Question about Breadman TR2200C Ultimate Bread Maker
My bread machine when plugged in, just makes a clicking sounds like it is timing out on a timer. Pushed all the buttons and reset button..still just clicks.
    Genius:
  • Breadman Master
  • 1,280 Answers
In cold weather many machines warm up first before mixing especially when the whole wheat program is chosen. The clicking you hear is the heating element and oven chamber expanding etc.
If your machine hasnt't started mixing within 30 mins. after you push start then there is a malfunction.
Posted on Jan 04, 2011
I went to plug my bread maker in Model B2500C and it started making a funny noise. Then I moved it to a different area to see if it would work better. When I plug it in it automatically starts and won't...
These are fussy models and have lots of issues - if you are still covered under warranty just contact B & D, they were great at sending me a new model after mine broke under warranty. It sounds like yours is broken beyond repair, it is likely cheaper to replace it. Try contacting the company, they should be able to help you best.
Sep 07, 2013 | Black & Decker Bread Machine
Trying to make French bread in my toastmaster bread and butter maker. Bread rose, doesn't bake. Machine is flashing 000
If you pushed the button for "French" bread then you do have a problem. If you pushed the "Dough" buttton then the flashing0:00 just means your dough is ready.
Apr 13, 2013 | Toastmaster TBR15 Bread Maker
Would like to know how to set machine to start at a later time
Since you haven't listed the model or make of the bread machine, there is a simple solution for this problem that will work or any make or model bread machine.
Using an "outlet timer" or sometimes known as "appliance timer" you can set your bread machine to receive power at a particular time in the day and you can even set it to turn off at a specified time too!
eliteandres.jpeg Above is a picture of what one of these devices looks like. These can be found at home improvement stores or online.
Step one: Plug the outlet timer into the wall Step two: Plug the Breach Machine into the outlet timer, and leave it in the "on" position. Step three: Set the timer to turn on at the specified time.
The bread machine will receive power at whatever time you set the timer to turn on and since its in the "on" position it will automatically start making the bread.
Feb 28, 2011 | Kitchen Appliances - Others
My Toastmaster TBR2 bread machine does not knead when started. It makes a tick-tock noise and the timer counts down but no mixing. The bread pan is positioned correctly. Why?
Make sure you are programming your machine correctly.
The Instruction Manual indicates three possible problems, none of which would seem to be your problem. Not plugged in, error message or kneading blade missing.
Suggest you review the Instruction Manual for programming your bread maker. Unplug your machine to reset and then plug in and program as directed.
TRB2 Instruction Manual:
http://dl.owneriq.net/4/4ae504be-4834-4845-a8f8-7a6df62c1033.pdf
Jan 22, 2011 | Toastmaster TBR2 Bread Maker
Timer is working but the motor (that spins the piece to make the dough) does not. Is there any security fuse ? Thanks Michel
Hi michel amor
If you are using the timer nothing will happen until the time you set for the breadmaking process to begin occurs. In other words if it 8 am and you want your bread several hours later then your bread machine will do nothing until several hours later. If you don't want to use the timer and you just want to be sure that your paddle turns and kneads the bread go ahead and push the stop button and hold it down until it beeps. Unplug your machine, then plug it back in. Then do this:
----push select
----choose your program ( for example choose #1 basic)
---choose your crust color
----choose your loaf size 1.0, 1.5, or 2.0 pounds
----push the start button
----your machine will start mixing with the paddle
----if your machine is cold it may warm up for about 15 -20 minutes but it will start mixing within 1/2 hour.........hope all this helps
Jan 10, 2011 | Black & Decker Bread Machine
Need the operting Manual for PerfectBaker PB571
Here's some info;
http://www.creativehomemaking.com/download/TR888_1183_Recipe_Book.pdf
Here is some operating instructions one baker used for this machine;
But here's how to actually use it:
Put wet ingredients in loaf pan. Heap dry ingredients on top. Make a well in dry ingredients and add yeast, ensuring it doesn't touch liquid if you want to use the timer. Put pan in breadmaker, clicking into place.
Plug in breadmaker but DO NOT touch the on/off button till the very last.
Using the "menu" button, choose what type of bread you're making (the top two rows -- normal, fruity etc).
Using the "crust control" select how dark you want your crust.
Using the "timer" select how long till you get the finished product. The minimum is 3 hours for quick bread/medium crust, which I often use, the maximum 14 hrs 30mins. It goes up in 30 minute increments with each push of the up arrow. Remember, what the timer shows is when the finished bread will be ready.
