Question about Franke Kindred DP2233/90/1 Granite Double Bowl Sink Polar White
How to use the clip attachments for Frank drop in sink,no instructions or pics for clips
    Problem Solver:
  • 18 Answers
Just weight the sink with water after running a bead of caulk under the lip of the sink. Finish the bead of caulk before it skins over and then drain the sink after 24 hours. I personally wouldn't worry about using the clips, the caulk will hold the sink securely, and if you ever need to remove it, allow for a much easier removal.
Feel free to contact me if you have any questions.
Brandon Wiese
Brandon@StoneRepairman.com
http://www.StoneRepairman.com
Posted on Apr 05, 2011
How do you attach the clips for a double sink composite granite sink
if what your speaking of is a sink that's made from 5 pieces of granite , id not suggest you try to use clips to hold it on the bottom of counter top , id suggest you either use Hot glue (works fast) or epoxy (2 PART) either of these would keep you from stesssin the material and it wont snap on you a bucket with shims can be used temp to set it all on (weight ) till epoxy dries
Jan 03, 2017 | Home
My porcclain drop in bathroom sink has no clamp tabs to attach clips to,how to fix
Go to Home Depot and buy some sink screws that go into tab that you attach the screw into the wood and the tab over the underside of sink. They also carry other stuff that works even better.
Apr 29, 2014 | Home
Cutting a new counter top for a sink
If you are installing a basic stainless steel sink into a laminate over particle board counter top-
Find the center of the sink along the legnth of the counter and mark the counter. Measure the sink from the top. Lay out the edges on the counter. Place the sink upside down on the counter and align with your marks. Trace around the sink in pencil. Subtract the distance to the flange where the clips slide in. Draw a new line inside the first one. This is your cut line. Check that when you make the cut that you will not hit the face frame of the cabinet. Move the sink back if needed and make new marks. Some cabinets are a tight fit. Cut the hole for the sink with a jigsaw. Start with the back line first. You may find on a counter with a back splash the jigsaw will not fit. Drill an 1/8" hole to mark the underside and cut from the bottom of the counter. Use a 1" spade bit to drill starter holes at the corners keeping away from the line you traced when the sink was upside down. Stay away from that line or you will have a hole the sink won't cover. Cut the front line. Drill a hole in the center of the counter you can put your finger in to catch the piece when it falls. Now cut the side lines while supporting the counter that is being removed. Discard the slug you removed.
Test fit the sink and remove any extra until the sink just drops in. Remove the sink and set it aside. You need at least 2 sink clips on each side of the sink but use 3 if you can get to them. Determine the location you want the clips at. Use the 3/4" spade bit to drill uot a pocket for the clips to go into. They will normally hit the bottom layer of particle board in the front and back. Center the bit horizontally 3/8" up from the underside of the counter. Drill your holes 1" deep. This is where the spring clip on your sink bolts will grab. You can test that the clips will fit then put a small beed of clear siliconized acrilic latex calk around the edge of the sink and install. Wipe up any extra squeeze out with a wet rag and then tighten the bolts and clean up again.
Now you are ready to install the plumbing. If you are using a new garbage disposer with the dish washer draining into it there is a small plastic disc you have to knock out before the dish washer can drain into the disposal. That plug is there to seal the disposer if you don't have a dish washer.
Get more help if you do not understand all the instructions. If you are pretty handy with mechanical things you should be able to get this done. If you have a different kind of sink please specify that and get more help.
Mar 19, 2014 | Tools & Hardware - Others
Remove cast iron kitchen sink with stainless steel rim and clips underneath
Clips attach to rim and hold sink from below, and rim holds sink from above.
Remove clips and sink will drop down.
Then use putty knife to remove rim from countertop.
New sinks will probably not fit same opening, new sinks are slightly smaller, so measure before removing old sink.
Dec 15, 2012 | Home
How do we install the clips on the bottom of a top mount sink
The clip with the screw together, with the screw head down and the claw up, go into the channel on the underside of the sink, they go through a slot in the channel then slide to fit about 3 or 4 on each side. Tighten up the screw and it should pull the sink down and clamp onto the wood under side of the counter top. Put a bead of siliconized latex caulk around the edge of the sink before dropping it in, DO NOT USE SILICONE!!!, then with a wet rag, clean it off what gurks out. You should be all set.
May 19, 2010 | Home
We cannot get the mounting clips to stay on
I have spent several hours trying to solve the same problem with a Franke Granite double basin sink. The clips for this Franke sink appear to be a piece of engineering garbage, and the instructions are utterly useless - A huge piece of paper with a template, and tiny pictures that look like they were drawn by a kindergartner with a crayon. The instructions for using the clips --oh there are none - other than a blurry picture in which the clips could fit inside this period (.). Lots of other people appear to have the same issue. I like the Franke sink, but without proper mounting hardware, this franke sink is no better than the poorly made clips, and the Franke Sink horrible instructions that it came with.
May 02, 2010 | Franke Work Top Double Bowl Kitchen Sink...
What is the recommended sink mounting clip for a 22x33 sterling by kohler self rimming kitchen sink. I had purchased elkay "u" clips it does not appear that they will work.
Technically, you are suppose to have the clips holding the sink down. However, that is a pretty heavy sink you have. If you apply a clear tub/shower adhesive caulk around the opening for the sink, it will prevent the sink from shifting on you. Sometimes, as an added precaution, I will apply a second coat from underneath the sink after the first application has had time to cure. You will not have any problems in taking this approach to solve your problem. However, if you feel you absolutely need the clips, you can call Kohler to inform them that your sink did not come with these clips. It has been my experience that they will ship the clips out to you at n/c. Hope this helps.
Nov 20, 2009 | Kohler K-5832-4-7 Bakersfield self-rimming...
Installing stainless steel sink with metal clips
if you look at edge of sink you will see small rail the bulbous end of clip goes in rail and flat side of clip goes against under side of countertop you then tighten clip which will pull sink and counter together you should install with plumbers putty around rim
Mar 24, 2009 | Neptune Home
Franke Kindred DP2233/90/1 Granite Double Bowl Sink Polar White Logo
486 people viewed this question
Top Franke Home Experts
Donni Steen
Gil Shultz
Freddy
Are you a Franke Home Expert? Answer questions, earn points and help others
