Question about Frigidaire FGF316 Gas Kitchen Range
Hello my left burner doesnot light up, when we turn the know,the sparks do come it but not the flame
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
Due you also hear the gas flow, if you dont. you have a defective gas control. if you hear gas flowing
you need to clean the burners, and clean out the little holes.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 04, 2011
  • mikeraja Jan 04, 2011
    how do you clean the burners and the little holes ? WIth a safety Pin or a Hair Pin ?
  • Barrett Palumbo
    Barrett Palumbo Jan 04, 2011
    yes that can be a first step, or toothpick
Right side burner will not ignite. Pilot flame is on.
Hello Paul;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number or your range. This is located on a metal tag either on the face of the oven after you open the door, or on the side of the door.
Each burner probably has a individual flow control valve to adjust the flame. This is a low probably, but still could be the problem.
Let's assume you can light the bad burner with a match:
You either have individual spark ignitors at each burner, or a multi-spark module in the upper left top back of your range. This controls all 4 burners.
Go into the following website, put in your model number and find your individual burner ignitor or the spark module. Record the part number and going into the web and search the part. Do not purchase from Sears unless you want to pay 2 or 3 times the price. Also, consider used parts.
Water Filters Lawn Garden Appliance Parts
This is a easy fix if you have basic tools. Turn the gas supply off. Then turn on the burners to bleed the system from gas. Then kill the power to the range - circuit breaker or electrical cord before you begin the work.
Feb 28, 2016 | Ovens
One burner won't spark when another is aflame. Multi-ignition BlueStar 4-burner range.
I would check that the plates are on correctly. Make sure they are aligned and sitting properly. Sometimes they move while cleaning and give you a bad ground connection for the spark.
Feb 15, 2016 | Kitchen Ranges
Right stove top burners won't ignite
Your right side burners probably have small vertical lighting holes that are clogged where the pilot lights the burner. Use a sewing needle to poke each hole clean. While you're at it, poke clean the horizontal burner holes just to make sure they are not clogged either. Are there also little tunnels from the burners to each pilot flame? Make sure those are clean inside and attached properly on each end. The pilot flame should be approx 3/8" tall. Compare the working pilot flame to the non-working pilot flames and adjust as necessary. Each pilot has a small aluminum tubing running to it, the adjustment screw will be on this tube. You'll just need a small flat head screw driver to turn it counter-clockwise to increase flame. Hope this helps. Let us know if we can be of further assistance. Douglas
Jun 05, 2010 | Amana ACF3325 Gas Kitchen Range
I have a JGP636 or 960. One burner won't do
When you turn the burner knob on does the igniter click and turn off on it's own when the flame ignites? If it does then it has flame rectification. That means it can sense when the flame is on. Or does it click when the knob is in the light position and not stop until you move the burner knob? Then this is standard ignition. If it is standard ignition it sounds like it is the igniter switch built into the burner knob might be defective. Are you able to turn on any burner knob and when they are in the igniter position do all the electrodes spark or just the burner that you are turning on? If they all come on then they are wired in a series. If they are wired in a series do you get a spark at the electrode of the problem igniter? If so you can turn on one of the other burners to ignition position then while it is clicking turn on the problem burner to light it. If the cooktop uses flame rectification then there may be a problem with the switch built into the burner knob or the flame rectification sensor for that burner might be bad.
Sep 29, 2009 | GE Profile JGP636 Gas Cooktop
Top left burner sparks, lights, but keeps sparking
Remove the burner cover so you can check the connections. If both connections are solid, the spark module is faulty and will have to be replaced. If the range is less than one year old it should be under warranty.
Apr 30, 2009 | Viking VGSC366-6B Gas Kitchen Range
Ignition problems
It sounds like the round burner orifices are dirty. Remove the round orifices and clean in warm soapy water, using a plastic scrubber or toothbrush to remove and dirt and residue around the sides of the burner. Do the same on the little electrode that protrudes at some position around the burner orifice seat.
The system works by the spark ignition module knowing a gas knob is open, and sensing for a flame by ionization within the exhaust gases of the flame. If things are dirty, then the module cannot read the ionization and shuts down the burner, and will also cause the spark to continue.
Also make sure all the burner orifices are properly seated in their holder. If not, the same thing will happen.
Jan 14, 2009 | Gaggenau 23 in. KG 260 Gas Cooktop
Ignitor would not turn off on front left burner
Same problem with the ignitors on the burners myself.  But only when i turn on the left side burners do they continually spark.  Any one know what ignition module on this?  How does it prove flame?  To ground?  Might I have a bad ground causing it to not rectify the flame?
May 16, 2008 | Jenn-Air JGS8860BDP Stainless Steel Gas...
No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Mar 14, 2008 | Cooktops
Gas kitchen range
Most problems with gas ranges have to do with the flame--either it isn't quite right or it's nonexistent. Most new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners. If, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
Jan 18, 2006 | Crosley CE35100AA Electric Kitchen Range
Frigidaire FGF316 Gas Kitchen Range Logo
48 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
