Question about Freezers
I defrosting my imperial heavy duty commercial freezer. Now it won't get cold. Is there something that I can do to troubleshoot. Does something have to be reset.
  • 833 Answers
SOURCE: Can my kenmore chest freezer be in the garage during hot summers and cold winters in Minnesota?
Jeremy,
You can put a fridge/freezer in the garage. Be sure that the area is level so you don't warp the case which will cause sealing problems with the gasket. Also, clean the condenser frequently as dust and dirt will reduce efficiency.
Posted on Dec 04, 2007
victorwod
  • 157 Answers
SOURCE: I have lost my turnkey for an Imperial Upright
you can visit the website of the company and make a request for the key or get the door forced it to get open and get a new locker key for it.
Posted on Feb 20, 2010
SOURCE: I have a Superior heavy duty commercial upright
I have a superior hd freezer it is working but the out side sides get very hot any idea
Posted on Jun 09, 2010
SOURCE: We have an imperial upright ''commercial grade''
just to be sure that your door is sealing properly, put a flashlight into the freezer and turn off all of the lights in the room to see if there are any openings in the seal. Iam suggesting you this coz sometimes a small opening may pass our eyes easily....
if the door is sealing properly......
If this is the type of freezer where the shelves are the evaporator coils, the coolant goes through the shelves(tubing) and the formation of frost is normal and has to be manually defrosted.All the shelves should be as cold asd the top one. The fact that just one has any frost may indicate that it is low on freon. If this is the case you should notice that the freezer doesn't get cold enought just like you said... so check your freon levels.
This could also be because of the thermostat not sensing when the fridge reaches its set temperature and as a result of this the compressor will keep on running and build-up of ice will occur.
Follow the advices in the order prescribed above and you should be set
Posted on Jul 27, 2010
  • 1531 Answers
SOURCE: We have an upright Commercial Grade heavy duty
the suction noise is not something that will happen all the time.
check the current draw on the compressor and make sure it is in between 1.2 and 1.6 amps.also look at you evaporator coils and make sure there is no excessive frost build up.If there is ice build up then you need to defrost it check the heating element and defrost timer and make sure they are in proper working order.also check the evaporator fan and make sure it is working when the unit is in a cooling mode.
Posted on Sep 08, 2010
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
Our old Imperial heavy duty commercial model uf20x needs seal. Where to find it?
Commercial refrigerator parts supplier can make it same day. Check google for your nearest supplier.
Feb 01, 2014 | True 72 cu. ft. / 2039 liter Commercial...
Freezer Controls
Cold, Colder, B-r-r-r
Nov 23, 2013 | Freezers
What is the best way to defrost a heavy duty commericial Imperial freezer?
a commercial freezer should have it's own defrost cycle. I would look into what the issue is that is causing you to do a manual defrost.
The 2 most common AND safe ways to defrost any freezer is either using hot water or a hot air source such as a hair dryer.
Dec 04, 2010 | Freezers
We have an upright Commercial Grade heavy duty Imperial Freezer, model # UL4000ECW2, purchased a little over 10 years ago. Today I noticed that everything in it is thawing and when I close it, it no longer...
Sep 07, 2010 | Freezers
I have lost my turnkey for an Imperial Upright heavy duty Commercial Freezer. It is locked and I have no way of getting inside... Where can I get one?
Feb 16, 2010 | Amana 19.7 cu. ft. / 558 liter Upright...
I need to know which circuit to install for my freezer The description I have is imperial commercial manaual defrost freezer 20.7 Cu Ft.
put it on a dedicated circuit(meaning only item on this breaker) with a minimum of 20 amps @ 120 volts
Sep 23, 2009 | Freezers
Jeremy,
Nov 27, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Freezers Logo
212 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
