Question about Samsung SyncMaster 2493HM Monitor
I have the SAMSUNG SyncMaster 2493 HM. It used to auto rotate on it's own and now it doesn't. the "90°" square box shows up when i rotate the monitor vertically, however it does not change. Please help! I would be greatly appreciative! Notes: I have checked the driver. It's updated and "working properly". I also went into the settings and tried to correct the issue there but unfortunately got lost. Thank you! ~ Sincerely, Chad
SOURCE: Brightness automatically going low when the brightness is at 100
hello, please make sure the magicbrite option is not set to "dynamic contrast" as this will change the contrast levels by itself, change the settings by pressing the down arrow touch key on the monitor, change it to any other setting, game mode is blinding on my one (when the monitor works, but thats another story!!!) good luck with samsung customer care centre 0870SAMSUNG (uk)
Posted on Apr 09, 2009
frankzjm
  • 191 Answers
SOURCE: Samsung 244t Monitor display issue
if the monitor will match well with Nvidia GTS8800 graphic card, you need to consider two issue:
1) resolution match from windows display property and moniter manu same one.
2) refresh frequency match from windows display property-->advance-->monitor and monitor manu--> refresh frequency
if two side setting could be all matched that you can use normally
if two side setting could not be matched any above step that you can not use some resolution normally possible.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 29, 2009
SOURCE: Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Posted on Oct 28, 2009
budmrtn
  • 11361 Answers
SOURCE: My samsung syncmaster 2493 wouldn't come out of
Look at the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 30, 2009
SOURCE: Rotation of Samsung SyncMaster 2243BWX
They are referring to the video card in your COMPUTER, not the monitor. There is a supported list of cards at http://www.samsung.com/Products/Monitors/magictune/magicrotation_06s.htm
Posted on Feb 01, 2010
Monitor rotation from MacBook Pro
Go to system preferences > displays, then there's an option to rotate the display. You'll also need the corresponding cable to connect it. Enjoy the mac!
Dec 11, 2012 | Samsung SyncMaster 2493HM Monitor
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
Sep 06, 2011 | Samsung Computers & Internet
My screen just stopped working and I have a rectangular box floating around in a counterclockwise rotation that says " Check cable signal " Do you have any ideas? It was working fine up...
that means your monitor is working fine, just check your video connection on both ends of the monitor and PC.
maybe your PC has two video cards, try to plug in another video connector
Jan 29, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
Medion radeon x740xl can this show full hd on
It doesnt look like this card supports HDCP, which is required to decode HD content.
Nov 22, 2009 | Medion M3 Director 5100 PC Desktop
Apr 04, 2009 | Samsung SyncMaster 2493HM Monitor
Samsung SyncMaster 913v picture rotated 90 degrees
Please press Ctrl-Alt and your arrow keys until the image is straight!
Mar 10, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung Monitor image rotates 90 degrees
Use ctrl+alt+ up Arrow key (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Mar 27, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
Samsung SyncMaster 2493HM Monitor Logo
207 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
