Question about Vacuums
I have a SMC model # OJ44V ceiling fan how do you remove the bottom glass globe to replace the light bulb ?
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: I bought a ceiling fan
If this is a new product and it is defective, take it back to Lowe's and insist on a replacement, talk to the manager if you have to. This site will only advise you on how to fix it.
Posted on Mar 06, 2008
  • 7 Answers
SOURCE: Good morning. My elderly
The globe should be screwed in place by about a quarter turn
Posted on Jan 17, 2011
sean1dave
  • 7 Answers
SOURCE: Need white translucent globe for
I believe Harbor Breeze is sold through the Home Depot. Any well stocked Home Improvement store will carry a great selection of replacement globes for your light.
Posted on Mar 07, 2011
Replace sharp vacum headlight
The light bulb on the sharp upright vacuum is accessed by removing the bottom rug plate. Once that has been removed I believe there is two screws to remove and the light bulb and socket will pull out through the bottom.
Dec 29, 2012 | Sharp Upright Vacuum Model 2807, 2809,...
The light on a fan is flickering. It doesn't appear to be the light bulbs. This fan has a remote control and it controls the fan OK and turns the light on and off but it flickers. What could be...
Try changing or testing the batteries in the remote or take the remote out of the fans range. See if this stops the flickering. It can also be the individual bulb. Sometimes the monofillament wires become loosened. It won't hurt the fan to use a broken bulb but it will shorten the life of the bulb. They do get the daylights shook out of them! If all the bulbs flicker it can be the twist connects. These are located under the ceiling plate cover. To check, shut off the fan or turn off the braker switch to make sure you don't get a shock (but I really doubt it). Remove the face plate ceiling screws to expose the wiring. There should be a black and a red cap that holds wires together. Black is ground red is power. One at a time hold the wires of the black cap with one hand and give the cap a gentle clockwise twist with your other hand to see if they need tightening. Repeat with the other colored cap. Push the wires back up inside the housing if needed and replace the cover.
These are the simpelist things to try before calling an expert. I hope this helps?
Sep 22, 2011 | Vacuums
Hello I have a hapton bay flush mount ceiling light fixture. The bulbs broke and I would like to replace them, however I seem to can open the fixture. It does not have a screw. Please help me. Ingrid
Hello, W/D here.
Try pulling (firmly, but not too hard) straight down. Most fixtures without screws holding them on will have a spring clip inside the globe to hold it to the fixture.
Best regards, --W/D--
Apr 03, 2011 | Vacuums
Light bulb will not screw all the way into the ceiling fan socket. It is a new socket and has not been damaged. Is there any lubricant that I might use to solve this issue? What other advise can you...
An auto store will have dielectric grease. Put a little on the threads of your new bulb and it will be easier to remove in the future, too.
Gary
Mar 08, 2011 | Vacuums
Need white translucent globe for Harbor Breeze Ceiling Fan to cover light. Globe fits to fan base with 6-1/4" Inside diameter mounting ring and is secured with three thumb screws.
Mar 07, 2011 | Vacuums
My hunter ceiling fan is not working and according to hunter technical support, I need to replace the remote control receiver (part # 8511204000) at a cost of 50.00 plus shipping.is there a way to by-pass...
If the product did not come with a manual control on it then yes you will have to use the remote. However, if the replacement remote will cost nearly as much as the ceiling fan itself you could simply purchase a new fan.
Feb 28, 2011 | Vacuums
I have a model 484 709 UPC 792145330547 The fan/light is close to ceiling (instalation). Their is supposed to be an "o" ring to remove the fan/light from the celling. I cannot find it!!! ...
Remove the cowl at the ceiling by removing the screws in the cowl (very close to the ceiling). Use caution in removing them as the weight of the fan may be carried by these screws. Depending on the style, though, the weight may be borne by supports beneath the cowl. Either way, this will get you access to the wiring, allowing you to change out/remove the fan. If the fan and cowl are together, and close to the ceiling, there is usually a method of hanging the assembly while the wiring connections are made during installation. Look for a hook that the screw hole will go over, supporting the fan.
Best regards,
--W/D--
Jan 19, 2011 | Vacuums
I bought a ceiling fan from lowe's, got it home got ceiling fan up in the bathroom, when we put in the light one of the halogen bulbs does not work , also two of the cobalt blue glass covers are cracked...
Mar 05, 2008 | Vacuums
Vacuums Logo
574 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
