Question about Frigidaire FEF366 Electric Kitchen Range
No fault errors the oven will not work, clock is not working, everything else on the range works except the oven
  • 1,772 Answers
Hello,Sorry to read about your problem
Their is a 80% chance you heat element is defective. and 10% your control knob is defective or a broken or worn wire.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
Posted on Jan 04, 2011
Testimonial: "wont know until I try the solution"
  • 1 more comment
  • jtbulman Jan 04, 2011
    If it were the heating element the clock and other items in the oven should work
  • Barrett Palumbo
    Barrett Palumbo Jan 04, 2011
    getting old, just saw the clock part, correct.element is good
    Try this to determine which part is needed.
    This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
    Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
    Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
    1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
    2. Gain access inside the control panel.
    3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
    4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
    5. Turn the power back on.
    6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
    7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
  • Reggie Good Dec 28, 2012
    My FEF366CCB is doing the same thing. It was preceded by a loud pop and tripping of the breaker. It happened during baking. When the breaker was turned back on, surface units work, oven light works, no clock, no codes, no response from any of the touch controls, non-working oven.
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
answered on another appliance site..
https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
Feb 12, 2018 | Frigidaire Ovens
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
I AM GETTING F1 ERROR CODE ON FRIDIGEAIRE MODEL #CFEF372CS2 SERIAL # NF41924422, ONLY OVEN NOT WORKING
I am 99% positive you need a new EOC based on the fact that you said you heard the all too common pop noise. EOCs usually cost around $200-$300 and sometimes more. The EOC in this is the same as your clock, if you took off the top back you will see burn marks on the back of the clock.
Jul 04, 2014 | Frigidaire PLEF398AC Electric Kitchen...
Top and bottom heating element does not work on Frigidaire electric range ES300
Usually when both elements are not working and everything else is working fine, the problem is your OCU (oven control unit), commonly known to consumers as the clock.
The clock controls the oven and most times does not produce an error code when it fails.
You will need the actual model number from a sticker located on the oven frame when you open the bottom drawer, the sticker will have the model and serial number clearly listed.
Do a Google search for that model number and find the clock.
I've provided a link for what probably is the proper clock but without the full model number I can't say for sure:
http://www.appliancepartspros.com/frigidaire-clock-316207529-ap3764682.html
Apr 05, 2013 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Everything works on the oven except the oven , wh...
If you mean that the fan in the oven will not come on check that the clock just needs resetting.
Hope this helps.
May 20, 2010 | Ovens
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
Jan 23, 2009 | Rangemaster 110 (Gas) Kitchen Range
Maytag MER5775Q Electric Kitchen Range
heating elements are usually good or failed with nothing between so unlikely to be the element. problem probably lies with the thermostat. to check, bypass the thermostat and check the oven gets really hot.
May 17, 2007 | Maytag MER5775Q Electric Kitchen Range
Frigidaire FEF366 Electric Kitchen Range Logo
449 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
