Question about Disney Ramone DVD Player
Can't turn up volume enough on Motorola V3i RAZR
I have Motorola V3i RAZR and I can't get the volume turned up enough to hear unless I am in a very quiet surroundings.
Movies will play fine however the music is at normal volume and the voices are very quiet. To hear them you can turn it up but then music is too loud.
This might be your TV many of the SONY and PHILIPS TV's have an Auto Volume control setting that is used to prevent the TV advert music from being too loud compared to the programs try turning this ON and OFF and see if it helps.
Jun 16, 2010 | Toshiba SD-2150 DVD Player
How can I turn up the volume? We maxed out the
There maybe a mute button on the remote some where, or else its just the case that these portable dvd players have rubbish speakers built in and they are just not loud... I recommend getting a decent pair of amplified computer speakers and plugging them into the headphone socket. That is what i do!
Apr 05, 2010 | Audiovox PVS72901 Portable DVD Player
Very low audio sound from recorded dvd
Could be the way it's connected, scart leads are good at causing problems! Does the box have a volume control? If so turn it up and leave it alone then. If you need to adjust the sound when watching use only the TV volume control.
Apr 05, 2010 | Televison & Video
I have BOSE speakers plugged into a small lcd tv. when the tv is off, I'm still hearing cable audio. why? i'll clarify. my tv has rca jacks connecting it to a couple of small bose speakers. sounds...
Your TV output is a pass-thru from the coax cable then. The only solution- turn the volume down, or unplug them.. Or get a cable box. A VCR may work as a temporary cable box, and if you have a remote for it, you should be able to just turn off the audio at any time with a VCR remote. (unless the VCR also has a pass-thru only audio output)
May 25, 2009 | Audiovox DVD Player FPE1505DV
We are having trouble witholumne play back wheen tv is up full blast and
check cables get new ones. and check the DVD volume is up
Apr 13, 2009 | Televison & Video
Volume is not working
get a splitter that allows you to plug 2 sets of headphones in the portable dvd player.
The sound is the only place were this machine falls short. The sound is okay at best with the built in speakers, but any background noise makes it nearly impossible to hear anything from them even with the volume all the way up. Not surprising since due to the size of the player the speakers are only a little bigger then headphone speakers, but with headphones or portable plug-in speakers the sound is superb. Besides the sound the only 2 complaints are that you can not control the volume with the remote and that the power switch is too easily turned on by accident (do not travel with the battery attached or you will find you have no charge when it comes time to watch a movie). The battery lasts 3.5 to 4 hours, long enough for 2 short movies or 1 long one.
also checkout The volume button is on the right side of the uint.
, headphones are a must, or get a device to play the audio through your car stereo ($15-$25). The player has the option to either input or output the A/V so you could play video games on the run or you could hook up a VCR and watch VHS...be creative
Apr 01, 2009 | Shinco SDP-1850 Portable DVD Player
What happened to our computer?i can't hear any sound?
turn the sound back with volume or with volume control in enterainment panel
Feb 21, 2009 | Audiovox D1708 Portable DVD Player
Disney Ramone DVD Player Logo
97 people viewed this question
Top Disney Televison & Video Experts
sonic boom...
sonic boom...
Iron
Iron
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
