 2011
Asus motherboard-p5gc-mx hangs at flash sreen
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
http://windows.microsoft.com/en-AU/windows7/products/system-requirements test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules make sure they have secure dust free conections
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
if you need more help with this post a reply
hope it helps
May 05, 2012 | ASUS Computers & Internet
How to hard reset nokia 5130
You can reset it using a soft or hard reset. The following instructions provide you with information on how to reset the Nokia 5130 using both methods.
  • Soft Reset
The soft reset is often the better option if you are worried about losing data. There is a chance the soft reset will also default to the factory settings, but there is a bigger chance that it will not. With a soft reset you will enter in *#7380#. This tends to clear any pending errors and on most phones it will help your phone work properly.
  • Hard Reset
  • The code for Hard Reset is *#7370#. Enter these digits into the phone and press yes to confirm. This will start the initialization process. Make certain you have already saved all important data. You do not want to lose your contacts, memo, or other information due to a hard reset. You may have issues with a Nokia phone that is not turned on. If there are problems such as these you can try hitting three buttons simultaneously. Hit the +*+3. If you can hit these three buttons all at once you may be able to get the phone to turn on, and then you can go through the hard reset with the proper codes.
These codes work with all of the Nokia models including the 5130. You may find other options do exist such as the power button while pressing the space key and delete key, and caps/ shift button will also hard reset the phone.
It all depends on whether or not the *# keys work. Sometimes they won't work if the phone is in phone lock or key pad lock and you need to get it open first.
Oct 02, 2011 | Nokia 5130 Cellular Phone
My computer says reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key
Hello
This means that your hard drive is not detected by your computer.Unplug your computer then open the cover then check if the connector of the hard disk are properly connected and the power supply on the hard disk are also properly connected. And try to feel if your hard is vibrating when you powered it on. Because if the hard disk does not vibrating it means that your hard disk have no power or not properly connected to the connectors or damage. Sometimes i experienced this problem thats all i done then it works.
Jul 29, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Both my desktop and laptop computers do not recognize my Signature mini external hard drive. I've replaced the cable. No difference. The ports work fine because they work with my printer. I have...
External hard drives of this type are mainly composed of a USB-to-SATA interface & a 2.5" SATA hard drive. If any of these components is defective, then you won't be able to access your data.
So, basically we have 2 possibilities:
1. A failing USB-to-SATA interface. You can test this possibility by disassembling the device, taking the hard drive out, & testing the hard drive in your desktop computer using a 2.5" to 3.5" SATA adapter. If the hard drive works fine, then the problem lies within the USB-to-SATA interface.
3. In the previous step, if the hard drive could not be detected by your desktop computer or is not working properly, then it is the failing part.
Jun 11, 2011 | SimpleTech Signature Mini 320GB External...
Emachine wants to: " reboot an select proper boot device or insert boot media in selected boot device an press any key " . I dont have a boot media or know what is the proper doot device....
The proper boot device is your hard drive, when you boot hit F2 while it is booting up and it will bring up the screen to change boot devices select the hard drive and save the settings and this should work if it dont it is possible that your hard drive has bit the dust.
B52computers
Jan 14, 2011 | E-Machines eMachines Desktop PC
HTC P3400i is not working properly, only a red
Try to hard reset it. You, most probably, know that a hard reset will set your device to its factory defaults, thus deleting every program you have installed, as well as you personal data. Hope you have a recent backup, to be restored after the hard reset procedure.
Anyway, to do it, press and hold both softkeys (the ones marked with '-'), and, whilst keeping them pressed, briefly press the reset pin (at the botton of the device) with the stylus pen. Keep pressing the keys until a warning message comes up. Then, release the keys and follow instructions on the screen (if any).
Hope you are able to bring your device back to life.
Regards, Carlos
May 05, 2010 | HTC Touch P3450 Smartphone
My keys are not working properly, having trouble
Use a can of compressed air to loosen dirt. Then turn kboard over and litely tap on back. You will be amazed at what falls out of the keyboard.
Sep 28, 2009 | Compaq Keyboard
Keyboard Fn key
Try hooking up and external key board see if that works ok, and if it does you may want to try to find a new or used key board for your laptop. The key board may be shot, It should be fairly easy to change to a new board, Hopefully That will help you diag. the problem..
Jan 06, 2008 | Acer Aspire 5630 Notebook
Sony VAIO VGP-WKB1 Keyboard Logo
100 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
