Question about Microsoft Xbox 360 Console
My xbox box has an e71 i think thats what it is and what is that how do i fix it.
  • 839 Answers
E 74, E 79, E 71 is shown on screen and a solution to fix it is by ensuring that your A/V connections on your Xbox 360 is secured. Another possible cause to the error is that there is a power surge or outage on your system.
BETTER U Click here to download repair guide
Posted on Jan 04, 2011
Yes my xbox pops up e71 but everything ive read want you to go into your dashboard.. but my dashboard wont even show it goes straight to the system error page.. can you help me?
E71, Your system was shut down in the middle of an update. Im sorry but there is no easy fix for your issue as there is no way to re-flash your system. the only option you have is to buy an xbox motherboard on ebay, they cost around $50.
Thanks
www.1RepairStop.com
Sep 18, 2011 | Microsoft Xbox 360 Console
My xbox 360 has the red light of doom and popped up on the t.v. says it is a E71 problem has ocurred. How can I fix this? -thanks
E71 can be a result of a few things. The most common way to rid the problem is to change the output settings briefly (If your playing HD switch to SD cables or vice versa). I know that has fixed many peoples E71. If not, you may have to reformat your HDD to factory settings (Make a backup of your game saves first!)
Mar 13, 2011 | Video Game Consoles & Games
E 71 error code
Nobody is 100% sure what causes this error but it Most likely relates to dashboard and console updates. Also, the problem appears to arise from gamers incorrectly flashing their hardware or doing botched firmware hacks which then prevent the system from functioning correctly.
Have you recently updated your Xbox 360 in anyway, or have you (or anyone else) attempted some form of firmware hack or flash? If so, this is probably the cause of the e71 code on your Xbox, however, it could also be completely random. If you call microsoft they will most likely tell you to9 just reset but that is only a temporary fix and you still have the problem of annoying freezes which will get worse and worse. Fixing the Xbox e71 is quite tricky. First try these methods,
1) switch off the console. With the console switched off, press and hold the sync button (the small white button that is used to search for wireless connections). While holding the sync button, switch on the console by pressing the power button and do not release hold of the sync button until the console is fully booted up. During the booting up of the console, any failed updates will be cleared allowing the console to run normally once again and thus eliminating the xbox 360 e71 error.
Another similar way is to
2)Hold the wireless connection button on your controller down with the 360 off. It's the little white button between the shoulder buttons. It's what you used to set up your wireless controller with your 360. While still holding the button, hit the XBOX logo on the controller to turn on the XBOX. Do not let go of the white button. After it's fully started up, you can let go. this reverts you back to your last update.
Or if nothing else seems to work you could try completely resetting your Xbox 360. To do this,
3) First enter the dashboard, go to the right-most column, go and press "Initial Set Up" then follow the instructions on screen. If you cannot access this screen due to the e71 error on your Xbox 360, you can try holding the "Y" button on your controller as you switch the console on. This will enter the same process, and restore default factory settings. However, there is still a chance that this might not work.
There are guides available online for less than $30 if you cant seem to get it fixed but make sure you get one that explains all errors as most only tell about the red ring of death.
Hope this helps
Nov 30, 2010 | Microsoft Xbox 360 Console
I have an xbox 360 that pops up with the 3 red lights on the front and every now and then the e71 error. How do I fix this problem myself?
Hope this helps
Nov 29, 2010 | Microsoft Xbox 360 Console
Error code e71
Your Xbox 360 will need to have the board repaired. We can certainly help you with this. Call us at 888-389-3038 and we'll give you a free quote today.
- You've been helped by a Wired Extreme technician.
Apr 16, 2010 | Microsoft Xbox 360 Pro System Console
My xbox got one ring with error code E79 or E71
Well, E79 and E71 are different things.
The E79 is an error code representing a Hard Drive error. It could be the HDD itself or its a connection problem with the hard drive. Try playing your 360 without it and see what happens.
E71: possibly a dashboard update error, there is no solution at present the console must be sent back to MS for repair. Try resetting your console, or Power Off, remove the HDD if you have it. Reconnect the HDD.
Jul 15, 2009 | Microsoft Xbox 360 Console
E 71 error on xbox 360
Sorry timehrhart you've just copied a huge section from Xbox Scene forums without mentioning the Reset codes.
Back to the question - E71 is due to a dashboard update, most new Xbox consoles get this error due to missing a patch that was available to download when the new Xbox dashboard came about.
To fix this you have to clear all game updates and clear the console cache and update your console via Xbox Live. To do this on the old dashboard layout go to the 'System' blade and then Console / on the new dashboard go to 'My Xbox' tab and then go to the far right and choose the 'System Settings' and then Console and then go to the 'Memory' section. Press Y and enter this code - X,X, Left Bumper, Right Bumper, X,X.
You will get a message asking if you want to clear your cache, press Yes and just wait for it to do it's thing and it should come back to the dashboard. Now you have to update your console via Xbox Live and hopefully it should fix the problem.
If this should fail then you have to send your Xbox back to Microsoft for it to be fixed. Microsoft have extended the warranty of any Xbox to 3 years if it has the E71 or Red Ring of Death error, so hopefully you should be covered.
Mar 13, 2009 | Microsoft Xbox 360 Console
The Xbox 360 will come on for about 2-3 minutes and then freeze up. It will then say "System Error. Contact Xbox Customer Support. E71."
Go to the following X-Box page and view the information.
http://support.microsoft.com/kb/927747?sd=xbox
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this solution.
Feb 22, 2009 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
59 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
