Does my heat pump have a heat system for below freezing temps. XL13C, Model #2WCX3030A1000AA, Serial # 8302KKT9H
  • Brian Niten Jan 04, 2011
    Heat pumps generally have an auxillary heat source. It can be electric strip heat, a gas furnace, an oil furnace, or what have you. If you don't have gas or oil then you would probably have electric. Look at the indoor blower. The electric heating elements will be located in the discharge airstream of the blower. If you suspect your electric heat is not working, let me know and I will help you check it out.
    Problem Solver:
  • 5 Answers
Yes!...It has electric heating elements also called strips that come on when pulling heat from the air is not practical..
Posted on Jan 04, 2011
Pool spa heater when freezing temp
It normally will heat up with pump moving water, once the threshold is achieved - system will come out of its Freeze protection mode and will begin to work as programmed. If there is a heat call, heater will come on.
You can also locate the sensors, both the Water & Air (they need to be very close in temperature for this to work) then place them in water warmer than the actual ambient temp, & above the temp that triggers "Freeze".
Dec 27, 2012 | Jandy Aqualink Rs4 One Touch Control...
Tip
Why your unit is freezing up.
To understand why your AC or heat pump is freezing up, it helps to know how your system works.
There are 7 major parts to an AC system, 9 with a heat pump.
1 - Condenser/heat pump (The outdoor unit)
2 - Air Handler (the indoor unit unless the system is a package unit, then all is outside in one system. The air handler is usually found under the home, in an attic, or in a closet.)
In the condenser are the following major parts.
3 - Compressor
4 - Condenser coil
5 - Condenser fan
6 - (HPs only) reversing valve
In the air handler are the following major parts.
7 - Blower motor
8 - Evaporator coil
9 - (HPs only) electric heat strips
Some systems known as "dual fuel systems" use another heat source in place of the heat strips, usually a gas furnace. I will address gas furnaces in another post.
When an air conditioner is operating properly several things are taking place.
1 - The compressor is compressing or "pumping" refrigerant through the system.
2 - through changes in pressure, the refrigerant makes the evaporator coil get very cold, and the condenser coil gets very hot.
3 - The blower motor/fan circulates air across the evaporator coils, as the room temperature air (Also known as "indoor ambient") goes through the cold coil, it exits, cooled approximately 15 to 20 degrees cooler than when it entered. (In a ducted system, the blower is also the fan that circulates the air throughout the home.)
4 - The condenser fan circulates air across the condenser coils. As the outdoor air goes through the condenser coil, it removes heat from the coils that are very hot. This in turn removes heat from the refrigerant so it can run its cycle again, and through pressure changes, cool the evap coil.
5 - With a heat pump, the reversing valve reverses the flow of refrigerant in the condenser and evaporator coils.
In AC mode, the evaporator coils get cold, and the condenser coils get hot. But in heat mode, the evaporator gets very hot, and the condenser very cold.
Now, whichever coil is getting cold will freeze up if there is inadequate air flow across the coil, as the refrigerant in it is far below freezing, and there is not enough airflow to keep the humidity in the air from freezing on the coil.
Things that can cause poor airflow are,
1 - Dirty/clogged coils
2 - dirty/clogged filter (will only effect evaporator coil)
3 - Closed/blocked vents (will only effect evaporator coil)
4 - Malfunctioning or dirty fan
Low refrigerant will also cause a coil to freeze up, reduce efficiency and cause the system to run for long periods of time. Not to mention, shortening the life of the unit.
With a heat pump, in heat mode only, the condenser (outdoor) coil will routinely begin to freeze up in cold temperatures. This is due to the fact that the refrigerant is below freezing, and the cold outdoor ambient temp is not warm enough to keep the condensation in the air from freezing on the coil.
Note, a properly working AC should never freeze up.
A heat pump is equipped with defrost controls to prevent ice buildup.
Some are controlled by timers, some by temp.
When a HP is going into defrost mode, the condenser fan shuts down, the reversing valve reverses the flow of refrigerant and the once cold condenser coil now gets very hot, defrosting the coil. (Many people have said this process sounds like the unit is coming apart, or about to explode and are frightened by the "smoke" which is really just steam from melting ice that comes off the unit.)
