Question about Turboair Heating & Cooling
I have 2 turbo air, Model # tas-9h/tas-940. One in a guest bedroom and one in my woodworking shop. The one in my shop makes a very loud grinding noise like the fan blade is rubbing on something. The other one is nice and quit. Please help! Gary Werbowski
koolbreezes
  • 540 Answers
SOURCE: AC make loud noise on power off.
Is this a wndow unit or central air system? if this is a window unit , your problem is it only needs cleanning (dirt dbber nest-- trash around the back blades-- or the unt is twisted and rubbing the fan shroud. Last but not least, the slinger ring around the back blades (a ring around the end of the blades thats picks up water in the bottom of the unit and sling it on the coils to help cool the hot gases....Thank-you Thank you Thank you very much!
Posted on Jun 03, 2008
  • 95 Answers
SOURCE: My Frigidaire compact window air
take it back for warranty... or call a pro.
Posted on Jun 10, 2008
22yooper
  • 828 Answers
SOURCE: outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Posted on Jun 16, 2008
  • 140 Answers
SOURCE: Unit constantly makes a clicking noise.
Electronic filters use static dicharges to filter the air. Unfortunately the make that clicking noise when they discharge. LG calls it a plasma filter. Clean both the regular and the plasma filter to see if that helps.
Posted on Dec 30, 2008
  • 588 Answers
SOURCE: York HVAC unit fan is
If your fan is making noise the blade or blower wheel is either hitting something or the bearings in the motor are bad and the motor needs to be replaced.
Posted on Apr 23, 2009
What is the meaning of an F1 error?
What kind of contractor is he? Go to the supplier that the contractor purchased the system from. Or the MFG website, or email their customer service. I'd let them know what kind of contractors are installing their equipment.
Jun 15, 2015 | Turbo Air Inc Turbo Air Ductless Mini...
Replacement Remote
EMAIL: ajpkassociatesllc@outlook.com for parts / remote controls
Jun 02, 2013 | Turboair Heating & Cooling
Replacing a starter on a 1993 volvo 940 turbo. Is this a difficult task?
It looks easy for the 940 but I am not sure about the 940 turbo, as maybe some of the turbo parts are in the way. I'm not sure about that, since there is no documentation on the turbo model vs. the 940 standard model. If you can follow the following instructions, then I would give it a whirl.
REMOVAL & INSTALLATION - 1993 Volvo 940
  1. Disconnect the negative battery cable at the battery.
  2. Disconnect the leads from the starter motor.
  3. Remove the starter motor retaining bolts.
  4. Remove the starter motor from the vehicle. To install:
  5. Position the starter motor to the flywheel housing.
  6. Apply locking compound to the bolt threads and install the retaining bolts finger-tight.
  7. Tighten the bolts to approximately 25 ft. lbs. (34 Nm).
  8. Connect the starter motor leads and the negative battery cable. Fig. 1: Unfasten the nut retaining the starter cables . . . 90952p12.jpg
    Fig. 2: . . . and remove the starter cables 90952p14.jpg
    Fig. 3: Unfasten the starter retaining bolts . . . 90952p11.jpg
    Fig. 4: . . . and remove the starter from the engine 90952p15.jpg
Oct 28, 2010 | 1993 Volvo 940
The problem with my car is that it will run like a top one day & the next day it will stall every couple of blocks. Any ideas?
940 i think is the turbo model pull out the air filter you may not be getting enough air the turbo maybe bad. otherwise sorry it 5 am ive been up all night my brain is fried lol.
Apr 22, 2010 | 1992 Volvo 940
Swapped 940 turbo motor with another 940 turbo now SRS fault lite is on.
that would be the air bad light. You can pull the fuse on it if you wish. Otherwise, the computer will have to be reset.
Sep 16, 2009 | 1991 Volvo 940
Ac unit cools entire home except for one bedroom
The issue may not be confined to airflow alone. An air conditioner makes us more comfortable through two basic rules of physics.
It removes sensible heat (the temperature you feel) and removes moisture from the air. Dry air enhances the bodies own cooling system allowing perspiration to evaporate more quickly which speeds the removal of heat from the body, this is why 85 and dry feels more comfortable than 72 moist degrees.
to ensure the ducts are balanced properly one must use an anemometer which is a tool used to calculate airflow by the pro's. Being that most homeowners do not have access to one there are some good observations to make using a pocket thermometer and your own senses:
  1. Ensure the guest room vent is the same size as the master bedroom.
  2. Ensure the supply duct for the suspect vent is the same diameter and approximate distance from the main plenum (where the ducts originate) as the master bedroom.
  3. Is the air emminating from the suspect vent approximately the same in volume as the master bedroom (does it feel and sound the same).
  4. The issue exists even if the guest bedroom door is left open.
  5. The air temperature measured at the vents is within 3-5 degrees of each other.
If 1 - 4 are true check for #5, if # 5 is false make sure the suspect ducting is insulated or covered well by attic insulation.
If 1, 2, 3 or 4 are false: Ensure the following:
  • The guest room ducting does not have a damper hidden under insulation or duct wrap.
  • The duct has not been crushed or restricted.
NOTE: internaly insulated ducts can be restricted on the inside by fallen insulation while appearing normal on the outside.
If #5 is false (issue goes away if the door is left open) the door may need to be cut off a bit more at the bottom or a grill installed to allow the air coming into the room a place to go.
If none of the above reveal the culprit concider the room itelf, it may have a higher heat load than the others.
A higher heat load may be due to dislodged, compacted and or wet insulation in the walls or attic, feel the walls and ceilings with your hands, how does it compare with cooler rooms?
If the walls and ceiling feel about the same and the tests above did not expose an issue its time to call the contractor back in, make sure the static pressure is checked in each duct a foot or so downstream of the the plenum and again just upstream of the vent. A duct with air pressure higher or lower when compared with the others could mean a variety of issues with the duct or where it connects to the plenum.
May 26, 2009 | Heating & Cooling
940 GL Stall problem
crank sensor problem
Jun 16, 2008 | 1992 Volvo 940
Volvo 940 se turbo estate
on the engine drivers side below the air intake/below the brake fluid reservoir/ follow the large red batery cable
Jun 14, 2008 | 1993 Volvo 940
Heating & Cooling Logo
71 people viewed this question
Top Turboair Heating & Cooling Experts
Steve F
Thomas Woodburn
Thomas Woodburn
Andy
Are you a Turboair Heating and Cooling Expert? Answer questions, earn points and help others
