Question about Nintendo Wii Console
Error Code: 52230 I have tried everything that people say but nothing will fix it. My Wii used to connect to my internet, i took my wii to someones house and played online there. i came back selected my connection to use and it just doesnt work. Error code after error code, they keep on changing.
  • 839 Answers
Error Occurred. Press the Eject button and remove the disc. Turn the power off and follow the instructions in the console manual.
BETTER U Click here to download repair guide
Posted on Jan 04, 2011
Error code 52230 Can not connect up on wii to
This error is an issue with your router's firewall. You can find Nintendo's help on this error here:
http://www.wiierrorcodes.com/wii-error-52230-52232.php
One of the best ways to fix this would be to set up a static IP address on your Wii that is outside of the DHCP range of the router and then open up your router settings and configure a DMZ to point to that IP address. This will place your Wii completely outside of the firewall.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 09, 2011 | Nintendo Wii Console
I am getting error code 52230. Unable to connect to server. I have other blue ray unit that connects to my wireless router and gets internet
sir you can visit this site to help you fix your wii console on your own... thank you sir please rate me
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52230&system=Wii&locale=en_US
Jul 02, 2011 | Nintendo Wii Console
Im unable to co nnect to the server code error 52230
Hi there! Welcome to FixYa!
This error is usually caused by a conflict with the firewall of your wireless router.
To solve this error:
  • If you are using America Online (AOL) broadboad, you may experience problems connecting the Wii console to the internet. Please contact America Online for more assistance.
  • If you are using wireless routers with Comcast firmware, you may experience problems connecting the Wii console to the internet because of incompatibilities with the Wii console.
  • If you are using a Netgear wireless router, disable the SPI firewall setting which is usually found under the WAN Settings of your wireless router.
Hopefully one of these options will work for you! Good luck!
Jun 02, 2011 | Nintendo Wii Console
Error code: 52230
Generally, a 52230 error is caused due to an issue with the firewall of your wireless router.
I hope that your problem works out!
May 26, 2011 | Nintendo Wii Console
When watching a movie using my wii console. everytime i log on the internet w/ my computer. I loose wi-fi connection to the wii. and get an error code 52230
Error Code 52230 means that your router or Internet Service Provider is having difficulty assigning a DNS or IP address to the Wii. What this usually means when you had a connection and it drops is that you aren't getting a clean signal connection between your router and your console. First step, unplug your modem and your router wait 30 seconds and plug them back in. If that doesn't work:
Various factors affect connecting a Wii to the internet with a WiFi connection as well, including signal strength, distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your Wii too far away or, has obstacles (walls and ceilings) in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and the router or if there are obstacles.
In your case it could be the wireless adapter on your computer is interfering with the Wii. Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
May 11, 2011 | Nintendo Wii Console
Unable to connect to server. Error Code: 52230. Trying to conect to internet via motorola droid x cell phone hot spot. Wii recognizes phone however still I continue to receive the error code mentioned...
From what I could find, this error means that the wii is not assigned an ip address that is routable by the phone. Make sure your wii is using DHCP in the IP address settings, and not manual settings. For further assistance regarding this check out the site listed below, and if you like my solution please feel free to give me a thumbs up!
Nintendo Support Forums
May 03, 2011 | Nintendo Wii Console
I put Internet on the wii system and when I went to use it, it said error code:52230
Error 52230 is a problem with your router's firewall.
If you are using America Online (AOL) broadboad, you may experience problems connecting the Wii console to the internet. Contact AOL for more assistance.
If you are using wireless routers with Comcast firmware, you may experience problems connecting the Wii console to the internet because of incompatibilities with the Wii console. If this is your problem, then you likely need to get a new router or switch ISPs.
If you are using a Netgear wireless router, disable the SPI firewall setting which is usually found under the WAN Settings of your wireless router. To get to the WAN settings, on your computer, type in 192.168.0.1 in your address bar.
Apr 16, 2011 | Nintendo Wii Console
What does error code 52230 mean
from the website: http://www.wiierrorcodes.com/wii-error-52230-52232.php
This error is caused by an issue with the firewall of your wireless router.
To solve this error :
Mar 28, 2011 | Nintendo Wii Console
When trying to connect to the internet I get error code 52230?
Error Code: 52230 There appears to be an issue with your wireless router's firewall.
  1. It is possible that your Internet Service Provider (ISP) is not compatible with the Wii console. For instance, if you need to login with a user name and password when you try to go online for the first time after restrarting your PC, your ISP is likely not compatible. Please contact your service provider for more information.
  2. If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls, click here.
  3. Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
Aug 24, 2010 | Nintendo Wii Console
Nintendo Wii Console Logo
260 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
