Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
My all pro 150000 btu heater sputters, shoots flames and smoke. what causes that?
    Scholar:
  • 146 Answers
The first thing to check would be the fuel filter from the tank to the nozzle.
Then check the input and output filters on the back of the pump housing.
Here is a link to a service manual.
http://www.desaparts.com/service_manuals.html
Thanks
M Cramer
www.allpartsinc.com
Posted on Jan 04, 2011
I have an older reddy heater propane 35000 btu the flame is pretty yellow it runs but tends to flicker and sputter some days will only run 30 seconds other days will run 1/2 hour but always easily restarts...
The flicker and sputter is usually a sign that the unit and more specifically, the fuel nozzle needs cleaning. Anything that would cause restricted air flow, needs to be removed.
In case you have misplaced your Owners Manual, I have included a link to it. You can download and print it for future reference, if you like.
http://www.desatech.com/manuals/Construction%20Heaters/099549-01.pdf
Hope this helped you to troubleshoot and solve the problem. Please let me know.
Apr 20, 2011 | Reddy Heater-30-55,000 BTU Variable
I have an All Pro 150000 btu kerosene / diesel torpedo heater. It runs for a few minutes and then starts sputtering, shooting flames and smoke. What causes this problem?
First thing is to download the service manual.
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If the units starts up and runs good and slowly goes out it will normally be due to a lack of fuel getting to the nozzle. When there is not enough fuel being delivered to the nozzle from either a clogged fuel filter of dirty air pump output filter the unit will slowly shut down from lack of fuel.
If the unit shuts down while it is running properly and the nose come is orange then you probably have a problem with a photocell or the flame out control.
If you have other questions you can contact our service department at 269-685-4125 at extension 224
Thanks
M Cramer
www.allpartsinc.com
Jan 04, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Heater fires up and runs every once in a while it will stop flame goes out puffs smoke and fires back up also will run irregular
check ignitor element. sometimes they rust and get loose. replace if element is loose. this causes an open and the ignitor fails putting out the flame and then the safety kicks on turning off the heater blower.
Dec 15, 2010 | Reddy Heater-30-55,000 BTU Variable
I have a master 150000 btu kerosene direct fire heater that runs for 5 minutes then shuts down and blows white smoke. what is the problem?
The white smoke is the kerosene fuel hitting the hot combustion chamber. Your flame has went out. The cause for this could be many. The first thing you need to do is check your fuel. Remove your fuel cap and look at the bottom of the tank for trash or water. Use a good flash light. It will all settle to the bottom. If so, drain and clean out your tank. Add fresh kerosene. Check your fuel filter. Replace if dirty. Test again. If problem continues, It is possible that your photo eye could be deffective or just dirty. It is located next to the ignitor or spark plug. It sees the flame. If the flame goes out, the unit shuts down. The flame has to be smooth (not sputtering). Water in the fuel will make it sputter and the unit will shut down. When the water/moisture in tank settles to the bottom, your suction fuel line is just off the bottom which results in it picking up the water instead of good fuel. Always disgard the old fuel from previous year and start with fresh fuel. This will cut down alot of your problems in the future.
Dec 07, 2010 | Master Heaters B155DST
I need a ignitor for a 150000 btu construction heater(kerosene/stove oil) ywo prong-with 2 screws
You can get them at www.allpartsinc.com
Here is a link:
http://www.allpartsinc.com/Items.aspx?key=search&code=__ALLCATS__&searchval=pp200&incl_m=F
Nov 19, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
344 people viewed this question
Top All-Pro Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
