Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
No hot water. Are the elements behind the thermosats?
    Top Expert:
  • Rheem Master
  • 11,211 Answers
They are behind the access plates but look at the plates the top one usually has a reset button behind it
Posted on Jan 04, 2011
GE40M06AAG lower element leaking at the gasket. Will any 240V, 4500W replacement element work, or is there one recommended?
taking it that you are talking about a hot water system (models mean nothing with out make and type of equipment) take the old element to a plumbers supply shop( hardware shops will not have the elements) and they will have a suitable replacement
elements can be straight loops or be curved so that the follow the sides of the tank
however with electric hot water systems , the leak is not always at the gasket but at the fitting behind the gasket which has corroded internally from electrolysis for the element
recommend that as there is power involved that you get in an accredited plumber to check the system first because if the tank is leaking then a new gasket and element is a waste of cash
Jun 15, 2017 | Element Water Heaters
It is not a refridgerator, it's a hot water heater!
The element is right behind that panel,sounds like that is whats leaking. The elements just screw in or have a plate that compresses againt the element and gasket. Either way sound like a simple fix be carefull those wires are 240 volts most of the time inless its a small water heater.
Lowes has the elements just shut off the power and drain the heater before you start. If its an older heater it will be rusted any may not come out,just be ready to a buy new heater if you cant remove the element and damage the heater due to all the rust. Good luck
Jan 11, 2013 | Water Heaters
No hot water from hot taps at all.
IT SOUNDS LIKE YOU HAVE A BURNT OUT HEATING ELEMENT YOU PROBABLY HAVE TWO IN THIS UNIT CH YOUR CERKET BREAKER FIRST IF OK DRAIN THE UNIT TURN BREAKER OFF RE MOVE ELEMENTS THAY ARE BEHIND THE COVERS THAY HAVE PHILIP'S SCREWS TAKE THEM TO LOWS OR HOME DEPOT MATCH WITH NEW ONES PUT THE NEW ONES IN FILL THE UNIT WITH WATER OPEN A WATER TAP LET RUN TILL ALL THE AIR IS OUT THEN TURN THE POWER BACK ON HOPE THIS HELPS GOOD LUCK BOB
Apr 25, 2011 | Reliance & 40 Gal Mobile Home Water Heater...
I have no hot water in my home i can not locate the reset button
The reset button is located on the top thermostat, on the heater you will see a acess panel with screws in it to remove the thermostat and element is behind this panel. Once removed the top thermostat should have a red button to press to reset heater.
If it resets then wait for a little time for hot water. If this doesn't work then it could be the elements are in need of changing.
Apr 09, 2011 | General Electric GE SmartWater Household...
No hot water on electric but burning hot on lp gas,what can my problem be.
Need to confirm hydro to water heater, all switches breakers etc on, and check to make sure switch at back of water heater at connection box on as well. If power to back of water heater, then check for reset in center of ECO on back behind cover. If power going to element ( behind cover as well) then replace element. Be careful when removing cover on back. Shut breaker off at main panel until you can get cover off and ready to test voltage.
Feb 26, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Elec water heater 40gal water way to hot and blowing braker on the water tank Red reset button what wrong please help
One of the thermostats is bad or there is corrosion behind it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Feb 14, 2011 | Water Heaters
Replaced bottom element and both thermosats. the reset button tripped what would cause this to happen
Reset trips when upper thermostat senses high heat event over 150 degrees F.
High heat can be caused by:
1) Element shorted to ground through center of element. Thermostats turn off one leg of 240V circuit. Elements always have 120V available. If element is shorted to ground, it might not trip breaker, and continues to heat using one leg of 240 with circuit completed to ground wire.
Test elements:
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#120-240
2) Insulation and cover not put back over thermostat. Thermostat exposed to cool air, misreads temperature causing element to continue heating.
3) Thermostat sticking in ON position. I usually replace both thermostats at same time to save another trip.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
4) Shorted wire or loose wire at or near upper thermostat. Check that screws are very tight against copper wire.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
5) One suspect can be eliminated is 240Volt power to heater.
Your heater circuit is good.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 18, 2011 | Rheem Water Heaters
I have a rheem water heater model # 72- 40- 1 not getting enough hot water .it only has 1 element how can i put in another element and wire it correctly? please help
First, let me say that no Rheem electric water heater that I am aware of has only 1 element.
You may have to search - but there should be one about 8 inches from the top and another behind a panel about 10 inches above the bottom. Please search again.
It is NOT possible to add an element to a "used" water heater. The inner and outer liners must both be sealed and that is done at the factory.
Feb 19, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water not getting hot / Kenmore Economizer 6 / Electric
Did you check to make sure that the breaker is good on the unit? Check to make sure you are getting voltage. If not, check to make sure that the thermostat located in behind the panel on the heater is getting voltage and also sending voltage to the elements. If the elements are getting voltage but aren't heating, the element(s) is bad.
Mar 06, 2009 | General Electric GE SmartWater Household...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
19 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
