Question about Xerox Office Equipment & Supplies
I have a xerox 5028 copier and it has a paper jam at the end where it is supposed to come out. What causes this problem and how do I fix it?
    Scholar:
  • 136 Answers
Ok shut off copier, Wait for it too cool down for 30 minutes, then remove the two brass screws, After you remove the web assembly, I like you to look for grooves on the Orange Fuser Roller.
After you do that call a tech company or a copier company that repairs these units if your unable to find anyone. We are in Connecticut,Copiers Plus Worldwide,LLC is whom we are I worked on over 3 units of these and it can be an easy if, if you attept to remove the fuser make sure the connector isn't melted it will be had to remove. I also carry A Brand New Copy Cartridge for this unit selling it cheap call us we can help
Posted on Dec 07, 2009
Chances are your paper had some moisture in it and when the heat was applied to it it curled up before it exited and got jammed.Make sure you turn machine off and unplug it.Let it cool for about 30 minutes. Open the clamshell you will need a phillips screwdriver to take off 2 gold screws that hold down the web assembly .When you have the two screws out lift the web assembly out you will see the paper inside folded up like an accordion .Check the teflon coated feelers that ride on the lower roller which applies the pressure one or more could be bent back getting in the way of the paper as it tries to exit
Posted on Apr 23, 2009
    President:
  • 2,072 Answers
Shut it off for about 45 minutes to let it cool down. The remove the 2 brass screws from the black area on top the fuser. Remove the web assembly and you will see one of the flat stripper fingers bent down blocking the paper path. Just flip it back in place.
Posted on Jul 09, 2008
I have a Fuji Xerox 525a colour laser printer which is giving a phantom paper jam message (error message indicates paper jam in cover E, but it is clear) What can I do to clear this message as it...
I beleive there are only two paper sensors for that machine.
1- in the tray there is a paper empty sensor which hangs down,
make sure you take out the tray and look for any pieces of paper stuck.
2- open right door and look as if your looking inside to where the paper is supposed to end up. The sensor is in that black unit, is there any paper there, can you see a black lever, if you pull on it gently and let go does it snap back in place?
Jun 21, 2008 | Fuji Office Equipment & Supplies
Xerox Workcentre 4150. Paper keeps jamming in print engine area. We clear the jam and it jams again.
If your Xerox WC 4150 is displaying "Clear the Jam in the Print Engine" or constantly jams as paper exits the machine you should check and possibly replace the fuser actuator (part# 120N00534) This is the most likely cause, if however this does not fix the printer the next step may be to replace the sensor or fuser.
Here is a video that shows you how to check and replace the actuator. ItemInc.com has this part in stock and ships same day. Good luck, and thanks for using FixYa!
Jun 23, 2011 | Xerox WorkCentre 4150 Black and White...
Xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Take care
Jul 19, 2010 | Xerox WorkCentre M15i Laser Printer
Xerox m15i copier guide broken
This sounds like the paper path guide that sends the copy by the drum modual and then to the fuser.
If the walls are stained yellow, they the "vains" plastic guides are broken and will cause paper jams. Also after the paper has been fed out of the fuser modual there are other plastic guides that might appear to be yellow in stains. these tips often break and will cause constant jams.
The door guide has to be replaces and the vertical transport may need replacing as well. You would need to get part numbers for this specific model and someone who knows how to dissasemble this machine.
End result, you may need to call Xerox for assistance.
Good luck.
Oct 16, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox M15i paper gets jammed above the fuser "paper jam 2" fuser is hot but i think its supposed to be. Almost every sheet gets jammed.
Yes it is supposed to be hot. Let is sit off for an hour.
Open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
Sep 29, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox XC830 Copier--Paper jams as it is leaving the copier
Inside the copier on the rear side where the gears are you'll find the gear on the fixing roller is broken. You can call Sharp instead of Xerox because there are usually cheaper. The supplies are not interchangeable, but the parts are.
Good luck
Apr 03, 2009 | Xerox DocuColor 12 Color Copier
XEROX 5328
That is an exit Jam code in the fuser.
You may just have one of the fingers bent straight down blocking the paper.
There also may be a secondary code that is causing the E-4-0.
But that is where to start. Look under the exit web cover for a piece of paper crumpled in that area.
Once there you may have to remove the fiser web cover to remove that jam and straighten out the finger.
MAKE SURE IF YOU GO INTO THAT AREA TO UNPLUG THE MACHINE.
Dec 07, 2007 | Office Equipment & Supplies
150 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
