Question about Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system
I have the Home SC-BT228P-K Theater System and the TC-P50U2 Plasma Television. I have the Home Theater System set as Input #1 with HDMI, the Satellite Receiver set as Input #2 with HDMI, and my XBox 360 set as Input #3 with HDMI. I can hear sound and see picture the the Home Theater System for the satellite receiver and the XBox, but when I put the setting on Input #1 and put a DVD in all I hear is the sound. I don't see any picture at all. I can't even get the Home Theater system to pull up a menu on the Television. I have it set with the ARC connection, and I tried the Vierra Link, even though I am not sure about that. Do I need Digital Optical Cables or something? I just figured I would see a picture and no sound if that were the case.
5 Suggested Answers
SOURCE: panasonic SC-pt960 home theater
You must set up the Reciever manue to accept Digiatl Audio in... refer to your manual
Posted on Nov 05, 2008
vetteman3002
  • 2299 Answers
SOURCE: I have a Panasonic VIERA
You need a digital audio fiber optic cable. You can get them at Walmart, Radio Shack, Target, just about anywhere. They are not real expensive around $15
Posted on Nov 03, 2010
  • 569 Answers
SOURCE: I have a Panasonic Model TC-p42X1 TV hooked up to
It's possible that you have the wrong type of HDMI cable. You need one that has Audio Return if you want to feed your Home Theater system with audio from the TV. There are several types of HDMI cable,some with audio return and some without. The two basic types (not including Ethernet) are described below - you need the High Speed version, which does have Audio Return.
hdmi-standard.jpgHDMI Standard This is the most basic HDMI standard which all cables have to meet. Cable should contain all the connections required for HD transmission, and have to deliver at least a resolution of 720p, (Video mode of 1280 x 720 meaning 720 Horizontal lines). These cables do not contain an Ethernet connection, or audio return.
hdmi-high-speed.jpgHDMI High Speed HDMI High Speed cables will support higher resolutions of 1080p. This means at least 1080 Horizontal lines, and cables rated at this specification may well support high resolutions of up to 4096 x 2160 (2160 Horizontal lines), check individual cables specifications for this data. Cables in this specification will also support a data transfer speed of 10.2Gbs (not to be confused with ethernet data speeds which are different), and a clock speed of 320Mhz. These cables do not contain an Ethernet connection, but do include an Audio Return Channel.
Posted on Feb 03, 2011
bobhifi
  • 635 Answers
SOURCE: I just bought Panasonic SC-PT480P-K
Let us take things step by step.
1) If you have an AV cable ( Yellow /Red/White ) try connecting the DVD players composite out (Y/R/W) to the TV's composite in. Select AV input instead of HDMI on the TV and see if you are getting an image. This is to confirm that the DVD video circuit is OK.
2) If all is OK in step one you can try buying a good HDMI v1.3 cable. You do not need a v1.4 cable which is only good for 3D bluray players.
Revert back for more.
Posted on Apr 02, 2011
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
Aug 13, 2014 | Panasonic Smart VIERA TC-P55VT50 55" Class...
How to connect a ps3 to a panasonic sc-btt190 home theater
My suggestion would be to use the ps3 to connect to TV using hdmi & then use an optical audio output (toslink) from TV to the btt190... You would think they would have one or two hdmi connections there but no they have none.... This is how I connected appletv to the btt190.... Works fine you just have to set tv input to appletv and btt190 input to >>ext in >> digital in....
Good luck. Btw have you connected to network? Did you have any troubles - mine will not connect via cat5 cable...
May 19, 2013 | Panasonic Sc-Btt190 Home Theater System...
How do i connect the tv to a Sony HT-DDW7600 Home theatre system
Use HDMI cable to connect the television and home theater.You can see the HDMI input at the back of your television and the HDMI output of the home theater at back of your player.
Jul 02, 2011 | LG 50PG20 50 in. Plasma HDTV
How do I connect the SC-BT228 Home theater to my new 50" Panasonic Plasma TCP-50S30 so that I can use the home theater speakers for both TV and Disc player?
You need a Digital Audio Cable connected as shown below from your SC-BT228 Manual.
Full setting details for the SC-BT228 Digital Audio In & TC-P50S30 Digital Audio Out are within the Manuals which can be downloaded from Panasonic at the following link.
http://www2.panasonic.com/consumer-electronics/support/
Please leave feedback.
Cheers
Andy
May 15, 2011 | Panasonic SCBT230 Theater System
I just bought Panasonic SC-PT480P-K DVD home theater and TC-P46ST30 TV. I connect DVD HDMI output to TV HDMI input port #1. But when I try to play DVD, I just got sound out to the home theater speakers...
Mar 07, 2011 | Panasonic SCPT480 Theater System
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
I cannot get a picture from my sc-bt100 on my screen the sound is working no problem checked all leads and connections
How are you hooking it up? To what kind of TV? Best connection for SC-BT100 is via HDMI out on SC-BT100 to HDMI in on TV, otherwise you aren't getting full HD output. Make sure your TV is set to correct input source.....
Dec 27, 2009 | Panasonic SC-BT100 Theater System
I just bought a dvd home theater system sc-pt760 and i have a 42 inch LG flat screen and the sound wount work on AUX for the TV
Are you using the HDMI connection on both units, the SC-PT760 does have a HDMI input Yes/NO ? If not then it has HDMI output to the LG for HD Picture. What I would do if no HDMI INPUT to the SC-PT760 is available, run out of the TV with the Digital connection into the SC-PT760 Digital Audio in, assign the input as tv and you shoild get TV audio out of your home theatre, you could also use the analog connection audio out of the tv to the home theatre but this would not yield a dolby digital sound.
Feb 02, 2009 | Panasonic Home Theater System System
Plasma tv/home theater
Is your Panasonic set to monitor the HDMI input? Just like selecting a mode input on the Tv you must also select the mode input on the surround system.
Bill
Dec 07, 2007 | Televison & Video
Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system Logo
211 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
