Question about Vacuums
The white plastic gears are stripped --- need replacement gears
  • powell_gil Jan 04, 2011
    this should be listed under small appliances(durabrand mixers)
  • 43,501 Answers
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Posted on Jan 04, 2011
Rug doctor brush not moving, everything works but the brush.
There is a belt that drives the brush that may be broken or loose. If that is not it you may have stripped a gear, they are all plastic, if so you may have to take it to a repair shop.
Oct 28, 2016 | Vacuums
How do I replace Dyson DC24 plug
Cut off the old plug end with wire cutters. Next, strip off the outside cover of the cord about and inch off. This will expose the black and white wire inside. Then strip off the coating on the black wire and white wire. Take your new plug end and slide the plug over the cord. Use a phillips screw driver to wire the black and white wire to the terminals.
Sep 05, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
My swivel sweeper 2 caught a carpet string and stripped the small plastic gear on the motor. How can I get another gear so I can repair my sweeper? Thanks, Ivol...
We were able to find every part ofr the swival sweeper exact for the gears you are looking for.
You can get a new complete sweeper head for 19.99 at:
http://www.swivelsweepercatalogs.com/
Mar 06, 2011 | As Seen On TV Swivel Sweeper Vacuum
What holds on the pads
There should be a black plastic disc that fits tight over that white one. The black disc has lots of little spikes to engage with the pads.
Mar 26, 2010 | Oreck Orbiter Floor Machines ORB-500,...
Spin brush will not spin. local repair man said one gear stripped and motor would need replacement. is this correct??
There is a plastic rod that sticks out of the back of the spin brush, this makes all of the brushes rotate. The motor would need to be replaced if it was not turning on anymore. this doesn't sound right...?
I think it is just a broken piece of plastic on the block brush which will need to be replaced.
You can find a schematic and the parts you need on this link
H3000 Link
http://www.usavacuum.com/category-s/85.htm
Feb 02, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
My Hoover steam vac dual v's brushes will not spin and the square that the peg goes into wont spin either. There is suction but it is making a loud noise.
sometime when the brush is not turning their are less resistance to the motor, so it will turn allot faster than normal. The turbine gear assembly which connected to the brush assembly probably broken, all the gears are made out plastic and they can easily break,strip or worned over period of usage. the assembly cost around 20 bucks and it not that hard to replace and it not that hard to take it apart, just remember what goes where. I wonldn't surprise when taking the vacuum apart as you observed closely and inspect the brush unit and the turbine gear assembly you might easily spot what broken and need replacing. hope that help some; and if you don't want to fiddle with it, your local vacuum repair guy can probably do it for less than 40 bucks. you can go on-line vacuum parts.com
Oct 04, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
I need a service manual Electrolux 6500
I don't have a service manual but maybe I can give you some instructions that will make some sense. Open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl covered strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl separates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and everything will be exposed. The control valve rests under the bag housing, since the machine is now upside down. I hope this helps. Good Luck!!
Jan 01, 2009 | Electrolux Epic 6500 Vacuum
Roomba Discovery
The plastic gears that drive the sweep brushes strip out easily on these. You can get the company to repair it for you but they make it a big hassle. I opted to buy the gear set on EBAY and replace them myself.
Dec 04, 2007 | Roomba Robotic Floor Bagless Vacuum
Electrolux 6500 can't open canister
This is what I used to open my vac... Note - the white plastic strips under the bumper clips into the case at the front end (to help these instructions, you may also want to put a thin flat blade screw driver between the white plastic strip and the case, @ the inboard most point)...
If you want to open the machine, the two bumpers on either side, that say ELECTROUX hold the egg shell together. This is the process....
1. remove the bag, leave the bag cover open
2. lay the vacuum on its side on the floor with the bag cover to your right hand side.
3. place screw driver blade flat against the bumper on the opposite end from the bag cover, near the cordwinder cover, strike the screw driver firmly with a hammer, this will unlock the bumper and it will slide off toward the bag end of the machine.
4. turn the vacuum onto the other side, and follow the same process.
5. after both bumpers are removed you can get into the vacuum.
http://www.howtomendit.com/answers.php?id=57063
Aug 30, 2007 | Electrolux Epic 6500 Vacuum
Can't open rear compartment
To seperate the two body halves: 1-Set the vacuum on it's wheels & open the front door. 2-Place a wide screwdriver blade just between the reaer cover and the rubber bumper and tap the screwdriver on the side to push the bumper forward towards the door a little bit. 3-Grasp the bumper and pull it straight out. 4-Leave the vacuum halves together...flip the vac over on it's top. 5-Put your palms against each wheel with your fingers in between the body halves..pull each side out just a little and snap the lower body upwards. It will then come apart. 6-You can then mark the wires on the cordwinder for corresct replacement afer the repair. Make sure you put the bumpers back on each I-Beam before you put it back together. (they don't need to be removed). And the FLAT end of the rubber bumper is against the front door. Good Luck !
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
