Question about Music
I got a pretty good deal on a digitech RP7. The only problem is that its missing one of the four switch covers (pitch). can you tell me where I coul find one? thanks,
  • Music Master
  • 5,603 Answers
Such a special part will require going to Digitech, support, and parts. The part should be fairly inexpensive.
Posted on Jan 04, 2011
Digitech 256 manual
This manual is Not available, The 256xl is ? I think if you contact the company they can help you, I have contacted them in the past threw this link.... http://digitech.com/en-US/support
Feb 22, 2015 | DIGITECH Music
Digitech Manual qm-1320
I wish I learned how to play more instruments. I have been thinking about going into a college band to learn more. I am pretty good at brass instruments.
May 14, 2013 | Music
I need to know how to restore factory settings on digitech RP RP-90
Here is the link to your manual if you don't have one:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP90/RP90Manual18_0490_A.pdf Page 34 tells you how and don't forget to calibrate the expression pedal. Page 35 tells you how. Hope this helped.
Nov 09, 2010 | Music
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Radio switches off automatically every five minutes
Press the power button repeatedly as you turn it on to set the snooze mode, or change back to perpetually on.
Apr 19, 2010 | Digi-Tech Digitech Vocalist Live 4...
I NEED TAN ELECTRONIC SCHEMATIC
Here is a link to the manual:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP1000/RP1000%20manual%2018-0597-A.pdf It is highly unlikely that you will find a schematic unless you know a service tech for a music store that deals Digitech. Also you will need some specialized tools. Here is their contact info:http://www.digitech.com/dealers/service_lookup.php If you are a tech you can always contact them.
Apr 07, 2010 | Music
My digitech vocalist 2 is extemely noisy! the ground switch helps only partly. It seems to be bad when you first turn it on and gets worse the longer you use it.
To check for a temperature related problem, try putting it in the freezer for a while then bring it out and see if it affects the noise. If it does, then problem can be found with circuit cooler mist.
Also see if noise is affected by vibration.
Sep 09, 2009 | DIGITECH VOCALIST LIVE 2
Digitech RP 90 foot switch is not working
I removed the back cover, unscrewed the two (of 4) screws holding down the circuit board, replaced them again, and it worked fine.
Jan 11, 2009 | Music
Music Logo
155 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
