Question about Procom MN100HPA Heater
I have a procom propane heater after a while it wouldn't stay on when I put it on level 1 why does that happen?
  • 6,826 Answers
Replace the thermocouple ,it is not staying hot enough,
Posted on Jan 04, 2011
Hello, I just bought the PROCOM MD300TGA Garage heater.I did'nt receive any paper work with the unit regarding what size propane line to run to it.I would guess it to be either 3/8 or 1/2.What do you...
Depending on the run of gas line required, most area building codes require a minimum of a 1/2". However, the last 6' can be 3/8".
Also, you can download the Owners Manual from the ProCom Website or from the World Marketing website.
Jan 19, 2011 | Procom Heating & Cooling
I have a ProCom ML150HPA for propane and would like to use a 20lb bottle the manual states that at least a 100 lb tank is required. With the 20 lb the pilot lights but will not stay liit without the...
The reason for a larger tank is so the LPG can vapourise enough to supply the heater using a smaller bottle it may freeze and not produce enogh gas
Dec 13, 2010 | Procom MN100HPA Heater
My procom heaters pilot stays on fine but when i turn it to on the flame goes down and heater goes out
I wold check gas pressure to your heater. If it's natural gas it should be about 4 ounces at gas valve. If it's propane/L.P. it shoul be about 7 ounces. If you have a gauge that you can check the pressure with there is usually a port on gas valve that is plugged and usually stamped test. Hope this helps you, Thanks
Nov 17, 2010 | Procom ML300TBA Heater
Where can I get a Charmglow gas heater pressure regulator Procom NRV81F-10? The regulator is leaking propane badly. Thanks.
There will be a number printed on the side of the regulator, contact Procom direct or just put the number into google search and something will come up.
Mar 14, 2010 | Procom QL300TYLA Heater
Hello, How to convert a ProCom VentFree Stove QL300TYLA from Propane to natural gas..
yo have to get a kit the orifices are way different because nat gas runs at one half a pound and propane runa at 10 pounds
Feb 20, 2010 | Procom QL300TYLA Heater
Convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Sep 14, 2009 | Procom ML300TBA Heater
Pilot goes out!!
My manual shows three possibilities:  1) Insufficient fresh air available for combustion, so ODS kicks off gas flow 2) Low gas line pressure (should be between 11 and 14") or 3) ODS/Pilot is partially clogged.  Toll free number for ProCom is 877-886-5989.
Mar 09, 2008 | Procom ML300TBA Heater
Pro com propane heaters
The info sheet from Northern Tool says this item is not approved for California. There is no mention about massachusetts but if you go to the procom site and do a search for specifications I'm sure you'll find something. For your information, propane heaters consume oxygen to operate but propane produces one gas, carbon dioxide NOT carbon monoxide [which is poisonous] and water vapor - about one ounce of water in a 24 hr heating period. Also be asvised that co-2 will not support life alone but the concentrations produced are very low. I'm in NY state and I use a MrHeat infrared heater in my house in the winter. My co-2 detector has NEVER tripped on.
Oct 01, 2007 | Procom ML300HGA Heater
Procom MN100HPA Heater Logo
115 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