Once you're satisfied with your settings, press on/off
If you choose "fruity bread" the timer will beep into the kneading process to tell you it's time to add the fruit. It goes in at a later stage.
When the bread is finished, it will keep on a warm cycle for a while until you switch it off.
I use high grade flour and add 1 tsp gluten flour to each cup of flour. The bread rises more.
Apr 25, 2009 | Breadman TR888 Corner Bakery Bread Maker
Delay-bake timer not working
I have given you the instructions for the timer for the B2200 and B2250 models. I hope this answers your question. I have also included a link to the manual in case you don't have one.
Carol.
6. Timer Buttons
Press these buttons to set the time for delay bake (up to 13-hour
delay). For example, you can time your bread to be ready for
dinner or when you wake up in the morning. Set it by selecting
how much time you want to pass before the bread is completed.
For example, if it is 8:00 p.m. and you want the bread to be ready
at 7:00 a.m., set it for 11 hours.
You can also use these buttons to adjust the time of the cycle.
They adjust up or down in 10-minute increments. Changes must
be made before the unit begins operation.
http://www.useandcaremanuals.com/pdf/B220,B2250984.pdf
Jan 19, 2009 | Black & Decker Bread Machine
TR440 Breadman won't begin kneading once "start" button is pushed
Hi Mindy.......it takes 30 minutes to PREHEAT this silly machine for wheat bread. I thought I did something wrong, too........I stopped it twice after it preheated for about 15 minutes. I did not want to waste anything so I let it stay in the machine.....I just went to check the machine and it started after 30 minutes of preheating.
I wish they would mention this in the book!!!
Julie from TX
Jan 11, 2009 | Breadman TR875 Bread Maker
I need a manuel for my bread maker chefmate hb-12w
Here's the instructions for Model HB-215. Source =>
http://www.globalgourmet.com/forum/index.php?topic=47.msg222
The post below this post says Chef Mate - Models HB12W, HB215 and CM725 only! So, it might be the same instructions.
Chefmate Bakery Oven Model HB-215
Modes:
  • Standard 1.5 lb normal crust: Bakes a 1.5 lb basic loaf of bread in 2 hrs 30 min.
  • Standard 1.5 lb dark crust: Bakes 5 min longer.
  • Standard 1 lb normal: Bakes a 1 lb basic loaf of bread in 2 hrs 20 min. No “dark” option.
  • French mode: Bakes a French loaf of bread (salty taste) in 3 hrs 40 min.
  • Sweet mode: Bakes a sweet flavor loaf which tastes like a butter roll in 3 hrs 40 min.
  • Doughmode: Use this mode for making dough for rolls, croissants, doughnuts,etc., which you want to bake in your conventional oven. Prepares doughin 1 hr 20 min.
Control Panel: (when pressing a controlbutton, be sure to hold it down until you hear a “Beeping” soundindicating contact has been made.
  • Display: Shows the time remaining until a mode is completed. Can also display timer setting or mode selected.
  • Select button: Push to select mode: Cycles through modes in following order:
    Normal 1.5lb -> Dark 1.5 lb -> 1 lb -> French -> Sweet -> Dough
  • Start button: Push to start processing the mode selected.
  • Stop button: (press for one second to take effect)
    Push to turn off power after baking is completed or to reset the mode or timer.
    If used after a mode is started, it will stop it.
  • Timer set buttons: Up arrow: advances timer setting 10 min each time pressed.
    Down arrow: sets timer setting back 10 min each time pressed.
Ingredient Information
  • Flour– Use flour that is marked “bread flour” or “better for bread”. (Thesewill usually be labeled as having more gluten than regular flour.)
  • Dry Skim Milk – This enhances the flavor and adds to the nutrition of the bread.
  • Butter – Butter adds a rich flavor to the bread and makes it soft.
  • DryYeast – Yeast is necessary for causing the dough to rise. Select readyto use yeast which needs no preliminary fermentation. Use only activedry yeast. Don’t use 50% faster dry yeast.
  • Sugar – Sugar speeds up the dough rising process, adds flavor, and makes the bread soft and the crust brown.
  • Salt – Salt controls the activity of the yeast and makes the dough firm.
  • Water– Gluten is formed when flour is mixed with water. This allows thedough to rise by retaining air. The amount of water and its temperatureare very important. Usually, the water temperature should be between 68F/20 C and 77 F/25 C. When the room temperature is over 82 F/ 26C, usecold water (about 41 F/5 C). When the room temperature is under 50 F/10C, use lukewarm water (about 100 F/38 C).
