Question about Kenmore 24 in. 16532 - Multiple Color Built-in Dishwasher
Hello I have a kenmore classic model number 110713601 and it pumps water to it and it sounds like it on but its now bring water into the dishwasher hope you can solve it thanks for you time
  • 1073 Answers
SOURCE: kenmore dishwasher makes grinding noise while draining
disassemble the top of the dishwasher pump, remove the bottom spray arm and remove the screws on the top of the pump housing this will get you started
Posted on May 03, 2008
SOURCE: Kenmore dishwasher limited edition model 665
Anyone know anything about heating elements, mine won't dry the dishes, thanks
Posted on Jul 18, 2008
SOURCE: kenmore ultra wash II model no. 1691190
YOUR MAN WAS OF ABSOLUTLY NO HELP IN SOLVING MY PROBLEM. I ENDED UP CALLING SEARS AND THEY SENT A TECH OUT. YOUR MAN SAID TO TAKE THE DISHWASHER OUT AND TURN IN ON IT'S BACK AND I COULD ACCESS THE PUMP. THE TECH SAID THIS WAS NOT TRUE. YOU CAN ACCESS THE PUMP FROM THE INSIDE OF THE DISHWASHER. IT IS APPARENT TO ME THAT YOUR TECH HAD NO IDEA ABOUT THE MACHINE. AS IT TURNED OUT, THERE WAS NOTHING WRONG WITH THE DISHWASHER. IT HAD A KINK IN THE DISCHARGE HOSE.....P
Posted on Jul 21, 2008
SOURCE: Kenmore dishwasher drainage problems
I have the same model -- and USED to have the same problem! We tried lots of things (bleach in the water, etc.). . . . and finally discovered it was a simple, standard concern. The drain tube from the dishwasher to the sink pipe was clogged with grease (looked like lard).
The way i knew it was clogged is that I disconnected the tube from the sink pipe, and tried to blow through the tube. It wouldn't let any air get through.
So once the dishwasher was empty of water (i removed the tube, drained into a big pan, and bailed a lot), we disconnected both ends of the tube.
With the tube in a trash bucket, I blew from one end (cleaned it off a bit first), and the "lard" came out. Drains beautifully now -- and did not require a plumber.
If you do this, be SURE you place the tube back ON the fittings EXACTLY in the same position and shape as before. This makes there are no new kinks or bends introduced into your drain tube.
Hope this helps.
E-mail if further questions!
Jonathan
Posted on Nov 28, 2008
SOURCE: Kenmore 665.1736 fills with water but does not spray
Take thre drain hose off from disposal. Pour hot water down the hose until full. Cover end with hand. Press cancel/drain while holding hand over hose - over bucket. That may unstick checkvalve balls and or fix air lock. I have to do that every 6 months or so. Started happening 1 month out of warranty. Go figure. Not a fix - just a work-around...
Posted on Jan 17, 2009
Is it possible to get new upper and lower racks for this model - if so what is the cost and how do i order?
Hello Adriana;
My name is Peter. I am a retired field service appliance technician.
The model number you provided does not sound like a model number. Your model number is located on a label on the face of the dishwasher after you open the door or on the side of the door.
Go into the following website and put in your model number. You will get diagrams, part numbers and cost.
Record the part number and search the internet for a better price. Even discontinued items are available on the internet.
Water Filters Lawn Garden Appliance Parts
Mar 23, 2016 | Kenmore Dishwashers
FDB1050remo Making a squeaking sound almost as if a belt slipping. Not overloaded and nothing rubbing on washer blades. My only guess is that it may be related to low water pressure. Is that possible?
please make this test and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 18, 2013 | Dishwashers
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
Why is my dishwasher running without water?
It is likely the sound you are hearing is that of the pump motor which is triggered because the flood switch has been triggered. This means the dishwasher is trying to empty itself to avoid damage likely casued by water leak. You need to find out why the flood switch is triggered. It would be helpful if you provide the model number of the dishwasher.
Jan 12, 2013 | Kenmore Dishwashers
Purchased 2007, Kenmore UltraWash d.w. makes loud buzzing noise that stats about a minute after 'start' and continues most of the time throughout cycle. Think it's the pump? Can't easily get it to be...
Please provide model number of the kenmore dishwasher.
Is there water in the base when the wash is complete? There could be couple of pumps in some Kenmore dishwashers - so hard to know which one until model number is known.
Dec 06, 2010 | Kenmore Dishwashers
Dishwasher not filling with water
Hello.
The humming sound you hear for the water is the sound of the solenoid trying to open with now success. You will need to replace the water valve. If you get the model number and go to www.sears.com and click parts direct it will have a place to enter the model number and order the water valve for your unit.
Jul 22, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore portable dishwasher not working
is the buzz sound when you ask it to drain or ask it to fill with water? or is the buzz sound when it is trying to wash? IF it is when you ask it to drain either you have something stuck in your air gap causeing no drain or there is something in your pump I would check the easy stuff first by checking the air gap this is if it is buzzing when you ask it to drain. let me know what is the senario.
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
Kenmore dishwasher (model 655) not draining
when i attend dishwashers that have lost power to some part, i always check for broken wires inside the door skin, the wire harness inside the door skin gets hot and cracks with use when opening the door all the time after that check the outlet pump which is often a separate part to the main motor, this pump could be faulty electrically
Sep 27, 2007 | Dishwashers
Kenmore dishwasher
fatubu, are you sure you have the correct model number, Im not finding anything on the posted model. They had an issue on models close to this that had an issue with a twisted or missing seal in the pump assy. causing water to fill the pressure switch hose. The dishwasher would drain water after the fill. The fix was to replace the pump and motor assy. Catriver..post back.
Feb 18, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 24 in. 16532 - Multiple Color Built-in Dishwasher Logo
135 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
