Question about HP Photosmart C5280 Printer
Display is very light and you can hardly read what it says.
    Problem Solver:
  • 10 Answers
Did you mean the display panel? there are some possibilities concerning with this problem. first, loosen connection. second, not enough power to support the printer check the power supply if it generates exact power to run. third, display panel is defective consult HP support or go to your nearest HP service center.
Posted on Jan 04, 2011
Proform 775 ekg control panel very dim, hard to read display
sounds like the back light is bad, not sure what type of screen that is. but most screens have a back light for them, they will go bad over time,
Apr 03, 2017 | The Computers & Internet
How can I see display better in sunlight?
Viewing screens that make use of "back lights" (LEDs, fluorescent, etc) to see / read the display in direct sunlight is often very difficult. Increasing the back lighting level is one method - but even when at 100% brightness, it is hard to overcome the sun. Shielding the screen from sunlight with your hand, body, etc., is often the only way that works effectively.
Apr 10, 2015 | Cell Phones
Is scratching of hard disk normal? my ASUS laptop does not start ( no display ) and the indicator of hard disk reading is off
The scratching noise is not normal. This hard disk appears to be faulty especially if the hard disk LED does not light up.
Apr 16, 2011 | ASUS K52JKA1 156Inch Versatile...
Display works well but is very hard to read even in the dark.
UNFORTUNATELY THIS IS A COMMON PROBLEM..THEY HAVE 2 SEPARATE LIGHTS IN THESE DISPLAYS AND ONE HAS WENT BAD...UNLESS YOU CAN SOLDER AND FIND THE REPLACEMENT LIGHT BULB THE ALTERNATIVE FIX IS TO REPLACE THE DISPLAY CONTROL ON THE UNIT....PLEASE VOTE...GOOD LUCK TO YOU
Jan 03, 2011 | Microwave Ovens
Lcd display is what seem to be to bright hard to read black info .or the black symbols are very light hard to read with bright orange lighted display thanks Mark
You don't say what device this is on, HOWEVER most thngs have a "contrast" control that will adjust the visibility.
Sometimes they call this a viewing angle control and sometimes it is a small shaft from the back of a unit, OTHER times it is a setting available through a menu... if you can read the display enough to find it...
Oct 12, 2010 | Music
Display is really light
there's no way to adjust the contrast on the TI-30XA unfortunately. you can try changing the batteries but beyond that, there's not much you can do.
Jan 20, 2010 | Texas Instruments TI-30XA Calculator
Numbers are too light ery hard to see
Try increasing the contrast. Press [2nd], and the [up] cursor. [2nd], [down] lowers the contrast.
If you set the contrast to maximum, and it is still too light to read, then you most likely have either weak batteries, or a problem with your display. Good luck.
Dec 29, 2009 | Texas Instruments TI-85 Calculator
Center information display hard to read
HI,I SUGGEST YOU SEND THE CLUSTER IN TO HAVE THE DISPLAY CHANGED AS THE LCD IS FAULTY,OR GET ANOTHER CLUSTER AND CODE IT TO THE VEHICLE.
Mar 14, 2009 | 1999 Audi A6
HP Photosmart C5280 Printer Logo
Ben Johnson
