Question about Kwikset Professional Door Lock installation Kit
Kwikset interior faceplate doesn't stay snapped in place. How to fix?
  • 784 Answers
The trim plate is held in place by a small indentation that is on the edge of the ring,, you should be able to use a small pointy punch and lightly tap the intentation in more so it grabs the lock screw plate more. there is also a notch that needs to line up correctly.
c...
Posted on Jan 04, 2011
I have an exterior screwless doorknob that I need to remove. The faceplate on the inside knob that covers the screws is also covering the little pin that removes the knob. Is there another way to remove...
There is the 3rd version of the Kwikset exterior door set. The interior face plate is removed and on each side of the base plate has small slots with a lever on either side that need to be moved to the other end of the slot. The whole interior knob assembly with come off.
Dec 23, 2011 | Kwikset Locks & Locksmithing
How do i change the code to my kwikset smart code?
Hi and welcome to FixYa, I am Kelly.
Here is the manual. (link below) See step 9 on page 6.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
My interpetation:
Slide the interior cover off. Locate the program button. Press program button, enter code. press progran button. You can also enter a 2nd code by pressing the program button 2 times, enter the code, press program button 2 times. Re-align the interior cover after programing code.
Thanks for choosing FixYa,
Kelly
Apr 20, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Exterior key for deadbolt just turns around and around.
It sounds like the exterior tumbler is bad, it is less expensive to just replace the whole deadbolt than to have the tumbler repaired.
Jun 15, 2010 | Kwikset Professional Door Lock...
Xbox 360 Console: My xbox 360 will keep opening its tray and it won'...
The very first thing, I would suggest you is to check the CD cover, as sometimes labels on CDs prevent tray to close.
If that does not work then do the following.
Remove disc from the tray, make sure the faceplate is on correctly.
The faceplate is the plastic piece on the front of your console.
• Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
• If you find that the faceplate is the problem, please contact Xbox customer support to order a replacement faceplate.
If this does not resolve your issue, please try step 3 and other steps from following link.
http://support.xbox.com/support/en/us/xbox360/kb.aspx?ID=907590&lcid=1033&category=hardware
If you wish you can also use following link of interactive troubleshooting wizard, which will assist you to narrow down on the issue.
http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xdds
This solution is absolutely free. If your issue is still not resolved, please feel free to ask.
Please rate and give your feedback.
May 03, 2010 | Video Game Consoles & Games
Key snapped off inisde upvc door lock key snapped at collar
ok here's a try at getting it out.
Sol1
Take two sewing needles and slide each one each side of the broken key. Go into the sides at an angle to 'nip' the broken piece and gently but firmly try to pull it out.
Sol2
If you have super glue and the remainder key section you can try to reglue the ends back together. this will only give you adhesion to remove the broken part out not a permanent fix. put glue on part you have and never too much as to seal the lock.
Sol3
Try tapping the reverse side of the lock with short sharp taps to encourage the stuck part to dislodge out, enough to get hair tweezers to pul out the stuck part.
Sol4
You need to remove screws from handles and faceplates and remove to revieal the lock. dismantle parts and keep them in removal logical order. so they can be replaced back in reverse order.
AndystUK
Aug 30, 2009 | Kwikset Locks & Locksmithing
Need to disassemble deadbolt with concealed screws
If it's like my deadbolt, pull the inside faceplate off. It's just pressed in place and the screws are behind it.
May 30, 2009 | Kwikset Powerbolt/Electronic Deadbolt-...
Keypad doesn't light up.
If this is a battery operated lock then the backlight doesn't stay on (otherwise it will wear the batteries out). To make the keys light up when you want to enter your code you have to push the lock button on the keypad first. If the keypad light has never come on then open the door and manually lock the interior lock then press the keypad lock button then the above instructions will work. This is the solution I got from Kwikset customer support and it worked for me. Hope this helps you.
May 19, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Loose Kwikset Chelsea Deadbolt
I just had the same problem as samrpetrich with a loose kwikset deadbolt. Here's how I fixed it - on the inside of the door, take off the latch that flips the deadbolt in and out using a very small allen key. There is a round plate cover that is snapped on top of the inside deadbolt mechanism. If you look on the bottom aspect of this round plate you'll see where it snaps on; once I saw where to apply pressure it came off easily - taking off this plate exposed the two screws beneath that were loose. Once I tightened these, I snapped the plate cover back on, but the dead bolt latch back and everything is tight again. Hope this helps.
Jan 23, 2009 | Kwikset Professional Door Lock...
LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG LRSC-26922 Side by Side Refrigerator
Kwikset Professional Door Lock installation Kit Logo
106 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
