Question about Sylvania G-Netbook
I am not able to connect to internet but my status is showing associated with router.Signal strenth is good.There is 2 RED X N BOTTOM right corner of PC......have tried to fix with all solutions given
  • 35 Answers
My guess would be a virus that enabled a proxy on your browser. In Internet Explorer, try going to Tools -> Internet Options. Then go to Connections->LAN Settings and make sure "Use proxy settings" is unchecked. Also, while you're there try checking Automatically detect settings at the top portion of that menu. Select okay and see if it works for you.
Posted on Jan 04, 2011
I need help to disconnect a second computer to my internet
Disconnect? I assume you mean to "Connect" a second computer. You haven't supplied much information as to how you are trying to connect, so I'll assume that you are trying to connect via wireless. If your router has been set up with encryption you will need the passcode to connect. You haven't mentioned what operating system you are working with so again I'll assume it's Windows XP and you are using a laptop.
Make sure your wireless radio is turned on then look down to the bottom right corner and you should see an icon that shows your internet connection status. Right click on it and select "View available wireless networks". It will show all available connections and yours should show on it as a good signal (if you are close to the router). Select the connection and click on "Connect". If you don't have the router set up with encryption it will tell you that the connection is not protected, just click on connect again. If you have encryption set up on the router it will tell you there is encryption and will ask for the passcode/password.
Type in the passcode and then type it in again on the second line (Vista and Windows 7 will only ask for the code once). Click on "remember this connection" when you see the option. You should now be connected and cruising the net! I hope this helped out, but without more information I can't go much further. Cheers!
Mar 02, 2011 | NetGear WGR614 Wireless Router
What is a security key it says unable to connect to the access point.Check that the correct security key has been entered
The security key is the password that protects your internet from other people connecting to your internet connection. To find out what your secuity key is there are three things you can do.
1. Check the back of your router, The security key is usually printed on there.
2. If it is not on the back of your router and are not very good with a pc or laptop contact your internet service provider they can usualy tell you the key.
3. If you are good on a computer and it is connected to the internet connection you want to use, turn it on then once everything is loaded a signal bar should appear in the bottom right hand corner of your screen. left click on that and a pop up box should appear. Right click on the network you use and click on status. Another pop up box should appear with your network settings, Click on the button that says wireless properties. Another pop up box will appear and at the top of the box click security. There should then be your security key but it will be hidden like a password. At the bottom there should be a check box that says show characters, tick that box and your security key should appear.
hope this helps
Jan 09, 2011 | Nintendo DSi Red Console
I lost the cd, is there any way i can install it online?
Hi
Yes it is possible to configure this router with out the CD.
All You need to do is just follow the steps given below.
1. Connected a computer to the router using a Ethernet cable.
2. Open up a internet explorer.
3. Click on CTRL & O [The letter O as in oscar]
4. In the Open box that appears the top left corner of the internet explorer type the numbers : 192.168.2.1 & press OK.
5. This will take you to belkin router setup screen.
6. Connect the modem from your internet service provider to the yellow port on the router.
7. Click on MAC address in the router.
8. Leave the password blank & press submit.
9. Click clone & press submit.
10. And now check the Internet status the top right corner the internet status shows connected & will be able to go online.
Thanks.
Dec 26, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a D link router a outdoor antenna which isadvertised for a 3 mile range. I am about 2oo yards from the antenna. My computer indicates a the signal strenth as good but i keep dropping off the net....
please observe signal strength as when you are connected to network and till you drop off, there may be distraction in signal strength while you are connected and when you check it again, it comes to good again.
Jun 27, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
My belkin back up dont work and only 1 orange light appears on the route
ISSUE: Flashing amber modem light in the Belkin Router and won't connect to modem or computer
SOLUTION:
Step 1: First hard wire Modem>Router>Computer
Step 2: Open internet explorer and type in this (192.168.2.1) address in address bar
Step 3: You see Belkin Router Ste Up Page
Step 4: In top right corner you can find internet status it would say Connected or Not Connected
Step 5: In your for left left screeen you can find list of options in that click on "Restore Factory Default"
Step 6: It will ask you password leave it balnk and click "SUBMIT"
Step 7: Click on "Restore Defaults" Button and It will show you two warning messages click "OK" "OK"
Step 8: Then you can see the router will reboot once it is completed you will be back to the Home Page
Step 9: In your for left left screeen click on "MAC Address"
Step 10:It will ask you password leave it balnk and click "SUBMIT"
Step 11:You can see Clone computer's MAC address Button Click on It "CLONE"
Step 12:Then you can see the router will reboot once it is completed you will be back to the Home Page
Step 13:In top right corner you can find internet status it would say Connected if its not
Step 14:Unplug the Power Cord from MODEM and RUTER wait for 2 minutes
Step 15:Plug the Power cord to Modem first and wait for 2 miuntes
Step 16:Plug the Power cord to Router and wait for 2 miuntes
Step 17:You can see Modem light in router will lit up standerd Green
Step 18:In top right corner you can find internet status it would say Connected
Step 19:Now your Good to go.... Check you can go online..Good Luck...Budy
If you need any help ....Please P.M me..... I'M here to help you all....
Thanks&Regards,
Karthi.J
Apr 19, 2010 | Belkin (F5D5231-4) Router
I want connect to the moderme
ISSUE: Belkin2_bing.gif Router won't connect to modem or computer
SOLUTION:
Step 2: Open internet explorer2_bing.gif and type in this (192.168.2.1) address in address bar
Step 9: In your for left left screeen click on "MAC Address2_bing.gif"
Step 11:You can see Clone computer's MAC2_bing.gif address Button Click on It "CLONE"
Thanks&Regards,
Karthi.J
Jan 27, 2010 | Belkin (F5D8231-4) Wireless Router...
Lost internet connection rest isp address by
Check the settings of the router.
you said the internet lost.
Click Here to know how to check the settings of the router.
Oct 27, 2009 | Belkin (F5D8231-4) Wireless Router...
Connection
Hello Krmn,
Are you running windows Xp or Vista ?
George
Sep 24, 2008 | D-Link GamerLounge DGL-4300 Router...
Unable to open internet page
let you router allocate the ip addresses manually by enabling DHCP and restart the router,and remove the usb adapter from the usb port and reconnect it, but when you right click on the taskbar on the little pc icons for your connection click enable WZC windows wireless Zero configuration as this will dissable the software you got with the usb adapter and hopefully make the connection more stable, but ensure you have a strong signal.
Jun 01, 2007 | U.S. Robotics MAXg USR5421 802.11g/b...
Sylvania G-Netbook Logo
69 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
