Question about Bosch Dishwashers
Bosch dishwasher SHU3032 UC/14. The soap dispenser does not open. In the past I've used dishwasher magic or similar to clean the dishwasher of hardwater deposits and that solved the problem. The cover opens and closes manually. The springs seem fine. I removed the door skin and the linkages look good. I checked the resistance on the Wax motor and it is with in spec, approximately 2150ohms. I 've watched the cycle and the wax motor never seems to actuate. I put my meter on the leads, coming from the timer, normally connected to the wax motor and could not get a reading. I had the meter set to DC, Should I have been monitoring AC? I also see wires going to the cycle selection from the detergent dispenser. What should I check next? thank you.
4 Suggested Answers
  • 1028 Answers
SOURCE: Whirlpool Dishwasher detergent door not
if the old dispenser relay was melted or damaged replace control bd the power for the dispenser relay comes from main control and should only be at dispenser when called for in wash cycle ..the control bd is keeping the relay energized too long causing melt down
Posted on Sep 10, 2008
  • 1028 Answers
SOURCE: Humming from wax motor
yes the voltage is sent from control bd ..it is supposed to be only a brief time period but due to malfunction it is continously energized resulting in overheat..i believe you said that was a whirpool/kenmore/kitchenaid..had that happen several times ..especially on the talltubs they are controlled by solenoids not wax motors those have a rectangular dispener on left of inner door..if yours is a short tub with dispenser on right side of inner door those were wax motors have had one just go bad and not operate at all
Posted on Sep 11, 2008
  • 22 Answers
SOURCE: Maytag MDB9150 Dishwasher soap dispenser door doesn't open
the plastic lock of the soap dispenser in side the dish washer door is broken
Posted on Jun 09, 2009
The soap is not opening during the cycle. We have tried new soap, hot water running before the cycle, little soap, you name it we do it. The only way my dishes get clean is not to shut the soap dispenser.
I have the same problem! Just in the past few days -- UGH! I am highly disappointed in this dishwasher. I read that the failure to release the door is due to soap and hard water build-up. So, I've sprayed the entire soap dispenser unit with vinegar. Hopefully that will help!
Jan 13, 2011 | Bosch SHE4AM16UC 24 in. Built-in...
Soap tablet not dispensing happens every 2nd or
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Jan 05, 2011 | Bosch 24 in. SGS43E08 Exxcel Built-in...
The soap dispenser on our BOSCH dishwasher, SHE4AM, won't open during washing cycles. Please help
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Dec 13, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Washer will not dispense soap from dispenser.
make sure that the soap dispenser if clean and free of residue build up. if this is clean you need to replace the dispencer
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Model shy66co5uc/14 soap dispenser will not open during wash cycle. I can open it manually, but it does not open in any of the wash cycles.
Most likely the small sping that activates to open the soap dispenser is either broken or missing. You need to get this part from the manufacturer.
Dec 04, 2009 | Bosch Dishwashers
The some dispenser and the rinse aid dispenser seem to be "stuck", soap door doesnt open and dishes appear streaky from no rinse aid. this happened after I cleaned the deposits from under the screen in the...
There is a solenoid which pops open the soap lid after the initial rinse.
If the solenoid or soap lid latch is faulty, you will need to replace it. In the interim just poar your soap in the bottom of the dishwasher tray before cycle starts.
Only use a little amount as per normal. Dishwashing tablets are best as it is a measured amount and has the rinse aid built in.
Good luck.
Ash
Oct 21, 2009 | Bosch Dishwashers
Dirty dishes
If you have a water softener, you should use about half the recommended amount of soap. Never use a wet or paste detergent. As mentioned before, this unit should be under warranty.
Gene, in AZ
May 24, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
116 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
