Question about Refrigerators
Have a hotpoint FFA97 fridge freezer the freezer is ok but the fridge is not getting cold but still says 2degrees on the display
  • 3 more comments
  • Anonymous Jul 31, 2008
    FFA 97 Fan not working but replaced the fan and still not working! Not found a solution yet.
  • darrenn Aug 23, 2008
    having the same problem but have not changed fan yet, was going to try next, have already turned appliance off for 8 hours and put back on no change, freezer over freezing and fridge not cooling.
  • UmPixie Oct 19, 2008
    same problem no solution found yet
  • Anonymous May 17, 2009
    Having the same problem as the others. Freezer works fine but fridge is not cooling. Not a very good product from hotpoint as its only 2 1/2 years old.
  • Anonymous May 18, 2009
    Have had endless problems with this 3year old fridge freezer for over 6 months.
    Have been in contact with insurers who have negotiated a replacement.
    Rubbish product
Hi ive had the same problem and solved it thank god !!! it happend to me about three times tll i sussed it.well here goes disconect from the mains defrost then you have to empty the freezer and remove the large plastic cooling panel at the back thers about 10 torque screws to undo. then you have to carefully remove the silver foil strip along the back of the cooling finns,the problem is that the ice on the fins builds up over time and collects on the strip and clogs the whole thing up. its been over a year and no problems since then and the fridge is as cold as ever good luck, will.
Posted on May 22, 2011
This model is one of the worst that Hotpoint has made in their history.
I got mine and the first time it failed 11 months after bought.  Call out warranty, technician arrive and replace main controller board.  Six months later, failed again.  Defrost it and started working.  A year later it failed again, the recirculation duct from the freedge to the freezer, gets blocked by ice.  There is something wrong with the defrost system.  My next move before buying a new one will be to replace the defrost switch.
Not recommend to anybody.
Posted on May 31, 2009
I had the same problem. I recommend recycling the thing, researching the available models in your price range and buying a repalcement.
Posted on Dec 28, 2009
Got a hotpoint ff72 fridge freezer and the fridge is not working, light still comes on but fridge is warm. freezer is ok
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | Hotpoint Refrigerators
My hotpoint side by side hss25gfpaww is not cooling on the fridge side but the freezer seems ok. Fridge not getting cold
heatman101
May 03, 2011 | Hotpoint HSS25GFP Side by Side...
Ffa97 problems why is fridge compartment is freezing any food that is at the back
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 27, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
Got a hotpoint ffa97, freezer was still cold and no alarm had gone off to say that that there had been a power cut yet the fridge temp had risen enough to curdle milk??\r\ntemp gauge was still showing...
Milk can sometimes curdle in a working fridge. But it does sound like your defrost system may be malfunctioning. Can you empty your freezer and inspect the defrost system behind the air circulator fan?
I know that defrost elements sometimes go bad and the controllers can pop too. You should check your operators manual and see how to put the fridge into manual defrost. *(it usually involves turning the fridge light on and off by hand. See if the freezer drains during manual defrost. If you have lots of food that dries out in a frost free unit the moisture contains a lot of contaminants that can plug the defrost drain. Which leads to a blocked air passage between the freezer and fridge sides.
You might want to get a small backup fridge for a while to run this down.
Or just use up the food in your fridge before running the tests.
Good luck and be careful.
Jun 28, 2010 | Hotpoint Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint ffa97p - the fridge is too cold and not responding to temperature changing
I'm assuming you're meaning that you reset the "cold control" in the refrigerator area and it is not responding. Try resetting the T stat in the freezer to between 2 1/2 and 3 1/2 and see if the unit continues to run on. If I have this the other way around, set the "cold control" the same as the T stat. The "cold control" is just a flapper door, it doesn't control the compressor only the T stat in the freezer does..
If the T stat is set as I said and the unit just keeps on running and never shuts down except to defrost, the T stat is bad and needs replaced.
There is a chance that the flapper door in the "cold control" is stuck wide open. Removing the cover and inspecting it might tell you if that's happening.
Jul 09, 2009 | Hotpoint Refrigerators
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Hotpoint FFA97 freezer works but fridge does not
It seems to me that there is a leak of gas from your unit.This is if you have 1 compressor/motor)If there is two compressors on unit then it can be thermostat for fridge.Anyhow check if motor is running all the time and is wery hot, if it is there is to little gas in system .This should be covered by guarantee.Jan
Feb 13, 2009 | Freezers
Refrigerators Logo
1,129 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
