Question about Car Audio & Video
Face is stuck in odd position, won't close/open play
I have a Sony xplod 52wx4. face has 3 positions: open almost 45'/buttons-silver face; closed black screen/LED graphics when on; & @15?' posit./where face can be inserted/removed. Problem: it is stuck in @ 30' position. Won't close, open, turn on ect. Position button & remote won't work.
  • ckelly99 Sep 08, 2008
    face wont close
I have a simular problem, i found out that i had a broken flat cable that runs from the lower left side of the deck to the face plate,my problem is that i cant find out what the correct part number is to this part i was already sent the incorrect one once...... thats where i came across you ,in search for a correct part number
Posted on Jan 01, 2010
  • 158 Answers
Does your stereo have a reset button ?or does it have FACTORY SETTINGS option in the settings menu ?
First try these options ,then write in FixYa with the model number .
Posted on Jul 12, 2008
Stuck sunroof
This is an electrical problem. Check fuses and replace if necessary.
Jul 05, 2013 | Cars & Trucks
The door mechanism is stuck in the closed position and the door won't close
Push in the door button. While pushing in the button, take a screwdriver and pry up on the door mechanism on the end of the door. Should unlock and allow the door to shut again.
Feb 18, 2013 | 1999 Chevrolet Lumina
Silver strip to make battery work fell out . how does it go back in
Examine the rear portion of the Microsoft Wireless 3000 mouse (the part where the base of your palm rests). Look for a silver button marked "Microsoft."
Press the "Microsoft" button. This button is actually the battery-door release. When you press it, the battery door pops open on its hinge.
Remove the old batteries, using the tip of your finger to gently pry them out.
Insert the left-side battery. The "Positive" post on this battery should be facing the back half of the mouse.
Insert the right-side battery. The "Positive" post on this battery should be facing the front of the mouse. Push the battery cover straight down to close it.
hope it helps
Dec 01, 2011 | Microsoft Wireless Mobile Mouse 3000
Cant get back door to stay closed . The lock is stuck in locked position I think and the door is open. When I go to close it, it is'nt staying closed. Had to duck tape it to stay closed. LOL! I keep...
It sounds to me ( correct me if I'm wrong ) like the door latch on the side vertical edge of the door is in the LOCKED POSITION. In order to unlock it perform the following. First electrically with the LOCK button UNLOCK the locks. Now with one hand hold the OUTSIDE DOOR HANDLE IN THE OPEN POSITION, while at the same time FLIPPING OPEN THE LATCH. All Done . Now you can close the door. Hope this helps
Jun 27, 2009 | 1997 Chevrolet Lumina
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Open sunroof that will not close.
you can open and close you sunroof "manually" remove the plastic cover next to your sunroof and dome light buttons (above your rearview mirror) there is an allen wrench stored inside... insert the wrench into the corresponding hole and you can close or open you sunroof by turning the wrench
Nov 29, 2008 | 2000 Volkswagen Jetta TDI
Head Unit problem
Go to Sony.com and search out the user manual. Most of these units have a reset button for just these types of issues. The reset button is usually behind a tiny hole that you need to insert a paper clip into. You can also try disconnecting tthe ground from the car battery and reconnecting it. That could cause the radio to reset.
Jun 26, 2007 | Sony CDX-M630 CD Player
Illumination not working when faceplate is open.
Wire braid out to the faceplate has got a parcially broken wire on it. Sony referes to it as a flexible circuit board. Part can be purchased from sony directly, an on a one to 10 scale to replace about a five.But it does involve taking your radio apart. So if you are handy at electronics. you can look it over. If you have doubts let a professional do it.
Jan 05, 2007 | Sony CDX-M8815X CD Player
Car Audio & Video Logo
319 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
