When i turn it on the system start then the fan stops and the fault ligth comes on
    Genius:
  • 1,126 Answers
I would first replace the fan, and also yo can check the voltage where the connector is plugged in at when it is working and then check and see if the voltage is there after it quits.
Posted on Jan 04, 2011
I have ASrock P4vm800,Prescott800,Pentium 4 Pro.But i need a help.When it is powered up nothing happenes except the system unit ligth up,& chassis font panel ligth is blinking Continously.Cpu fan...
There is a verity of things you can check & or replace. You mentioned the CPU fan is not turning. This is very very important.
This suggests possible CPU fan is defective. Average life span for a CPU fan is 5 years or 50,000 hours. Your MB uses Intel PGA socket 478. For a replacement heatsink & fan assembly open the link provided;
http://www.amazon.com/Thermaltake-A4012-Cooler-Intel-Socket/dp/B000FEW8JW/ref=dp_cp_ob_e_title_0
A new heatsink assembly will come with a new fan attached to the heatsink.
It should also come with new thermal past or thermal tape attached to the bottom of the heatsink assembly.
As to the front panel LED light blinking continuously.
If the LED light is red in color this means your primary hard disk drive is trying to load windows.
My suggestion is for you to replace the CPU heatsink assembly first.
No need to remove the CPU from its socket at this time.
If you never replaced the Heatsink & fan assembly watch the video included below;
http://www.youtube.com/watch?v=4OB1hxxKdec
Once completed your system should function correctly.
If it doesn't, post you’re finding here & I'll help you further.
Cheers'
Mike
Aug 10, 2010 | Computers & Internet
I change the turn signal lever I took apart unplunged everything carefully put everyhing back together carefully but as I was workig on it I heard my horn honk twice I look no bear wires anywhere finish...
your security system is activated. try turning the key on let set for 10 minutes turn it off then start. on some models it has to be done 3 times on off on off on off start. 10 minutes each time
Jun 22, 2010 | 2000 Chevrolet Tahoe
Securyty ligth car dont star
ANY TIME SECURITY LIGHT COME ON YOU HAVE FAULT IN THE IGNITION KEY OR KEYS THEY COULD BE WORN OUT WHERE TO A POINT WHERE THE BCM AND PCM DONT RECOGNIZE THE CAR KEYS CAUSING NO START CONDITIONS.ALSO WORN KEY SWITCH AND BCM WILL CAUSE NO START CONDITIONS.TRY THESE TWO THINGS TRY ANOTHER CAR KEY IF STILL DONT CRANK.PUT KEY IN IGNITION TURN KEY TO ON POSITION WITH ENGINE OFF LEAVE KEY ON POSITION IN IGNITION FOR 10 MINUTES WATCH DASH SECURITY LIGHT WHEN IT TURNS OFF IN 10 MINUTES.TURN OFF IGNITION FOR 5 SECONDS THEN TRY STARTING CAR IF CRANKS OR DONT STILL THE PROBLEM IS IN THE THEFT SECURITY SYSTEM NEED TO GET DEALERSHIP TO FIX THEY HAVE DIAGNOSTIC EQUIPMENT TO FIX AND REPROGRAM THEFT SECURITY. SYSTEM.
May 25, 2010 | 1999 Oldsmobile Alero
No turn ligth and no stops ligt
gmc had a recall for that problem. It is the switch under the break pedel was installed wrong during manufacturing. Took mine in and they replaced switch.
Aug 09, 2009 | 1994 GMC Sierra
Ligth for air-bag do not turn off when the car is
How many times have you started the vehicle after reconnecting the harness. There is a certain amount of no fault starts before the light clears. You may have to clear the light manually with a scanner.
Jul 26, 2009 | 1991 Porsche 911
Clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
H8DAE-0 Fan issues, stopping and starting.
Sounds as if you have a motherboard fault or a processor fault, as, if the processor is faulty, everything will stop, especially if the temperatures arent being read correctly by the motherboard causing the system to shut down before any damage is done.. It's a process of illimination i'm afraid
Aug 21, 2007 | SuperMicro H8DAE Motherboard
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
