Question about Maisto Rock-crawler Remote Control 4wd Truck
Just bought this truck this evening, got it home, put brand new batteries in it, and it wont go unless you have the controller right next to it, and then it will go 2 ft away and stop. Have tried all different channels and going outside away from possible interference. So now what?
    Problem Solver:
  • 3 Answers
Sounds like you got what I call a defective one. I usually return for a replacement when possible. We got a couple of these trucks for the kids at Christmas. We ended up having to send one back (defective) b/c the wheel alignment tab was missing so the truck wouldn't go straight. The other one only started acting up after my son played in the water with it. But at first they both worked funny until we put the antenna, the one that's on the truck, into a plastic tube to hold it up straight. Don't know if yours has that or not, but our tube was in the bag with the instructions. Good luck!
Posted on Jan 04, 2011
Put a brand new battery in 2000 bonneville and still wont turn over
Alternator and starter solenoid. Pontiac has fuse links built in to the wiring harness. One is near the alternator, another in the big red wire going to the fuse panel. If the dome light comes on then the fuse links are good so look at the starter.
Feb 22, 2014 | Centric 2000 Pontiac Bonneville - SLE -...
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
Truck wont crank over
auto shutoff relay or fuel control to the injector pump from the ignition switch..be checking the batteries for connection(or burnt thru solenoid because ecessive cranking will burn these up with all the amperage required to spin a diesel...)
Dec 21, 2013 | 2002 Ford F350 Super Duty DRW Reg. Cab
I have a 2002 pontiac Aztek. In cold weather it wont crank unless I put it on a battery charger. I bought a new battery and the same thing happened.Put the old battery in after cleaning the neg.cable(was...
Has your alternator belt broken or alternator not charging the batteries? Check amps output from the alternator aswell it maybe undercharging them. Make sure all battery connections and earths are clean and their mounting points are clean. Is it the correct battery for the car?
Dec 17, 2013 | 2001 Pontiac Aztek
My alternator keeps going out
The voltage regulator isn't being turned on when it is need
The challenge it to look at wiring diagrams & see what controls it
Jumping a dead battery is a dangerous thing to do
Batteries require they be fully charged before being put
back into service- to continue any testing
If you even jump a car made in the last decade,
you may smoke the electronics
On newer cars you disconnect the battery, to charge
it alone from the vehicles systems
Mar 13, 2013 | 1983 Dodge Ramcharger
Wont turn on unless you take battery out and put it back in.
I hate even suggesting this but, I ran into the same problem with a Canon Elan IIe film camera. The Canon batteries were getting expensive so i bought off brand at the local Costco store. Same battery same voltage but 1/4 the price. What I did to fix the problem was put a single small strip of masking tape on the bottom of the battery closed the battery compartment door and everything worked as it should until I need to replace the battery again.
Dec 13, 2010 | Canon EOS Digital Rebel XS / 1000D Body...
89 Honda Prelude SI- Wont start
sounds like your on the rite track . clean the contacts at the batt and at the starter and get back to me
Feb 19, 2009 | 1990 Honda Prelude
No Power
did you make sure you have a memory card in the camera, i know with mine it wont power up unless there is a card in it.
Jun 17, 2008 | Fuji FinePix S5000 Digital Camera
I had the same problem with both red lights going on..............
dear dan,
in many cases from my experience is Even brand new things have away of not always working right or being built all correctly my two suggestions for u is to take the radio back which at this point of replying may be to late Other way of doing this is if u got a local cb repair shop take it there and have then look at it.
Apr 04, 2008 | Uniden Bearcat Pro PC78LTW 40-Channels...
Maisto Rock-crawler Remote Control 4wd Truck Logo
272 people viewed this question
Top Maisto Toys Experts
ray gallant
Mai Lor
17 SOUTH INDUSTRIES
17 SOUTH INDUSTRIES
Are you a Maisto Toy Expert? Answer questions, earn points and help others