Operating Instructions
Baking a standard loaf of bread using Standard Mode.
Ingredients for 1 lb loaf for 1.5 lb loaf
Water 7 ½ ounces (210ml) 9 ½ ounces (270ml)
Bread Flour 2 1/3 cups 3 cups
Dry Skim Milk ½ tablespoon 1 tablespoon
Sugar 1 tablespoon 1 ½ tablespoons
Salt 1 teaspoon 1 ½ teaspoons
Butter 1 tablespoon 1 ½ tablespoons
Dry Yeast 1 ½ teaspoon 1 ¾ teaspoons
1. Open the lid and remove the bread case (hold both sides of handle and turn counterclockwise.
2. Position the kneading blade on the drive shaft. (remove any crumbs from drive shaft.)
3. Place ingredients into the bread case. Add ingredients in the following order:
Pour in the proper amount of water.
Add the flour, sugar, salt, butter, and dry skim milk – in that order.
Place the dry yeast on the center of the flour.
Note:When using the timer, make a hollow depression in the ***** of flourand pour the dry yeast into it. Do not let the yeast touch the water orthe dough may not rise properly.
4. Place the bread case into the body of the baker. Turn clockwise to lock
5. Close the lid.
6. Plug in to outlet. (after being plugged in the number “0 00” will flash in the display.
7. Setthe standard mode. Press the select button to set the mode to Normal,Dark, or 1 lb, depending on your preference and the amounts ofingredients used.
8. Start. Press the START button. The timereadout in the display will begin counting down the minutes from theamount of time required for the mode you have selected.
Steam may rise from the vent on the back of the lid during operation.
When baking is finished, the buzzer will sound three times and the display will read “0 00”
9. Removingthe bread case. When the buzzer stops, press the STOP button and openthe lid of the baker. ( The heater in the unit will keep operating tokeep the bread warm for a while after baking is complete. When removingthe bread case, always be sure to press the STOP button to turn off theheater.) Using the handle and oven mitts, remove the bread case. Thehandle and bread case will be very hot. Do not place the heated breadcase on the body of the baker, table cloth, or plastic surfaces.
10. Removing the bread from the bread case.
Usingoven mitts, turn the bread case upside down and gently shake it toremove the bread. The surface of the bread case is slippery, so be sureyou have a firm grip.
If the bread can not be easily removed, turn the drive shaft on the bottom in both directions so loosen the bread.
Place the bread on a wire rack or similar surface to cool.
Note: when baking is completed, remove the bread as soon as possible. If leftin the case for a long period of time, its surface will become stickyand the flavor will be lost. If the kneading blade comes out with thebread, use a plastic or wooden utensil to remove it. CAUTION: it willbe hot.
11. Remove the plug from the outlet.
Baking a French loaf of bread using the French mode
Follow the above instructions, except select French mode in step 7 and use the following ingredients in the order shown:
Water 9 ½ ounces (270ml)
Bread Flour 3 cups
Sugar 1 ½ teaspoons
Salt 1 ½ teaspoons
Butter 1 ½ tablespoons
Dry yeast 1 ¾ teaspoons
Baking a sweet flavor loaf of bread using the Sweet Mode
As above, but select Sweet Mode in step 7 and use the following ingredients in the order shown:
Water 7 ounces (200ml)
Egg (medium size) 1
All Purpose Flour ½ cup
Dry Skim Milk 2 tablespoons
Sugar 2 tablespoons
Salt 1 ½ teaspoons
Butter 3 tablespoons
Dry Yeast 1 ½ teaspoons
How to use the timer. (The timer function cannot be used with Sweet or Dough modes)
The timer extends the time from pressing START until the baking completes.
1. Place all ingredients into the unit and plug it in.
2. Select the desired mode
3. Press up arrow once. The normal time for that mode will be displayed: 2:30 for a standard loaf.
4. Keep pressing up arrow (or down arrow) until the desired time to completion is displayed.
5. Press the START button to start the delayed timing.
Preparing a dough for handmade bread using the Dough mode.
1. Follow steps 1 through 6 for standard loaf. Select Dough mode in step 7.
2. Press START to begin the dough making process. It will take 1 hr 20 min. The display will show the time remaining.
3. Thebuzzer will sound 3 times to let you know the dough is ready. Take itout and shape it as you wish for baking in a conventional oven.
4. Unplug from outlet.
Dec 30, 2008 | Kitchen Appliances - Others
Breadman TR2200C Ultimate Bread Maker Logo
159 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
paul
paul
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
