Question about Whirlpool LSR7333 Top Load Washer
The basket doesn't spin - Whirlpool LSR7333 Top Load Washer
  • 479 Answers
If the basket is not spinning then issue might be with motor or the belt assembly connecting motor rotor to basket provided the power and switch are ok.
You may need the help of a mechanic for the same.
Thanks
Posted on Jan 04, 2011
    President:
  • 3,113 Answers
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Washing machine will not spin
see this causes:
It doesn't pump or spin
frozen pulley pump or belt broken pump, replace+tes the lid swithc for defective and replace.
It pumps, but doesn't spin
lid switch defective replace+coupler broker+belt defective+clutch worn+drive motor defective+transmission drive NOT shifting properly+basket drive worn :replace
It spins only with the lid closed safety reason, will not start.
see the diagram.
God bless you
Jul 02, 2012 | Kenmore 24032\24036 Top Load Washer
Washer wont spin
see this possibles cause:
frozen pump pulley+drive pump belt broken replace
lid switch open, or defective +motor coupler broken+belt broken+clutch worn+motor defective.+transmission not shifting properly+basket worn
safety the machine will run with the lid door closed.
God bless you
Jun 28, 2012 | LG WM1814CW Front Load Washer
711 Lid lock issues
see this causes:
frozen puller, or broken belt, lid switch defective or open replace
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, basket worn,
for security reason, only spin with the lid closed
Jun 19, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Washer will not spin dry
see the causes:
frozen pulley or broken belt replace+lid switch open or defective replace
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, the basket is worn.
for safety, only sping with the lid closed.
Jun 19, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine will not spin
see this causes:
frozen pulley pump, or broken belt replace+lid swtich defective
lid switch defective,motor coupler defective,+belt broke, clutch worn, +drive motor defective, +transmission is not shifting properly+basket drive worn replace. see the diagram
safety reasin the spin working with the lid closed
see the diagram .God bless you
Jun 19, 2012 | Fisher and Paykel Washing Machines
Maytag Neptune rotates but not in spin mode
see the causes:
frozen puller or belt broken pump, lid switch defective
lid switch defective+motor coupler defective+belt broken+clutch worn+drive motor faulty+transmision not shifting properly+basket worn.
lid for security reason.
see the diagram
Jun 19, 2012 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Ensignia model MAV2757 AWW. The washer basket doesn't balance, even with a small load, and turns off due to the weight being unbalanced. The springs are there and oiled, the hardware...
Snubber ring that tub and spin basket assembly sits in is most likely worn. Very inexpensive part but extensive labor involved. I would suggest calling a competent service tech.
Nov 14, 2017 | Maytag Ensignia MAV2757AWW Top Load Washer
My Kenmore washing machine, model number 26812690, won't agitate or spin. It goes through all the cycles but the tub doesn't move
if its a direct drive , make sure the brake is releasing for starters, If the spin basket has difficulty getting up to speed, you have a slipping clutch. You can determine this by slightly holding the spin basket when you select spin.A rapid spin up to speed shows a "good" clutch. other things to check for are a broken coupler, or any item trapped between the drum and housing, ( which is what happens most the time, )
Jul 09, 2011 | Kenmore Washing Machines
I have a Maytag Neptune TL (FAV6800AWQ , Serial # 10178127EC) that starts and stops after the wash cycle begins. It fills up fine but starts and stops/pauses and the time doesn’t lapse. On a normal load...
You have a Series 10 machine 1st two digits of your s/n.
Seems like you have the Service Manual or troubleshooting guide.....can't get that from Servicematters any more I feel you have some drive system binding.
I helped a owner on another forum similar problem. Google this "Neptune TL Spinning Issue Will Not Proceed". Did a lot of up front testing in the end he ended up replaceing the Outer Tub Bearings, the Clutch Pulley.
Start by opening the washer lid and see if you can rotate the wash basket with one finger in the CCW Spin direction. There should be only slight resistance to rotate the wash basket CCW. During the 1st water fill of the wash basket the Control Board will spin the wash Basket slow rpm you can enter Service Mode and observe the rpm on the LED console.
Next start a Quick Spin test and note the highest RPM range the machine will spin up to. Looking for Outer Tub Bearing resistance.
I would suggest another DIY forum to work thru this issue if you are going to DIY. This forum is hit and miss we posting pics and e-mail notification for support......Rich
Oct 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool LSR7333 Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
