I cannot connect the cable, it was working with satellite but i cannot change it and it is not working now.
    Genius:
  • 1,126 Answers
Go to the menu and pick what type signal you are using and the auto problem and it should work fine.
Posted on Jan 04, 2011
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
My blu ray and regular DVD player have sound coming through the tv, but the tv itself on a regular chanel like ESPN, there is no sound. This is a Mitsubishi 73" DLP.
You have completed the proper troubleshooting, and by process of elimination you have determined that there is nothing wrong with your television's sound. The problem lies in cable. The next troubleshooting steps depend upon how you receive your cable channels. If you have a cable box (or a satellite receiver) you may just need to unplug it for 30 seconds to reboot it (or follow the instructions from a cable/satellite company representative on how to properly reboot your particular cable box/satellite receiver model). Also commonly the cable box/satellite receiver is not set to output audio properly. If you are connecting it to the television with an hdmi cable the audio output must be set to hdmi. Also there may be a setting pcm or bitstream. The cable box audio setting normally would have to be changed to pcm.The problem may be with the cable box/satellite receiver itself needing to be replaced or the cable cord connecting it to the television may need to be replaced. It is less likely that the television has a setting the one source input the cable box/satellite receiver is connected to that would affect the sound but confirm that there is or isn't. Last there may be something wrong with the source input you have the cable box/satellite tv receiver connected to.
If you do not have a cable box/satellite tv receiver then rescan your channels, try a different cable cord, and check with the cable company to make sure there is no internal issue at the moment.
May 11, 2011 | Televison & Video
How do you change the 480i to the 720p using the remote
That isn't how resolution works. The resolution is changed in the cable box or satellite tv receiver. The television automatically displays the resolution once it has been changed on the cable box or satellite tv receiver. If you are on input tv on the Sharp television then it will not display any other resolution besides 480i if you have a cable box or satellite tv receiver. If you are not connected to a cable box or satellite tv receiver and you are on input tv then the resolution will differ from channel to channel.
Feb 10, 2011 | Sharp LC-42D43U 42 in. LCD HDTV
I just purchased a new RCA 32 inch w/ DVD. When starting up it asks if you will use Cable or Air. I have Dish Satellite and picked air. I only get one channel and if I try to go up or down channels I get a...
You should not have had to choose cable or air. When you have satellite it is considered the same thing as cable. Air is over the air rabbit ears antenna free programming. When you are connecting a satellite receiver you only have to turn to channel 3 or pick the correct av, component or hdmi input. Oh you must be connecting more than one television to the same satellite receiver. When that is the case tv #2 usually has to be set on a different channel and the satellite tv company tells you which channel. You still use the satellite remote to change channels and leave this television on one channel at all times. This television is good enough for its own hd satellite receiver connected with component cables or an hdmi cable though in order for you to see its full potential for displaying hd programs.
Jan 07, 2011 | RCA L32HD31 32 in. LCD HDTV
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
Audio display flashes in and out in the upper right corner
This usually happens when you are connecting a cable box or satellite tv box to the television with a coaxial cable. In order to get this to stop you have to connect the cable box or satellite tv box to the television with an RCA/composite cable. Then you will have to change inputs to the appropriate one with the input button on the television (press it repeatedly) or with the input button on the Sharp remote (press is and then scroll down with the down arrow and press enter).
If you are not using a cable box or satellite tv receiver you can try connecting a signal booster to your coaxial cable but that is not guaranteed to work.
Jul 13, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No signal onthe screen
If you are connected to a high definition cable box or satellite tv box you would not need to turn to channel 3 on your television. The television would need to be in the right input either component or hdmi. If someone connected the tv to the cable box or satellite tv box with a coax cable like an antenna cable then the tv channels will be available on channel 3 as well but they will not display in high definition. You change channels with the cable box/satellite tv box remote control. If the above is not correct and you are only connected to an antenna cable and not to a cable box or satellite tv box you will need to complete a channel search from the tv menu. It sounds like you are using a cable box/satellite tv box and that the tv is on the wrong input. If the cable box/satellite tv box is not working (i.e. just a black screen) on your television than that is a different matter entirely.
May 10, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
I need help! Our cable jack on our tv is messed up so we have to run it through a dvd/vhs player. I have tried everything to get it to work. I can play dvds and see them, but i cant get the satellite to...
Change the source on the Philips/Magnavox to switch between satellite and movies (warning: this particular Philips/Mag cannot process HD Satellite receiver boxes). You can switch sources by using the Magnavox remote and pressing 0-2. Then press ch down until the display says either L1 or L2 - whichever input the satellite is connected to. Another warning: For my instructions to work, you must have a non-HD satellite receiver, and you must run a red, white and yellow cable from the satellite box to the Magnavox instead of a standard coaxial cable wire (and then, of course, run a second set of red, white and yellow cables from the Magnavox to your TV).
-Tha Mp3 Doctor
Dec 31, 2008 | Philips Magnavox DVD/VCR Dual Player
How do I install a channel to receive satellite programmes? My model is LE19R8
If you have a satellite and it is connected with coaxial cable put the set to channell 3 or 4. If the satellite is connected with RCA cableput the set on that source the cable are connected to. No need to program the set. Use the cable remote to change the channels just use the tv remote to turn the set on and off and for volume.
Aug 19, 2008 | Televison & Video
Satelitte to Cable-TV wont work
Check your satellite output. Maybe you change the option in the out.
Jan 28, 2008 | Hitachi 50HDX60 50 in. Plasma Television
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
