Question about Pentair Minimax NT Heater
I turned the heater off for 3 weeks and now when I turn it on it displays EO4 and runs cold for 60 seconds then off to EO4. I have removed the ignitor on the right but the part on the left next to the ignitor is unknown to me. We have had the heater for 3 yr with no problems until now.
  • 310 Answers
If this is a MiniMax NT STD heater, the part on the right on the bottom is not the ignitor, it is the flame sensor. The part on the left with 2 wires is the ignitor. The E04 code is for a fan failure. This means that either the fan is seized, or the air switch is bad, or the air switch tubing is cracked (this is most common)
If you hear the fan is going, then turn off heater and check the air tube connected to the air switch (3" round disk on right side under the square steel enclosure with 2 wires coming off it on the front).
Remove the tube and inspect it to make sure there are no cracks.
If the tubing is good, and the fan works, you need a new air switch.
If you know how to use a multimeter and/or just need more help, you can reach me @ adamh@newconceptchem.com
Posted on Jan 07, 2011
One other possibility -- this happened to me. There were trees near the unit and some leaf and twig debris had manged to work their way down into the fan. Not enough to stop it, but slowed it down and/or impeded the air flow enough to cause the air switch to register insufficient flow and throw an E04 code. Cleaning the debris out fixed the problem.
Posted on Jan 28, 2011
Drain hot water heater
turn off gas
turn off cold water to heater
connect hose to spickot
place hose end outside
turn on spickot
open hot water faucets in house
wait.
when water stops, turn on cold water for 30-60 sec or so to try to stir up any sentiment in tank
turn off cold water and let drain.
close spickot
turn on cold water
let fill till water start coming out hot water faucets then turn off hot water faucets.
turn on gas and relight pilot.
finish bleeding air from hot water faucets.
set water heater thermostat
Jun 14, 2014 | Rheem 43VP50E2 50 Gallon FVR Natural Gas...
Re: Bosch Highflow Water Heater - model YS2433R. Hot water runs for 1-2 mintues and then turns cold. Burners turn off. Display flashes "14" (error?). Started when winter set in. Ph. 64 4 5666948
hi there,
have you gone checking the unit... first check the thermostat switch, and also the fan blower fuse/resistor.. It could be one of those is not functioning well now...
Let me know...
Jul 05, 2008 | Heating & Cooling
Freezer is forming frost around the light fixture located in the ceiling of the freezer compartment. We must manually remove the frost approximately two times per week.
If you are certain that the evaporator fan is running then your automatic defrost function has stopped working.
There are 3 things that cause it to stop working:
1. The defrost control
Item 801 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5206998&diagram_id=26604625#d26604625
2 The defrost heater
Item 826 above link
3. The thermo disc Item 621 above link.
4. The bi-metal thermostat (closed below 60 deg F)
Item 4 can be tested for continuity at temps below 60 deg F.
Item 2 and 3 can be tested at room temp for continuity.
Item 1 the main board controls the defrost cycle which turns the defrost heater on and off.
Primary suspects would be the defrost heater and thermo disc.
Shop areound for the heater if you find that is bad... the link I posted that heater seems VERY expensive to me. The heater PN: WR50X10042 I note prices in the range of $115.00 - $171.00
This PN defrost heater has a history of repeated failure.
Thanks for choosing FixYa,
Kelly
Sep 08, 2011 | GE Profile PFS22SBSS Bottom Freezer French...
My central heating unit is in the attic of my 2bd/2bth house. I don't know its age. It's a gas unit, but doesn't have a constant pilot flame. Rather, the pilot is ignited electronically. The problem is...
You don't mention make or model so here is my guess as to how to thinkout the trouble of what ever is in your attic.
For some reason, your heater is mis-firing. Normally, I would expect 3 to 5 such events at which time the heater goes out on safety. The heater knows it is on safety but you don't until it gets cold in your house. When you turn the power off, wait the 30 seconds, turn it back on, the heater no longer knows it is on safety (memory cleared) so it fires. Your heater continues to fire until ? at which time it starts counting again to 3 or some number. At the max mis-fire number - it goes out on safety again ... repeat - turn it off, wait 30 seconds, turn it back on - no memory and so forth.
Do you have a service contract or regular service man? Might be time to find one.
