Question about Sunbeam 30Pint Dehumidifier
After emptying the reservoir , when we put the reservoir back in the power light keeps flashing on and off. Tried unplugging it and plugging it back in , but the power light keeps flashing and we cannot start the fan in either speed. There is no lights on the center display , except when we remove the trap it says "P2". Any ideas ? Thanks.
  • rbaase Jan 04, 2011
    I have moved this switch that is activated by a float in the bucket to both positions when the bucket is out and I get the same results. So it sounds like the switch is bad then, correct ? If that's the case , how hard is that to change , roughly how much would it be and do you know where I could get one ? Thanks.
  • Sunbeam Master
  • 43,501 Answers
There is a switch that will keep the unit from running if the bucket is out...this switch is either broken or for some reason is not being help in properly...if you can figure out where it is then hold it in by hand and then try to run the unit... if the unit runs then the switch is good and the bucket is not pushing it to the proper position...then fix that...
heatman101
Posted on Jan 04, 2011
  • D. Floyd Kolb
    D. Floyd Kolb Jan 04, 2011
    That is probably not that hard to fix and you can easily buy the parts yourself online...
    Here is a tip that will help you with the online buying...
    How to Buy
    Appliance Parts Online
    heatman101
    How to Buy
    heatman101
Not running- CH 24 code on the Humidity setting & empty bucket red light flashing even though bucket is empty and in place correctly
If the bucket is in place correctly, turn the unit OFF & unplug it for 10 minutes. This should allow the electronics to rest and revert back to the original factory setting after you plug it back in and turn it ON. From there you should be able reset the controls to your liking.
Hope this helped. Thanks for choosing FixYa.
Aug 22, 2011 | LG Dehumidifiers
My dehumidifier says the bucket is full, when it is empty. the red light flashes and it beeps. I can't get any buttons to work. I have taken the bucket in and out several times. Any suggestions? It did...
First, the unit may need to be cleaned and after that, unit may need to be reset. Turn the Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. Then plug it back in and turn the Master ON/OFF Switch to ON. Set the controls as you normally do. Hopefully, that 12 - 15 minute timeout, allowed the electronics to reset themselves. If this continues to occur frequently, contact an authorized Frigidaire Service Center
Hope this helps you troubleshoot and solve the problem.
May 02, 2011 | Frigidaire FDF70S Dehumidifier
Unit wont run but lights up. It reads low humidity even though its high
First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted. Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them. If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
Good luck.
Aug 13, 2010 | Haier HD656E Dehumidifier
Wont run. E2 on screen. about three years old
I hope this helps.
Take care.
Aug 12, 2010 | Haier Dehumidifiers
Light saying bucket is full is on all the time and unit is not working
Good luck.
Jul 28, 2010 | Kenmore 54501 Dehumidifier
Keeps flashing bucket full and there is no water in the bucket.
water is not draining into the reservoir an thats why it keeps on blinking so clean out the drain assembly an treat with bleach ,,,,
May 24, 2010 | LG DH504E GoldStar Dehumidifier
The pump doesnt work
I just fixed the same problem on my DE-500P. The pump filter was blocked and there was a layer of scummy lint-like stuff in the bottom of the pump reservoir (not the main - or overflow tank) also blocking flow down through the filter to the pump. The line you tried to plug is probably the vent line for the pump reservoir. It attaches to a fitting on the removable tank side of the bulkhead. Unstop the vent. Repair steps are as follows:
1. Remove the overflow water tank and the two side covers (five screws in each). Note that as you go through the removal of all the covers and other procedures, there are two lengths of screws; don't switch them. If you lose track, the rule of thumb is use the short screws for going through a single layer of plastic into metal.
2. Remove the rear cover (take out the screws along the bottom and on the sides). It will still be attached to the front top cover at the top with tab fasteners. Gently pull out the bottom of the cover while depressing the top of it on both sides with your thumbs (about an inch and a half inside the trim ridges) to clear the tabs. Ease the top part of the cover back and remove it (it will have to tilt to one side, don't forget this when putting it back on).
3. Remove the top cover, not forgetting the two screws on top by where the back cover attached (go gently, there's a wiring harness) and turn it to the side. There was enough slack to leave the wires connected; just be careful to not damage them.
4. The filter looks like a small transparent in-line gas filter. Remove the pump filter, leaving the short tube attached to the top of it. I quickly atttached a length of tubing to drain the reservoir into a bucket. I couldn't find a replacement filter, so I filed a slot in the side of the bottom half of it to remove the gunk using the wire from a twist tie (the upper half had some tabs inside that would have been in the way). Afterwards, I wrapped it tightly with stretchy electrical tape and put a cable tie over the tape at the slot to keep the tape from being able to creep loose over time. Don't use a fuel filter, the paper element is too fine (you need a screen) and the paper will fall apart in water.
4. Remove the float and bracket from the pump reservoir. The reservoir screws are not all apparent; there's also a screw way over on the left and one coming in from the right. I used a 12 inch #2 phillips screwdriver with a magnetized tip for most of this. Remove the pump reservoir and clean out the scummy stuff in the bottom and where the tubes attach. When removing the reservoir, you'll have to detach the vent line that goes through the bulkhead to where the big tank was and pull the tab above it down slightly while easing the tank out.
5. Clean out any dirty tubes, paying particular attention to the coupling for the drain hose and the long drain hose itself.
6. Put the reservoir back in and hook up all the tubes and filter. It does make a difference in which direction the filter goes back in. You want the water from the reservoir to go through the filter from the outside of the little screen; that leaves the maximum room for crud build-up before it plugs up the screen again. Newer ones have a flow direction arrow; point it away from the reservoir.
7. Depending on your confidence level, at this point you may want to plug in the dehumidfier, put the overflow tank in, turn it on, turn on the pump, and fill the pump reservoir to check for functioning and leaks. If you do this, just remember that the circuits are hot and not all are insulated.
8. If all is OK, unplug the dehumidifier and put the covers back on. Total time was about an hour.
Jun 01, 2008 | DeLonghi DE500 Dehumidifier
Sunbeam 30Pint Dehumidifier Logo
53 people viewed this question
Top Sunbeam Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Sunbeam Dehumidifier Expert? Answer questions, earn points and help others