During defrost mode, the secondary or "auxiliary" heat comes on to ensure that you are still getting warm air from the vents. (Again, this can be electric heat strips or a dual fuel system)
If you are experiencing cold air from the vents during defrost, that means your auxiliary heat is malfunctioning.
The auxiliary heat is used for three purposes.
1 - during defrost mode to maintain warm airflow (automatic)
2 - when the HP cannot maintain the set temp due to extreme outdoor temps. It comes on when the indoor temp drops several degrees below the set temp on the thermostat (automatic)
3 - For emergency heat source when the HP is not working. (Manual)
To recap....
Iced up coils?
Poor airflow
low refrigerant
Malfunctioning fan
failing defrost system
There are two things that can be done in a pinch to help de-ice frozen coils. This may get you by until the repairman can get there, or you can fix the system if you are a do-it-yourselfer.
HPs frozen outdoor coil in heat mode, not going into defrost?
Cover most of the vents, and turn the system onto cooling mode until the outdoor coil is thawed. then uncover vents and return to heat, or emergency heat. (this usually takes 15 min or less)
Frozen coils in AC mode with a heat pump?
Turn the system to heat with the thermostat on just high enough to get the system to come on. (again, usually takes 15 min or less to thaw.)
AC only, with frozen evap coils? (this can sometimes be seen frozen all the way outside to the compressor on the copper lines.)
Turn the system off, and the fan switch from "auto" to on".
This will usually defrost the coils within 1 to 2 hours.
(If your system has the furnace in line before the evap coil, turn the system to heat, and the furnace will defrost the coil within minutes.)
on Dec 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
My unit has been running all day. set on 75 degrees and still only 65 in the house
If this is a heat pump depending on the outside temp. it may not bring the temp. up. It is really not efficent to run a heat pump below freezing or near freezing.I suggest running the Auxillary electric heat if. Most heat pumps have auxilarry back up electric heat banks installed in them.
Dec 26, 2009 | Heating & Cooling
Armstrong Heat pump Package Unit, Model#1B36DA-9B,
Hi, the outdoor unit will start to freeze when it is cold outside, but also it should go into a defrost mode to melt this ice either by the defrost board or defrost thermostat. You will know as steam will rise like smoke and some folks think it is on fire. If it never goes into defrost, get back to us and we can go through some things to check. Merry Christmas,
Shastalaker7
Dec 24, 2009 | Heating & Cooling
Temp set at 68 degrees but goes to 66 and the heat pump never shuts down has an electric aux
Depending on the outside temp. your heat pump might not keep up with the demand. It is not economical to run your heat pump in temperatures at or below freezing. Doing so could cause compressor failure and these are not cheap to replace. I would be running the aux. electric in low temps.
Dec 21, 2009 | Honeywell Programmable Thermostat Heater
HEAT PUMP OPERATION FOR TEMPSTAR SMART COMFORT 2400, MODEL THC436AKC1. LOWEST OUTSIDE TEMPERATURE FOR OPERATION?
I have installed many heat pumps and if it is installed without and ouside temperature sensor I would not recommend running it below freezing 32 degrees farenheheit. Running a heat pump at low outside ambient temps. can hurt your compressor and that is the most expensive part of the outside unit.
Dec 20, 2009 | Heating & Cooling
Have a large new house with lots of vinyl clad wood double hung windows on a lake temp today this am is 0 F we have a HRV system house temp is 66 downstairs and 58 upstairs heating with a heat pump and...
Really not efficent to run a heat pump at those temperatures. Below freezing is not good for the compressor in the outside unit. The humidity in the house with the low temp. is causing the condensation on the windows to freeze. Kinda like an air conditoner does in the summer without the freezing humid air from the house goes over the cold a/c coil and the moisture condensates on the coil running down to drain pan. raising the temp. in the house and lowering the humidity should help. I would also recommend running the electric heat in low outside teperatures.
Dec 17, 2009 | Aprilaire 600 Humidifier
GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Nov 26, 2009 | Refrigerators
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