Thanks for your question at FixYa.com
Jan 05, 2010 | Heating & Cooling
Error code lo and eo4
The LO is just telling you the water is below 58 degrees. The EO4 is the fan sensor. If you haven't used the heater for a while you should check for rat and bird nests then you can check your air pressure switch to be sure it is OK. The NT LN model will have the gas pressure switch in the same circut, so if you have the low nox model be sure to check all your gas valves and be sure they are on. If this is a LP heater be sure your tank is at least 1/3 full to have enough pressure to run the heater. If the heater hasen't been run for a while be sure to bleed your gas line also. Good luck.
Dec 04, 2009 | Pentair Minimax NT Heater
Power OK, can smell gas, but no ignition. Get the
The EO4 is listed as a Fan Failure. However, these heaters have a tendency to go EO4 for no apparent reason. It is what I call the "heater hic-cupping". The easiest thing to try first is to reset the heaters computer. To do this, you will open the right hand side door, find the POWER toggle switch and move it to OFF. Then turn off the Circuit Breaker to the heater,shutting down all electrical power to the unit. You will need to wait about 15 to 20 minutes before you do anything else.
After that time, revese the order. Turn on the Circuit Breaker, then the Power Switch on the heater. Try and start the heater. The computer will "reboot" flashing codes like --- or 888, do not worry about those. When the display panel comes back to normal, check what the heater is reading for a water temp and compare that to what the water is actually. Hopefully, they will be right on, or close, together. The heater will try to start 3 times before going into "Lock Out" mode.
If it does start, it was just the computer hic-cupping. If it does not start and you receive another EO code, on the backside of the Display Panel, there are Diagnostic Lights. If there is a light on by a couple of letters, like HLS or PS, then that is what is malfunctioning.
Jul 08, 2009 | Pentair Minimax NT Heater
Heayrt won't fire e4 can't hear fan runnung
I am not sure if you have gotten this issue corrected, or not, but the first thing I would try to do is to reset the heater computer system. This sometimes corrects and EO4 error code.
What you will do is open the right hand side door and find the POWER toggle switch, turn that off. Then find the CIRCUIT BREAKER for the heater and turn that off as well, then wait about 15 to 20 minutes. After waiting, you will turn the CIRCUIT BREAKER on first, then the heater. Try and start the heater up.
If the EO4 code comes back, there may be an issue with the heater. If the code does not come back and the heater starts, then the error code was what I call a "computer hic-cup".
Jul 04, 2009 | Pentair MINIMAX NT TSI IGNITER
HEATER GOES OFF ON EO2 OR EO4 CODE . WATER FLOW IS 145GPM HEAT EXCHANGER IS CLEAN FAN WORKS FINE. VENT PIPE HAS BEEN CLEARED OUT THIS IS A MINI-MAX 400 I RUN A FAN BLOWING ON THE HEATER AND IT STAYS ON...
EO4 is the heater fan error, it may go on briefly and then shut off after only a few minutes. most likely cause is a blown fan-there is a thermal switch installed on the blower fan that shuts off the fan when it gets too hot. the only workable solution is to replace the blower fan unit completely also 145 GPM is a very high flow rate; normal residential pools operate in the 40-70 gpm range and 110+GPM on commercial pools if this is residential you may have too much pump for your system. 1 1/2-2 hp is standard if you also run an automatic vaccuum off the same pump
May 07, 2009 | Pentair MINIMAX NT TSI IGNITER
Rheem Model# RGDJ-10eamer sometimes lights and sometimes does not
Find the small tube that runs from the inducer blower. Disconnect the hose and see if there is water in it. If so then I suggest remounting the pressure switch that it is attached to a little higher and so that there is no droop in the tube for water to collect. Just shortening the tube will only allaow water in to the pressure switch. The second thing is with the tube disconnected at the inducer take a straightened paper clip and poke it in the orifice on the nipple attached to the inducer. there may be a partial blockage. Let me know what you find.
Feb 27, 2009 | Heating & Cooling
2001 chevy s10 no heat
remove the heater hoses at heater core and backflush heater core with a water hose it is clogged
Oct 02, 2008 | 2001 Chevrolet S-10
Pentair Minimax NT Heater Logo
698 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
