Question about Weber Genesis Silver A Grill
I replaced the Burner Tubes. The grill still does not heat up very hot, good flame not very much heat? Thank You
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
you may have a defective main gas control valve, the round silver looking thing, that the gas hose connects to.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 04, 2011
ON THE CAST IRON BURNERS THERE IS A PLATE WERE THE BURNER INSERTS INTO THE GAS VALVE. THIS PLATE CAN BE ADJUSTED TO ALLOW MORE/LESS AIR TO THE BURNERS BY SWIVELING THE PLATE .CANTHESE BE REPLACED
This 'adjustable plate' is known as an 'air shutter' located at the tips of the venturri tubes which are the tubes that carry the propane from the valve to the burner. These air shutters allow you to control your flame by mixing oxygen with propane to create a yellow flame to a blue flame. The perfect flame is a uniform blue flame with a small yellow tip.
Unfortunately, these air shutters are considered part of the burner itself and cannot be individually replaced. However, if the burner and venturri tubes are separate from each other, you may be able to get a replacement venturri tube without having to replace the entire burner unit.
Hope this helps.
Ben
Tanks 2 You Propane
propanetanks2you.com
Mar 30, 2010 | Lynx Grilling
Can not adjust flame.
It sounds like the grill just needs a good cleaning, plus when you do clean it check that the burner tubes and orfaces are free of any debris.
The orface is a tiny hole inside a small brass threaded insert where the gas blows through into the burner tubes, it is very critical that this is clear as well as the burner tubes.
Jul 29, 2009 | Weber Grilling
Low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Jul 03, 2009 | Weber Genesis E-320 Propane Grill
I have a ducane stainless steel ducane 30400042. Weber has sent me new burner bars since the old ones rusted but you do I install them?
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Jun 20, 2009 | Ducane 30400040 Stainless Steel Grill
Need to replace burner tubes on a Ducane grill. How do you do this? How do you get the old one off? I don't have a manual anymore.
First call Weber to receive the Warrenty burners for free. Have model and serial numbers ready. They can be found on one of the doors. Here is what I did for my Ducane model 30400042.
Jun 07, 2009 | Ducane 30400042 (LP)
The gas flow cannot be raised and a slight breeze puts out the fl
The new gas grills have a safety device built into the gas hose that can cause this problem until you get familiar with it. The flame on a gas grill should be blue. If you have a yellow flame it could be caused by a couple of different problems. First of all the burner might be worn out. If you have an older grill then you should inspect the burner to make sure that there are no cracks or holes and that all the burner holes are the same size. If you have a newer grill or burner, or your burner appears to be fine then the problem might be with the regulator. The regulator is a round metal object near the connector to your gas supply. Sometimes regulators get stuck. This can reduce the gas flow, make a yellow flame and keep your grill from getting hot. To solve a stuck regulator, turn off the fuel supply to your grill. Disconnect the main connector and open the grills control value. This will eliminate any pressure on the regulator. Sometimes this will reset the regulator, but sometimes they stay stuck. Take a small hard object like the handle of a screwdriver and give the regulator a gentle tap. Now you can reconnect everything and see how your grill works now. If you still have a yellow flame your propane tank might be low, the regulator may need replacing or you could have a blockage in the venturi tubes. So check your fuel level by pouring hot, not boiling water down the side of the tank. Feel along the side where you poured the water. The propane level is where the tank feels cold. If you have plenty of fuel, locate the venturi tubes. The venturi tubes are located along fuel lines right behind the control valves. These allow air to mix with the fuel before reaching the burners so they have a small open space. If that space is blocked it will restrict the fuel flow to the burner. Make sure it is clear of obstruction. If you have done all this and still have a yellow flame you may need to look at replacing
May 29, 2009 | Brinkmann 810-8410-S Stainless Steel...
How to change the burners
Mar 30, 2009 | Ducane 30400040 Stainless Steel Grill
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
Replace burners
remove the cooking grates and the 5 pieces ubnder the grates covering the burners from the grill. Next remove the 4 screws on either side of the control knob panel pull it away from grill and pull the burners out from inside the grill. DO the reverse to install new burners
Apr 19, 2008 | Ducane 30400042 (LP)
Flame on gas grill is too small
From: http://bbq.about.com/cs/replacementparts/a/aa071100a_3.htm
Symptoms and Solutions Low Flame: The grill just doesn't want to heat up. This can be cause by several things. Taking it from the fuel source to the flame, lets start with the burner. Newer propane tanks contain a self regulating feature that will automatically slow down the flow of fuel if it thinks it's too high. This can be solved by turning the tank valve off completely and disconnecting it. Open the control valves (on the grill control panel) and ten close them. Reconnect the fuel tank and slowly turn on the valve. Now light the grill to see if that fixes it. Otherwise check the control valve(s) and venturi tubes for obstruction and alignment. Make sure that the flow of fuel is continuous. Check the burner for clogged gas holes. You can usually see this problem by observing how the grill burns. If there are spots without flame then you probably have a clogged burner.
Oct 28, 2007 | Patio Classic Barbecue Bucket Grill
Weber Genesis Silver A Grill Logo
64 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
