Question about Panasonic 5.8GHz Cordless Telephone
The phone screen is now blank on three of my panasonic 5.8 ghz phones. How do I fix this?
  • Panasonic Master
  • 6,771 Answers
This is not cost effective repair, the main processor ic that directs the LCD is malfunctioning and you need to replace the whole system.
Posted on Jan 04, 2011
How do I fix my Motorola Moto G after it has dropped into water?
if you immediate removed the battery and left it drying for a few days you had a chance. but now it is fried
Jun 21, 2015 | Motorola Mobility Moto G 8 GB Black...
New issue after a few years of good service, very heavy static on all phones in the system. It is not the DSL filter, as i tried a new one.
Is it possible that the DSL line is filtered outside or the phone jack is defective? Has anything changed recently? Try isolating the DECT 6.0 phone system. Otherwise, consider replacing it with a 5.8 GHz system. I have a the same system (the Panasonic KX-TGA402N -- the three pack, a old 900 MHz cordless answering phone, several Bluetooth devices, and a 2.4 GHz wireless router (Linksys WRT54G2.) I have no noise problem. If you can't determine the source of the interference, I assume you already replaced the phone system.
Mar 08, 2015 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
Cordless Extension handset (non-color) screen remains blank and does not connect to Multi Function Printer.
Hi, the handset is not registered with base, to register please follow this process:
1. On handset press Menu/OK.
2. Press cursor up or down to choose "Register HS", then press Menu/OK.
3. Press Menu, 0, 6 on the control panel of base unit (MFP)
4. Press OK on the control panel of MFP.
You should hear one long beep when the handset is registered correctly. If not (three short beeps) repeat steps from 2 to 4.
Aug 02, 2012 | Brother BCL-D10 - Cordless extension...
My panasonic KX-TG5663B's screen says 9 and a little circle. The answering machine is not working. It just tells callers we are not available and hangs up. Can you assist us with this issue?
The answering system is set for the greeting mode. It will enter this state if the message memory is full or when the caller recording time is set to Greeting only.
To change the caller recording time from the handset, press Menu 0 6 2 then select the desired length of the recording. Then Save the setting and press Off.
If the phone is in this state, then delete messages from the unit. Then reset the caller recording time.
The manual for the phone is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/5-8-GHz-Phones/Operating-Instructions/model.KX-TG5653B.O#ts .
I hope this helps.
Mar 30, 2011 | Panasonic KX-TG5653B Trio Cordless Phone
Hot do you fix Panasonic KX-TGA560M 5.8 GHz Cordless that has nothing displaying on the screen?
Cannot hear from handset or earphone, can only hear from speaker phone. What can be the problem.
Aug 24, 2010 | Panasonic KX-TGA560M 5.8 GHz Cordless...
Display screen is blank
Panosonic KXTG5632 Screen is blank lights up but no numbers or info.phne works fine. Tried removing batt. Any sugestions
Thanks Bill
Jul 15, 2008 | Panasonic KX-TG5632 Phone
The base unit goes blank no display
I had this same problem. It turned out to be a bad power adapter for the base unit. If you have another handset that has its own charger than the power adapters are interchangable. try swapping them and see if this fixes your problem.
Mar 08, 2008 | Panasonic KX-TH111S 2.4 GHz Cordless Phone
Panasonic 5.8GHz Cordless Telephone Logo
1,061 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
