Question about GE JVM1850 1000 Watts Microwave Oven
When you press start the microwave starts with a low hum and sounds like a bearing or fan is vibrating, micrwave still heats up and works just runs rough. Bruce
  • 591 Answers
Ther is a loose peace of metal in the magnetron, it is not a big worry, it's just noisy, i have a noisy microwave and it is working fine for 10 years now, if you use the defrosting mode you should hear the noise (on and off) because in the defrost mode the magnetron energises on and off, it could be the cabinet vibrating as well look for loose peaces of metal
Posted on Jan 04, 2011
Microwave has power will not start
When you say it just hums, do you mean that it sounds like it is running but isn't heating? Or do you mean that the sound is different from when it normally runs? Is it quieter or noisier than normal? Do you hear the fan running or is that sound missing?
IF it sounds normal (or about the same as when it worked), but it's nust not heating, then it is probably a bad magnetron tube.
Aug 18, 2014 | Whirlpool Microwave Ovens
GE microwave JE1660WB001 does not heat makes humming sound
The magnetron has gone and is the heart of the microwave oven, this part is the most expensive to replace, cheaper to buy new in the long run.
Apr 19, 2012 | GE JE1660 Microwave Oven
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Microwave will not heat
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
 Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Vibration sound
There are two possible sources; the fan, which may have a loose sleeve bearing (fan must be replaced), or a transformer with loose laminations. The latter is a rare occurrance since most transformers are 'potted' or treated with epoxy resin.
After pulling the plug, the housing will be fairly easy to remove with a half-dozen or so screws around the edge of the back panel.
If the fan is then accessible, you could block the blades with any insultating material and briefly turn the unit on. Keep fingers clear of ANY part inside; danger of electrocution. If the vibration is missing, then the fan is at fault.
Jan 14, 2009 | Sharp R-1480 Microwave Oven
Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
Maytag Over the oven microwave
is the turntable working
Dec 29, 2007 | Microwave Ovens
Microwave not heating.
check magnetron related circuit and replace magneron, check condencer, diode and etc.,
Oct 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
298 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
