Question about HP vs19 (Silver) 19" LCD Monitor
Turned my HP VS 19C off and now will not turn on
  • 11,361 Answers
Check the caps and fuse in the power supply section first.
See pictures here:
http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
Hopefully it will not have bad lamp assemblies later on.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 04, 2011
Our car alarm keeps going off. We turn it off and it goes off again in apprx. 5 minutes. We are in a cold climate, it is apprx. -19c right now.
There is an issue with the Body control module in those. Have your dealer check for codes in the bcm.
Feb 21, 2011 | 2011 Kia Sorento
Hp vs 19 e monitor won't turn on
Look at the power supply first; look for burnt parts, bad capacitors, etc.
Please post back what you find
Dec 06, 2009 | HP vs19 19" LCD Monitor
Transducer is mounted on a plastic bracket to trolling motor. when trolling motor is turned on, black vertical lines appear on my screen. lowrance x107 cdf
Are you utilizing another unit in your dash? If so, sometimes when both units are on and in sonar mode, their frequencies will intefere with each other causing the vertical lines. I would suggest turning your dash unit off or lowering it's Hertz rate from 200Hz down to 50Hz.
Funny story...I saw this same issue on my boat years ago. I had an X102C up fron and an LCX-19c in the dash. I acutally thought it was some sort of man-made structure and spent time fishing it...DOH!
Aug 23, 2008 | Lowrance LMS 332c Mapping Sonar/GPS...
Frigidaire FRF170FF Freezer beeping
This is probably the defrost cycle. The beeps are the high temp alarm. It is probably overly sensitive.
Jul 04, 2008 | Freezers
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Lowrance LCX-19C GPS Receiver Problem
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
Mar 15, 2008 | Lowrance LCX-19C GPS Receiver
HP vs 19 Flat Panel LCD Monitor will not turn on.
Find instructions to fix a problem like this here:
http://boredprojects.blogspot.com/2008/06/hp-vs19d-fix.html
It's helped a lot of people so far, hopefully it will help you too.
Oct 11, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP vs19 (Silver) 19" LCD Monitor Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
